Mixing oils
by bfleeman. 12/15/18 10:51 AM
Ebay 10% off Tech 15% off everything else*.
by demarpaint. 12/15/18 10:39 AM
Milwaukee Fuel M12 Ratchet 1/4” vs 3/8”
by Snagglefoot. 12/15/18 10:16 AM
Hifly Hf 805
by chrisri. 12/15/18 10:00 AM
Preferred 5.3L L83 Oil Filter
by zfasts03. 12/15/18 09:58 AM
sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Rough Idle after short trip
by Datarock. 12/15/18 09:07 AM
Homelite 360
by mobilaltima. 12/15/18 09:04 AM
Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
81 registered members (Artem, Audios, 4WD, amblerman, ammowaster, 15 invisible), 2,142 guests, and 39 spiders.
Topics295,106
Posts4,927,905
Members66,688
Most Online2,553
Oct 27th, 2018
Page 1 of 3 1 2 3
Sorry for beating a dead horse concerning BC 0w40! #4524196
09/23/17 04:15 PM
09/23/17 04:15 PM
Ohio
MichaelDCRogers Offline OP
Ohio
Given the countless uoas done to verify that Castrol 0w40 is in fact a decent brand name oil, often pruchased at Walmart (the irony). How well is this oil able to resist burnoff. I have tested it in my previous Mk5 GLI and found it, alongside 0w30 GC to be around the same resistance to the 5w40s both Pennzoil Ultra and Castrol 5w40.... I cant afford a Uoa to be done now...But i thought I would ask for members` advice concerning this oil`s Noack volatility, shear stability and other positive characteristics.
Re: Sorry for beating a dead horse concerning BC 0w40! [Re: MichaelDCRogers] #4524218
09/23/17 04:44 PM
09/23/17 04:44 PM
Ohio
Dorian Offline
Dorian  Offline
Ohio
I have ran the 0W40 in our old 3800. It had about 7K on the oil when it was vandalized and totaled. The oil was looking great and the car loved it, but those engines are fairly easy on oil unlike your GTI. However, I can't give you much info about the oil. I purchased it at AutoZone during the January clearance this year for $10 per 5 quart jug. At that point I can't be too picky about its performance.
15 Camry Hybrid SE 48K 0W20 Kendall bulk
14.5 Camry SE 2AR 0W20 M1 AFE 44K (Mom's)
98 Chevy Prizm 1ZZ M1 AFE 0W30 148K (Brother's)
Re: Sorry for beating a dead horse concerning BC 0w40! [Re: MichaelDCRogers] #4524290
09/23/17 06:47 PM
09/23/17 06:47 PM
Los Angeles, CA
190E26FTW Offline
190E26FTW  Offline
Los Angeles, CA
Im using Castrol Edge 0w40 Made in Germany one in my inline 6 mercedes engine. It burned about less than .5 quarts in 8000 miles. I was impressed. I used to use Mobil 1 15w50 or Mobil 1 0w40 and it was burning quickly like a quart in 300 to 400 miles. I constantly had to check the dipstick, which annoyed me as I had no engine leak!
Im impressed with Castrol 0w40 German made oil, but now its Belgium so I havent tested that out yet. My stash is still German made. Also I mix in Castrol Super Car (Made in Austria) 10w60 oil with the 0w40 if I know I am going to super hot regions like Las Vegas. It handled the 118 degree air temp heat no problem. My coolant temp stayed at 82 C the entire time with AC on. I was amazed. Mobil 1 15w50 would have burned off but Castrol mixture did not even move on the dip stick for the entire 1200 mile trip (went to nor cal also). Engine also ran quieter than Mobil 1. Not bad for a 24 year old car with 238,000 miles.
The next oil I want to try is Pennzoil Platinum Euro 0w40 which I have 12 - 5 quart jugs of. Noack is 6% which is lowest of all the name brand oils. I think Castrol is around 8%? I dont remember exactly the number
Re: Sorry for beating a dead horse concerning BC 0w40! [Re: 190E26FTW] #4524311
09/23/17 07:15 PM
09/23/17 07:15 PM
Great Lakes
Quattro Pete Offline
Great Lakes
Originally Posted By: 190E26FTW
Pennzoil Platinum Euro 0w40... Noack is 6%
Source of this info?
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Sorry for beating a dead horse concerning BC 0w40! [Re: MichaelDCRogers] #4524412
09/23/17 09:41 PM
09/23/17 09:41 PM
MN
oil_film_movies Offline
MN
Castrol 0w40 has to be very good to pass 229.5, A40, LL-01, VW specs, etc., the toughest set of tests for passenger car oils on the planet. Thats all you need to know. It performs.
Re: Sorry for beating a dead horse concerning BC 0w40! [Re: 190E26FTW] #4524414
09/23/17 09:54 PM
09/23/17 09:54 PM
Texas & Global
4WD Online confused
4WD  Online Confused
Texas & Global
Both a 0w40 and a 15w50 consumed at same extreme rate? Id put the odds pretty low they are even close on base oil.
2018 Chevy 1500 Z71 4WD
2017 Chevy Tahoe LT 4WD
2014 Fusion Hybrid Titanium
2013 Cruze LTZ - RS Turbo
Re: Sorry for beating a dead horse concerning BC 0w40! [Re: 4WD] #4524495
09/24/17 12:46 AM
09/24/17 12:46 AM
Indiana
BobFout Offline
BobFout  Offline
Indiana
He think he stated the Castrol 0w-40 was consumed at a much lower rate than the Mobil 1 15w-50.
2003 VW Jetta TDI (Sold) / 2015 VW GTI 2.0T
Re: Sorry for beating a dead horse concerning BC 0w40! [Re: BobFout] #4524499
09/24/17 01:35 AM
09/24/17 01:35 AM
Los Angeles, CA
190E26FTW Offline
190E26FTW  Offline
Los Angeles, CA
Yes Bob you are correct.
Re: Sorry for beating a dead horse concerning BC 0w40! [Re: Quattro Pete] #4524500
09/24/17 01:36 AM
09/24/17 01:36 AM
Los Angeles, CA
190E26FTW Offline
190E26FTW  Offline
Los Angeles, CA
I have a concussion right now but i thought I remembered seeing somewhere on this website. I could be wrong.
Re: Sorry for beating a dead horse concerning BC 0w40! [Re: MichaelDCRogers] #4524840
09/24/17 12:01 PM
09/24/17 12:01 PM
Ohio
Ohio
love you guys...thanks for taking the time to share your experiences...i still have research to do...if i am not mistaken... bc 0w40 is the same as german castrol 0w40...so...here it goes...the Fuley plant..owned by Ineos oligomers, is the largest oliphen blending plant in the world responsible for making performance synthetic lubrication...Guess what...Ineos is partnered with BP as a combined business.. Ineos bought BP,s Innovene division in 2005 to become a "combined business." Now, considering that BP owns Castrol, that Castrol 0w40 is sourced from Belgium and further considering the fact that Ineos, partnered with BP, has its Fule plant, its oliphen blending plant located south from Brussels Belgium, it possib,e to say that Castrol 0w40 is being sourced from that plant..which means it could have PAO group IV base stocks enabling it to perform as well as it does in a number of applications!? There is another Pao blending plant located in Germany as well...and considering that the 0w30 and 0w40 castrol has switched production between Belgium and Germany, where the pao plants are located, twice bewteen each other as products?
Re: Sorry for beating a dead horse concerning BC 0w40! [Re: 190E26FTW] #4524844
09/24/17 12:04 PM
09/24/17 12:04 PM
Ohio
Ohio
look at previous comment...there should be good Uoas for Bc castrol too...formulations would have to be similar in order for it to perform as well as it does.
Re: Sorry for beating a dead horse concerning BC 0w40! [Re: MichaelDCRogers] #4524853
09/24/17 12:08 PM
09/24/17 12:08 PM
Great Lakes
Great Lakes
Given how low its pour point is, I would say Edge 0w40 definitely has PAO in it.
Re: Sorry for beating a dead horse concerning BC 0w40! [Re: Quattro Pete] #4524974
09/24/17 02:56 PM
09/24/17 02:56 PM
Texas & Global
4WD Online confused
4WD  Online Confused
Texas & Global
Can anyone from Oz verify this is current on the shelf M1 - I noticed the BMW being back with other German OEM's:
Re: Sorry for beating a dead horse concerning BC 0w40! [Re: 4WD] #4525209
09/24/17 07:41 PM
09/24/17 07:41 PM
Ohio
Ohio
overall. i,d say its good for all intensive purposes... castrol and mobil 1 0w40 both get decent uoas depending upon circumstance...0w40 with mobil 1 synthetic 15w50 was a good idea btw!!!referencing previous post on this thread!!!
Re: Sorry for beating a dead horse concerning BC 0w40! [Re: 4WD] #4525365
09/24/17 11:48 PM
09/24/17 11:48 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
That is old batch. Rest of the world still uses VISOM based 0W40.
15' Toyota Sienna AWD (Mobil1 0W20 EP+ 2qt of M1 0W40 + FRAM Ultra).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Page 1 of 3 1 2 3
