Fuel pump doesn't care what is downstream from it. When a fuel filter gets clogged enough to increase backpressure, the OBD2 system will throw lean codes, or some other fuel system pressure code.
Just don't ever run it dry....that is pretty much it.
EDIT: About the above post, in a perfect world with equal pumps, a returnless pump should last longer.
