Since the daughter is heading off to the dorms next week I took the opportunity today to swap out some fresh tires and go over her breaks. PO did a pad slap but neglected to lubricate ANYTHING; re-did the rears a little while back and now it was time for fronts. So frustrating but at least minimal new parts (just a pad hardware kit).
Brake fluid was terrible, though. When I did the rears and siphoned the MC and flushed them out a little, though I knew it wasn't good enough. When I siphoned the MC today the fluid coming out was thick, opaque, dark yellow (Pics when I find my phone). Replaced with Valvoline Dot3/4 (Not worried about that debate, just leave it as I have used this fluid for a long time and it works). Bled everything out with my new Motive Power Bleeder. So easy! Anyways, brakes no longer drag and feel just about a good as one could hope for with these cheap pads. Can readily lock up the 265/70r17 LTX AT2 tires that are on it now!
Seriously, though. Who installs breaks with completely dry and unlubricated caliper pins? Front and rears are slightly different but both are a version of metal pin in rubber bushing. Can you say stiction?!?
