Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
103 registered members (Arminius, ArrestMeRedZ, 2012AccentSE, albenjoseph, 55Test, Astro_Guy, 9 invisible), 1,972 guests, and 54 spiders.
Topics286,148
Posts4,903,019
Members67,565
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
Would you prefer all trans pans have a drain plug? #4523504
09/22/17 07:37 PM
09/22/17 07:37 PM
Michigan
ZZman Offline OP
ZZman  Offline OP
Michigan
I think it would be a good idea for easier maintenance.
2003 Mercury Grand Marquis. PP HM 5w-30 and Fram TG
2008 Sebring Hardtop convertible. PP HM 5w-30 and Fram Ultra
2006 Kawasaki Vulcan 900 LT. Motul 7100 10w-40 and K&N
Re: Would you prefer all trans pans have a drain plug? [Re: ZZman] #4523509
09/22/17 07:41 PM
09/22/17 07:41 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Yes. Plus a plug for the torque converter and a spin on filter.
Me: 13' VW GTI 3 door 6 speed manual
Re: Would you prefer all trans pans have a drain plug? [Re: skyactiv] #4523514
09/22/17 07:43 PM
09/22/17 07:43 PM
Michigan
ZZman Offline OP
ZZman  Offline OP
Michigan
What a nice dream.... smile
Re: Would you prefer all trans pans have a drain plug? [Re: ZZman] #4523517
09/22/17 07:47 PM
09/22/17 07:47 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
YES!!!!!!!!!!!!!
FWIW, almost all the Japanese cars' transmissions have a drain plug, while American automatics rarely do. Europeans are somewhere in the middle.
Fun fact: In the early 2000s, Ford and Mazda used a common 4-speed automatic on cars such as the focus and Mazda Protege and 3. The Mazdas have a drain plug, The Focus does not. crzy
Too bad Dorman doesn't make a transmission pan for the THM125c 3-speed auto used in so many GM cars from the 80s and 90s.
Re: Would you prefer all trans pans have a drain plug? [Re: ZZman] #4523518
09/22/17 07:48 PM
09/22/17 07:48 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
They get over torqued so often either causing a leak, Damaging the thread where I can't get it to seal after a service, Or the head is rounded off making it no use to me.
2001 Chevy Camaro L92/4L80E
Re: Would you prefer all trans pans have a drain plug? [Re: ZZman] #4523526
09/22/17 07:58 PM
09/22/17 07:58 PM
Texas
4WD Offline
4WD  Offline
Texas
DIY like I did - 20 minutes to change pan volume and filter with a good shirt on ...
Re: Would you prefer all trans pans have a drain plug? [Re: skyactiv] #4523553
09/22/17 08:23 PM
09/22/17 08:23 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
This!
2004 Corolla 129932
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Would you prefer all trans pans have a drain plug? [Re: ZZman] #4523554
09/22/17 08:24 PM
09/22/17 08:24 PM
Canada
i_hate_autofraud Offline
Canada
I'd like a drain plug, but I'd drop the pan anyway! That's where the junk is and a semi-plugged filter
at least on GMs.
Since internal filters are on the pick up side/(suction)side, any significant material in the filter
effects pump operation - and therefore shift quality, enough to set a Tranny code and do damage!
Re: Would you prefer all trans pans have a drain plug? [Re: i_hate_autofraud] #4523565
09/22/17 08:34 PM
09/22/17 08:34 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
at least on GMs.
Yes, but with a plug you can get the bulk of the fluid out before dropping the pan and making a mess (or as said above, add a spin on filter and drain plug and transmissions would last forever).
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: Would you prefer all trans pans have a drain plug? [Re: ZZman] #4523572
09/22/17 08:43 PM
09/22/17 08:43 PM
socal
barkingspider Offline
socal
I vote for drain plugs
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: Would you prefer all trans pans have a drain plug? [Re: blupupher] #4523577
09/22/17 08:50 PM
09/22/17 08:50 PM
Texas
4WD Offline
4WD  Offline
Texas
I run a Fram XG16 - change yearly along with pan volume. (B&M plug)
After 3 years the pan was clean and I changed the rock catcher
Re: Would you prefer all trans pans have a drain plug? [Re: ZZman] #4523586
09/22/17 09:01 PM
09/22/17 09:01 PM
Buffalo, NY
JTK Online content
JTK  Online Content
Buffalo, NY
As long as it's got an easy means to add fluid and check level, a drain plug is awesome.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Would you prefer all trans pans have a drain plug? [Re: barkingspider] #4523588
09/22/17 09:06 PM
09/22/17 09:06 PM
Western Ma.
rollinpete Offline
rollinpete  Offline
Western Ma.
Plus make it magnetic...
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive238K miles
PPHM 5w30 and Fram Ultra x 2
Currently under the influence of oil shocked2
Re: Would you prefer all trans pans have a drain plug? [Re: rollinpete] #4523598
09/22/17 09:17 PM
09/22/17 09:17 PM
USA
USA
Honda does this smile
Re: Would you prefer all trans pans have a drain plug? [Re: ZZman] #4523601
09/22/17 09:21 PM
09/22/17 09:21 PM
Albany, NY
ford46guy Offline
ford46guy  Offline
Albany, NY
I have the Dorman pans for all my cars. $20 is a no brainer, especially if you work without a lift. The powdercoat holds up well.
Two pans looked like they were ready to seep when I replaced them.
Too bad all their products aren't such high quality.
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Page 1 of 4 1 2 3 4
