Central A/C [censored] out
by TOMJ
06/18/18 08:43 AM
08 Scion tC under valve cover pics
by Highboy
06/18/18 08:39 AM
Storing extension ladded in garage?
by maverickfhs
06/18/18 08:27 AM
Do you let your tool batteries go dead in storage
by Snagglefoot
06/18/18 07:20 AM
BITOG using excessive CPU power?
by Kibitoshin
06/18/18 05:10 AM
Any news on what happened to this plane?
by Exhaustgases
06/18/18 02:36 AM
E4OD fluid ?
by Exhaustgases
06/18/18 02:23 AM
Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
Orion62, Revd, blinky1041, mostdecent, T1TN
65261 Registered Users
74 registered (BAJA_05, Artem, 2004tdigls, andyd, 2009Edge, badtlc, 9 invisible), 1437 Guests and 38 Spiders online.
65261 Members
67 Forums
285509 Topics
Page 1 of 5 1 2 3 4 5 >
#4523156 - 09/22/17 12:59 PM Do you flush your power steering system?
Diesel16 Offline
Loc: Michigan
Hello guys and gals. I have a question. Do you flush your power steering system at all or do you leave the factory fluid in it all itís life? I was just told by a few mechanics to never flush my power steering unit or my transmission or engine coolant because if I flush it then it will cause it to fail and not work correctly and slip. I call total old school mechanic thinking for these reasons they gave me. I look at it this way. Why would they make these fluids if they never need to be changed? Why do they make transmission filters if the fluid never needs to be changed? Fluids break down over time and donít last forever. Saying not to change the fluids would be like saying donít change your oil cause the new oil will just cause the engine to wear out faster and not operate properly. Lol
What do you guys think? Reason Iím asking is cause my car is a first gen Ford Fusion and it has about 130,000 miles on it and the power steering fluid has never been changed but it has been topped up cause it was low one time but itís dark as can be and smells like old transmission fluid. I was thinking to do the turkey baster method and suck out the fluid in the reservoir and add new and drive the car for a day and do the same thing over and over again till the fluid is nice and red since this car takes atf fluid as the power steering fluid. Also I want to get a transmission service done in it with a new filter but Iíve been told if I do that with this many miles in the car it will just cause the transmission to slip really bad and fail. I had a transmission service done before at 75,000 miles I think it was and never had it slip. Just had the rpm flair when it shifted but that went away with reprogramming.
Edited by Diesel16 (09/22/17 01:00 PM)
#4523161 - 09/22/17 01:08 PM Re: Do you flush your power steering system? [Re: Diesel16]
Chris Meutsch Offline
Loc: Cincinnati
I have never touched any PS system in any car I owned. So far, so good. Started driving in 1994.
2005 Honda CR-V EX, 254k.
2008 Honda Pilot EX-L, 96k.
#4523162 - 09/22/17 01:11 PM Re: Do you flush your power steering system? [Re: Diesel16]
mclasser Offline
Loc: The Northeast
I turkey baster the reservoir once a year. It's an easy and gentle way to replenish the PSF and its additives.
2018 Hyundai Elantra VE -- 3K
2013 Honda Pilot EX-L 4WD -- 55K
2002 Honda Accord EX-L -- 210K
#4523168 - 09/22/17 01:20 PM Re: Do you flush your power steering system? [Re: mclasser]
MCompact Offline
Loc: KY
I've done it a couple of times in my ti; can't hurt...
Mine:
2014 M235i
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2016 i3 REX
2009 Cooper Clubman
Son's
2009 328i
Buy what makes you smile...
#4523169 - 09/22/17 01:21 PM Re: Do you flush your power steering system? [Re: mclasser]
OneEyeJack Offline
Loc: S California
+1 except for my Civic which does not have P/S.
#4523170 - 09/22/17 01:22 PM Re: Do you flush your power steering system? [Re: Chris Meutsch]
WobblyElvis Offline
Loc: Toronto Canada
Same here, but since 1973.
#4523171 - 09/22/17 01:22 PM Re: Do you flush your power steering system? [Re: Diesel16]
dustyroads Offline
Loc: upstate NY
I do the turkey baster thing myself. For my last couple vehicles, I used Maxlife trans fluid in the power steering. My F150 is electric power assist, though.
As far as the transmission in your car, I wouldn't hesitate to get the old fluid and filter out. I would rather get some new stuff in there, regardless of the old sayin' that you're doomed if you swap out trans fluid so late in a transmission's life. I'm confident that you will be safe swapping out the old fluid/filter.
2013 F150 XLT 5.0 4X4 96k+
Edge 5W-30 / Fram 10575
#4523172 - 09/22/17 01:24 PM Re: Do you flush your power steering system? [Re: mclasser]
Benzadmiral Offline
Loc: Da Swamp
Same here. Though I regretted it the first time I drew out the fluid on my '97 C-Class and refilled with the OEM dealer fluid. Stuff smelled like stale garlic pretzels dissolved in male cat spray. After that I used MaxLife.
-- Paul W. (The Benzadmiral)
('11 Buick Regal CXL, charcoal/cream, 2.4L NA)
http://benzadmiral-uncle.blogspot.com/
#4523173 - 09/22/17 01:26 PM Re: Do you flush your power steering system? [Re: Diesel16]
barkingspider Online   content
Loc: socal
I turkey base the power steering in all my vehicles whenever I see that's its dark or if it's been a while. I would say approx twice per year
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
#4523183 - 09/22/17 01:42 PM Re: Do you flush your power steering system? [Re: Diesel16]
boulderdentist Offline
Loc: Boulder, Colorado
What I have heard about the transmission fluid is to drop pan, change filter, replenish. This should not damage the transmission. The experts seem to say avoid power flushes at higher mileage because it can stir up or flush out debris. If the transmission is OK, a drain and fill should not hurt. For power steering fluid I use the turkey baster method, takes patience and multiple times. Getting rid of entrapped air is messy and difficult on my Ford Taurus. Baster method eliminates that.
Scott
#4523192 - 09/22/17 01:48 PM Re: Do you flush your power steering system? [Re: Diesel16]
69GTX Offline
Loc: Connecticut
Turkey baste 32 oz of fluid into your PS steering system over the next month or so. Do a trans pan drop and fill, change filter. That will refresh 1/3-1/2 of your fluid and make a gradual change towards clean fluid. Depending on how it drives, you can do more drain and fills in the coming months/next year....ideally, you have a drain plug somewhere on your system.
The fact that automatic transmission and PS fluids shear down rather rapidly and oxidize due to heat is reason enough to change them by every 20K-30K miles. If you use a synthetic fluid then the shear should not be an issue. Conventional and semi-synthetic will shear down 10-20% during a 20K-30K mile interval. That means a 7.4 cSt viscosity fluid could end up at 5.9. Go longer and you can lower it into the 4's. Manual transmissions that use ATF's can shear conventional fluids down 25% in 10K miles.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
#4523196 - 09/22/17 01:57 PM Re: Do you flush your power steering system? [Re: Diesel16]
dogememe Offline
Loc: SF BAY AREA, CA
The whole "don't change tranny fluid on high mileage/not regularly serviced transmissions" is [censored]. Power flush with one of those machines? No. A drain&fill and filter change if applicable with the correct fluid is never a bad idea.
Radiator drain & fills are good too. Again, not a fan of power flushes or flush chemicals. Pointless on the cooling system unless it's badly neglected.
Brake fluid is better to properly flush but that's a lot of work. Sucking it out with a (clean, unused) turkey baster thing is ok once in a while if the fluid looks bad. Could always check with one of those test strips to see if water content is too high
Power steering fluid, no idea, just use the right fluid! that's important
2007 Ford Crown Vic P71 4.6 ~124K Miles, Valvoline SynPower 5W-30, Royal Purple Filter *Daily Driver*
2010 Ford Escape 2.5 ~70K Miles, Valvoline SynPower 5W-30, Wix Filter *Turo Rental Car*
#4523202 - 09/22/17 02:07 PM Re: Do you flush your power steering system? [Re: Diesel16]
nthach Offline
Loc: California
I do a periodic suck/fill of any hydraulic power steering system I touch. It's cheap insurance. Power steering is probably the most abused system in a car, we all do it(lock to lock turns, city driving, maneuvering parking lots).
#4523217 - 09/22/17 02:24 PM Re: Do you flush your power steering system? [Re: Diesel16]
ATex7239 Offline
Loc: Texas,USA
I use the turkey baster method at 100K miles or 5 yrs.
Easy to do and remember. And I'm all about easy.
'12 Buick Enclave 139,xxx
Valvoline ML SynBlend 5w30
ACDelco PF63E
'17 Ford Fusion (Company Lease) 42,xxx
Oil Ė Don't know
Filter Ė Don't care
#4523220 - 09/22/17 02:26 PM Re: Do you flush your power steering system? [Re: Diesel16]
Garak Offline
Loc: Regina, Saskatchewan, Canada
I suck out and replace the fluid periodically in the G37. On the other hand, the taxis went hundreds of thousands of miles without the fluid being replaced, without the pumps failing. So, am I really accomplishing something?
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
