Omnia - the band
by Shannow
Today at 02:58 AM
Guest's devices cannot connect to my WiFi
by boulderdentist
Today at 12:54 AM
Battery stuck in flashlight.
by Chris142
Yesterday at 11:53 PM
Must read for everyone watching their diet
by JLTD
Yesterday at 11:28 PM
2014 Mazda5 Valvoline Synpower 0W-20 7500 miles
by PWMDMD
Yesterday at 10:54 PM
VOA Ravenol ECS 0W-20
by PWMDMD
Yesterday at 10:47 PM
2020 mid-engine Corvette spy vid?!
by AZjeff
Yesterday at 10:45 PM
'05 base impala. NO turn signals.FAST blinking.
by Lee4212
Yesterday at 10:34 PM
Motul 15w-50, 5 Liter 4 Pack $19.42
by hatt
Yesterday at 10:10 PM
High Lead Redline 5W40 thoughts? Ty
by Pajero
Yesterday at 09:40 PM
Source of the Mighty Columbia River
by Snagglefoot
Yesterday at 09:32 PM
Another thick/thin article to discuss
by JLTD
Yesterday at 09:23 PM
Ethylene Glycol Long Life Coolant for KUBOTA
by pburchett
Yesterday at 09:11 PM
Mobil 1 5W-30, 6,200 mi, 2017 2.3 EB Explorer
by Whimsey
Yesterday at 08:48 PM
Chevron 10w-40, 97 Nissan Maxima, 3000 miles
by OilGeek91
Yesterday at 08:36 PM
Old green antifreeze in garage storage is gelling
by JLawrence08648
Yesterday at 08:32 PM
VWs at Pick n Pull
by Eric Smith
Yesterday at 08:17 PM
Single Data Point: CK-4 destroys the flat tappet
by Gokhan
Yesterday at 08:12 PM
Breaking in new short block
by Bub
Yesterday at 07:00 PM
Should I buy a mill or a drill press?
by Vern_in_IL
Yesterday at 06:32 PM
azzid0906, OilGeek91, DRancher, Newuser, Varbill
65299 Registered Users
23 registered (2002 Maxima SE, dishdude, BobFout, billt460, Bjornviken, dlundblad, 2 invisible), 864 Guests and 60 Spiders online.
65299 Members
67 Forums
285816 Topics
#4523100 - 09/22/17 11:29 AM adjust briggs clutch spring
edwardh1 Offline
Loc: Coastal South Carolina
for walk behing mowers.
you turn the inner/spring - outer spring part and it lenghtens or shortens the spring and cable - this affects the the drive action. is there a trick to that? my spring is hard to turn- do I pry the coils apar tsome and oil it? Im afraid that twisting the inner or outer part of the spring might bend or break the spring?
any idees?
Edited by edwardh1 (09/22/17 11:36 AM)
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
#4523204 - 09/22/17 02:13 PM Re: adjust briggs clutch spring [Re: edwardh1]
andyd Offline
Loc: Marshfield , MA
Find a PDF for the specific unit. Get the model,type and serial number of the motor and the mower and start Googling. You tube may have something too. I have PDFs for most of my OPE
Thick oil is better grin2
#4523230 - 09/22/17 02:33 PM Re: adjust briggs clutch spring [Re: edwardh1]
mk378 Offline
Loc: USA
Briggs makes engines. You need the docs from whoever made the mower.
If the spring is rusted up there is probably rust in the cable and that is a big cause of balky drive engagement. Detach both ends of the cable and check that the center moves through the sheath freely. If not, replace the cable.
Edited by mk378 (09/22/17 02:34 PM)
#4523276 - 09/22/17 03:18 PM Re: adjust briggs clutch spring [Re: edwardh1]
old1 Offline
Loc: Columbus Nebraska
Are you talking about a Snapper???
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 15/40 Delo
1929 ford model A No filters, and 15/40 oil
#4523417 - 09/22/17 05:59 PM Re: adjust briggs clutch spring [Re: old1]
edwardh1 Offline
2012 yes 21 inch walk behind
manual has no detais in how to do it, just turn it
Edited by edwardh1 (09/22/17 06:00 PM)
#4523462 - 09/22/17 07:00 PM Re: adjust briggs clutch spring [Re: edwardh1]
GravelRoad Offline
Loc: Virginia
Ok, we have a spring that screws into another spring, like a bolt into threads called a "Clutch Spring".
I normally remove the spring(s) from the clutch cable and the clutch idler arm. Needle nose pliers help.
Then spray spring with wd-40 or similar. Screw springs into each other about 2 full turns. Pliers may be needed. Re-attach spring, while watching the spring, engage drive lever, your looking for the spring coils to separate slightly. If not, remove spring again and repeat.
Then test running mower.
2016 Subaru Outback Premium. PUP 5w30 oem filter
2013 Hyundai Elantra loaded. lifetime free oil/filter change
