'15 6.7 Powerstroke UOA
by roadrunner1. 01/18/19 10:18 AM
Automotive Battery Voltage -What is ur reading?
by Patrick0525. 01/18/19 10:10 AM
Amsoil 0w-40 vs 5w-40
by Buddyp. 01/18/19 10:07 AM
M1 is changing their oils, site and adding a new oil
by Flashlightboy. 01/18/19 10:01 AM
Boiler/baseboard valve corrosion
by wormwood1978. 01/18/19 09:24 AM
Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
106 registered members (Astro14, 69GTX, atikovi, AndyB, anndel, 6 invisible), 2,110 guests, and 50 spiders.
Topics296,780
Posts4,958,731
Members66,969
Most Online2,577
Jan 14th, 2019
Extended run fuel tank #4522867
09/22/17 05:44 AM
09/22/17 05:44 AM
key largo,fl
henni Offline OP
henni  Offline OP
key largo,fl
Purchased the extended run fuel cap with tank for our Honda inverter.
Couple questions
When refueling, assuming this is always done from the extended run tank, provided the primary tank is still full?
Also, apparently it does not matter that the extended run tank is sitting on a lower level - ie. the internal gravity feed is sufficient to create a vacuum and syphon (flow unaided) fuel from extended to primary ?
Anything else to be aware of ?
Re: Extended run fuel tank [Re: henni] #4522892
09/22/17 06:17 AM
09/22/17 06:17 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
So long as there is fuel in the line, it will continue to siphon. Mid it runs dry you'll have to purge&prime it.
Cable ties should hold it
Re: Extended run fuel tank [Re: henni] #4522920
09/22/17 06:47 AM
09/22/17 06:47 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
These work on Hondas because they have a fuel pump.
I made one for my Champion, but it has to be elevated.
You can refuel the aux while the gen is running several times before you have to refuel the primary tank.
(as long as you don't take forever to do it)
Eventually, enough air will make its way in - and the only way to get rid of it is to fill the main tank again.
Re: Extended run fuel tank [Re: Olas] #4522921
09/22/17 06:48 AM
09/22/17 06:48 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I don't see any need to purge/prime the aux line. That procedure is not needed at all.
Re: Extended run fuel tank [Re: Linctex] #4523055
09/22/17 09:10 AM
09/22/17 09:10 AM
Boston, MA
HerrStig Offline
HerrStig  Offline
Boston, MA
How's the fuel pump going to pull fuel uphill into the generator tank if there's air in the line?
Re: Extended run fuel tank [Re: HerrStig] #4523125
09/22/17 11:23 AM
09/22/17 11:23 AM
Canada
boraticus Offline
boraticus  Offline
Canada
Put an inline primer bulb on the line from the auxiliary tank. Similar to that found on outboard motor fuel tanks.
Actually, an outboard motor fuel tank and line would be ideal for an auxiliary fuel supply. For the Yamaha, all you'd need is a modified fuel cap, attach a short piece of fuel line and an outboard motor fitting to the cap, connect to the outboard tank, prime the line and go. I'd likely mount the auxiliary tank higher than the generator to ensure uninterrupted fuel flow.
Re: Extended run fuel tank [Re: HerrStig] #4523900
09/23/17 09:45 AM
09/23/17 09:45 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Not quite. Just in theory.
In practice,
after the (first full) main tank is used about 1/4 of the way,
there's plenty of vacuum to pull fuel from the auxiliary tank.
