GM Marine Engine wont start
by Gito. 09/24/18 11:59 PM
New TV bad picture some channels part2
by raaizin. 09/24/18 10:46 PM
Another Bad PCM on a Buick 3.8L!
by clinebarger. 09/24/18 10:17 PM
Funny pictures thread
by JLTD. 09/24/18 08:40 PM
Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
Lubricant Additives - A Practical Guide
by wemay. 09/24/18 01:39 PM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
43 registered members (Bailes1992, Blkstanger, Brian553, Bbonez, Brian123, 4 invisible), 765 guests, and 41 spiders.
Topics290,964
Posts4,853,450
Members66,063
Most Online3,590
Jan 24th, 2017
Decent Oil Filter Wrench Nissan Frontier 4 CYL #4522742
09/22/17 12:32 AM
09/22/17 12:32 AM
California
boom10ful Offline OP
California
The oil filter location on this truck is horrid and I can barely put my hand/ a band wrench to crack the filter loose. I was going to go with a Lisle 63600 but after seeing the reviews I don't think that it will fit the small filter. Anyone know of one that will fit this filter and be compact enough to fit?
Re: Decent Oil Filter Wrench Nissan Frontier 4 CYL [Re: boom10ful] #4522772
09/22/17 02:07 AM
09/22/17 02:07 AM
Southeastern USA
FowVay Offline
FowVay  Offline
Southeastern USA
I have a 2017 Frontier and I went to Advance Auto and bought a cheap Autocraft wrench that fits over the end of the filter. I actually bought the filter wrench for my Kawasaki ZX-14R motorcycle but it works for that, on Toyota plastic cartridge filter caps, and my Nissan Frontier perfectly.
The P/N for the wrench is Autocraft AC1093 and was sold under another brand with part number W54118. I like the cap wrench because is has a 3/8" drive opening that allows me to use my torque wrench when installing filters. My Kawasaki and Nissan specify 13 lb/ft of torque and the plastic Toyota caps specify 18 lb/ft.
I believe Nissan relocated the oil filter on the newer trucks because mine sits right on the passenger side of the engine in a fully accessible location. I don't even have to remove the belly pan to do my oil changes.
Quaker State across the board.
Re: Decent Oil Filter Wrench Nissan Frontier 4 CYL [Re: FowVay] #4522780
09/22/17 02:29 AM
09/22/17 02:29 AM
California
California
Thanks for the link! Yeah, I used to have one of the newer trucks and the filter was easily accessible. Now I have this older truck and the filter is a pain to get to.
Re: Decent Oil Filter Wrench Nissan Frontier 4 CYL [Re: boom10ful] #4522883
09/22/17 07:06 AM
09/22/17 07:06 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Quote:
......I was going to go with a Lisle 63600 but after seeing the reviews I don't think that it will fit the small filter.....
Without the year can't say definitively but the two smallest filters that Nissan could use are the 6607/14612 shorty and the 7317/14610. Based on the specs the Lisle 63600 should "fit" either of those filters, both have same diameter. The Lisle cam action states it works for 2-1/2" to 3-1/8" diameter filters which would include the both those filters, and many use that cap wrench.
As an aside AZ sells the similar OEM brand cam action cap wrench with the same size specs for ~$6.
So the 63600 should "fit". That said, depending on access limitation and/or filter orientation it's possible the cam action wrench may not be the best choice.
Re: Decent Oil Filter Wrench Nissan Frontier 4 CYL [Re: Sayjac] #4523321
09/22/17 04:02 PM
09/22/17 04:02 PM
CA
user52165 Offline
user52165  Offline
CA
That AZ OEM unit is JUNK! Buy the Lisle - it will fit. Very few filters for cars are larger than 3 1/8".
Re: Decent Oil Filter Wrench Nissan Frontier 4 CYL [Re: user52165] #4523327
09/22/17 04:08 PM
09/22/17 04:08 PM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
That AZ OEM unit is JUNK!.....
That would be in your experience apparently. Otoh IME, the OEM has worked just fine in 7317/14610 applications I've used it for.
Be that as it may as noted depending of filter access and orientation, the cam action cap wrench may not be the best choice.
Re: Decent Oil Filter Wrench Nissan Frontier 4 CYL [Re: boom10ful] #4523656
09/22/17 11:41 PM
09/22/17 11:41 PM
California
California
After much deliberation, I decided to buy the Lisle 61600 64/65mm cap. Looks like it'll fit. I didn't go for the Lisle 63600 because of the multiple reviews that it won't fit a small Honda filter. Since the Nissan filter that I have is close to a Honda filter in size it would be useless to me. This 2002 Nissan Frontier 4 cylinder truck is the only one that I will be using a tool to remove a filter. The filter is 15208-9E01A.
Here's the one I bought:
https://www.amazon.com/gp/product/B00AOJAPPC/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Re: Decent Oil Filter Wrench Nissan Frontier 4 CYL [Re: boom10ful] #4523678
09/23/17 12:47 AM
09/23/17 12:47 AM
Southeastern USA
FowVay Offline
FowVay  Offline
Southeastern USA
That's the same wrench that I had listed in my initial quote. They seem to be sold under several different brand names. Mine has the 65/14 stamped inside and has worked great for many years.
