When you're too old to drive
by Speak2Mountain. 09/19/18 09:22 AM
Another VW Thread
by Zee09. 09/19/18 09:21 AM
Tremec HP MTF - No more ATF?
by ABomb369. 09/19/18 09:02 AM
Is 0W weight oil the perfect oil?
by Baas95. 09/19/18 08:01 AM
2014 Durango ZF8 transmission fluid recommendation
by MoparMan12. 09/19/18 06:45 AM
Does Rear Heater Need to be On?
by Gebo. 09/19/18 05:04 AM
125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
Audi A4 vs Volkswagen CC...or good old Passat?
by KCJeep. 09/18/18 07:19 PM
GM 454 engine
by dirtymudder. 09/18/18 07:13 PM
High Performance Motorcycle oil...which one?
by Neiz15. 09/18/18 06:50 PM
Need help High Performance Motorcycle oil?
by Neiz15. 09/18/18 06:38 PM
MC FL-500S CUT OPEN
by 53' Stude. 09/18/18 05:15 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
96 registered members (28oz, 64bawagon, ABomb369, Aero540T, AandPDan, advocate, 10 invisible), 1,180 guests, and 45 spiders.
Topics290,632
Posts4,847,745
Members66,011
Most Online3,590
Jan 24th, 2017
10w-30 Synthetic Recommendations #4522680
09/21/17 10:13 PM
09/21/17 10:13 PM
FL, USA
shurguywutt Offline OP
FL, USA
Looking for a good 10w30 synthetic. I would prefer a high mileage for the strong additive package but I can really only find 5w30 full synthetic high mileage or 10w30 high mileage synthetic blend. Any recommendations? I live in a very hot and humid climate so 10w30 would be ideal. Thanks.
2008 Pilot 2WD J35Z1 148k
Maxlife Blend 10w-30
FRAM Ultra Synthetic
Fumoto F106SX
Re: 10w-30 Synthetic Recommendations [Re: shurguywutt] #4522682
09/21/17 10:18 PM
09/21/17 10:18 PM
Western usa
Ammofirst Offline
Ammofirst  Offline
Western usa
Mobil 1 10w-30 High mileage. Wally World $22.88. Its a great choice for many applications
Re: 10w-30 Synthetic Recommendations [Re: shurguywutt] #4522686
09/21/17 10:21 PM
09/21/17 10:21 PM
South Texas
Insertcoolname Offline
South Texas
Mobil 1 hi mi is a thicker 10w30 full synthetic. Does not meet resource conserving spec but meets API SN $12 rebate off the jug right now
theres also Valvoline full syn with max life
. About to try regular max life 10w30 this next change. Never used Valvoline before.
04 Camry 2az-fe 2.4L 204k QS HiMi 10w30
Supertech white can filter
Re: 10w-30 Synthetic Recommendations [Re: shurguywutt] #4522687
09/21/17 10:23 PM
09/21/17 10:23 PM
Spring,Texas
Bud_One Offline
Bud_One  Offline
Spring,Texas
16 Civic-QSUD 0W-20, XG7317
14 Civic-Idemitsu Zepro 0W-20, XG7317
05 Chevy 2500HD-QSUD 10W-30, XG3675
97 Accord Wagon-Havoline HM 10W-30, PH3593A
Re: 10w-30 Synthetic Recommendations [Re: shurguywutt] #4522696
09/21/17 10:32 PM
09/21/17 10:32 PM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
M1 10W-30 HM is stout. I would go for that
Re: 10w-30 Synthetic Recommendations [Re: shurguywutt] #4522708
09/21/17 10:47 PM
09/21/17 10:47 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
I just picked up 5 jugs of this for my summer oil.
https://www.walmart.com/ip/Havoline-ProDS-Synthetic-Motor-Oil-10W30/54468667
$16.73 a jug shipped!
2004 Corolla 124686
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74277
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 74705 4-22-18
Re: 10w-30 Synthetic Recommendations [Re: shurguywutt] #4522750
09/22/17 12:51 AM
09/22/17 12:51 AM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
I ve been using Havoline 10w30 Full Synthetic that I got at Oreillys. Sounds good but I swear my gas mileage took a big hit v.s my regular fill of Pennzoil Platinum or QS Full Synthetic.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: 10w-30 Synthetic Recommendations [Re: shurguywutt] #4522827
09/22/17 05:22 AM
09/22/17 05:22 AM
Around the corner
koffy Offline
koffy  Offline
Around the corner
I just got 3 jugs of QSUD + 2 in 5W-30 flavor from AAP for $8.45 each, I havenít tried it though.
Re: 10w-30 Synthetic Recommendations [Re: shurguywutt] #4522833
09/22/17 05:35 AM
09/22/17 05:35 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
If for whatever reason you can't find the M1, perhaps try a HDEO 10w30. They typically are blends too.
03 Jeep WJ 4.0 200k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 149k Rotella T5 10w30 Supertech ST3980
Re: 10w-30 Synthetic Recommendations [Re: shurguywutt] #4522839
09/22/17 05:49 AM
09/22/17 05:49 AM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
Reccomendations? Yes ....
Don't get so wrapped up in believing that only one base stock or grade is going to be "ideal".
While I do agree that it's possible to find an "ideal" lube, that definitive answer is FAR, FAR past any effort ANY BITOGer here has ever put forth, or ever will. You see, to do so would take hundreds of thousands of miles of testing, using all manner of control and test groups, etc, etc, etc. Blah blah blah. Yada yada yada.
Just about any lube that is in spec with (or at least very near) the vehicle's OEM stated lube requirements is going to do fine. I SERIOUSLY DOUBT your engine will even know the difference between a 5w-30 conventional, 5w-20 semi, 10w-30 syn, etc. I presume it's going into your Pilot, but actually that really does not matter. I don't know why you think 10w-30 is "ideal" anyway; I have not seen that spec'd for a gasser in a long, long time. Do you have proof that 10w-30 is "ideal", over other grades? Or (as I suspect) is this just a "want" that you've already talked yourself into?
Do as you see fit. No issue there.
Just know that the engine does not care nearly as much as you do.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 10w-30 Synthetic Recommendations [Re: Ammofirst] #4522846
09/22/17 06:11 AM
09/22/17 06:11 AM
GA.
ChrisD46 Offline
ChrisD46  Offline
GA.
**This**
2017 Hyundai Sonata 2.4L GDI 4 cylinder
2010 Hyundai Elantra 2.0L 4 cylinder
2007 Kia Sedona 3.8L 6 cylinder
Re: 10w-30 Synthetic Recommendations [Re: Ammofirst] #4522855
09/22/17 06:22 AM
09/22/17 06:22 AM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
This
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
Re: 10w-30 Synthetic Recommendations [Re: shurguywutt] #4522876
09/22/17 06:55 AM
09/22/17 06:55 AM
socal
barkingspider Offline
socal
Any brand name 10w30 full syn will be good to go. Even supertech
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: 10w-30 Synthetic Recommendations [Re: shurguywutt] #4522881
09/22/17 07:00 AM
09/22/17 07:00 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
Valvoline Synthetic w/MaxLife Tech.
6.3% Noack in 10w30 on last check.
'18 KIA Sportage 2.4L LX AWD: GTX Magnatec 5w20
'13 Hyundai Santa Fe Sport 2.0T: EDGE 5w30
Re: 10w-30 Synthetic Recommendations [Re: shurguywutt] #4522885
09/22/17 07:09 AM
09/22/17 07:09 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
5W-30 and 10W-30 are the same oil until it gets cold out, which doesn't happen in Florida
