Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
108 registered members (69Torino, 2012AccentSE, 2010Civic, 69GTX, 1978elcamino, 8 invisible), 1,814 guests, and 51 spiders.
Topics286,112
Posts4,902,848
Members67,565
Most Online2,967
Mar 10th, 2019
OEM or Aftermarket for Sway Bar Links & Bushings #4522656
09/21/17 09:35 PM
09/21/17 09:35 PM
Massachusetts
smc733 Offline OP
smc733  Offline OP
Massachusetts
Hi All,
I am having some front-end work done on my Corolla, namely lower ball joints, sway bar links, sway bar link bushings and struts. I've found a great local shop to do the work at a very reasonable labor rate, and they're letting me supply the parts. The goal of this is to keep the car running well for another 40k miles before I plan to trade it (at 100k now). With this said, I've ordered the following:
KYB Quick-struts for the front (rear is supposedly fine)
Genuine Toyota LBJs (read one too many horror stories about aftermarkets here).
Where I'm undecided is on the sway bar links and bushings. I can get Moog problem solvers for $55 ea cheaper, and the bushings are $16 for a pair versus $13 each for the OEMs. I also looked at Beck/Arnley, but it seems these are not reboxed OEMs for this part, and have been somewhat problematic. I've read that Moog quality may have gone downhill recently, but in this case, the part for this car looks to actually be upgraded (there's a side-by-side on the Amazon page). I'm wondering if anyone has recent experience with Moog SBLs and bushings, and if you think they're a better, worse, or indifferent choice (which goes to the cheaper option) in this case.
Also, the Moog's are greasable, with a good synthetic grease, how often is this required?
2016 Hyundai Sonata SE
2011 Hyundai Elantra GLS
Re: OEM or Aftermarket for Sway Bar Links & Bushings [Re: smc733] #4522659
09/21/17 09:46 PM
09/21/17 09:46 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Seems like a lot of money to be spending on a car your not going to be keeping that much longer.
The Struts on my 2004 Corolla S held up just fine to 102,000. I figure its set for another 100,000K at least. I replaced the OEM struts with Monroe's.
2004 Corolla 129932
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: OEM or Aftermarket for Sway Bar Links & Bushings [Re: smc733] #4522668
09/21/17 10:00 PM
09/21/17 10:00 PM
MN
14Accent Offline
14Accent  Offline
MN
Go with the Moog links. You won't be disappointed.
I replaced the factory tooth picks with Moog's on my dad's Hyundai and they're night and day different. And yes, they're greasable.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: OEM or Aftermarket for Sway Bar Links & Bushings [Re: smc733] #4522718
09/21/17 10:59 PM
09/21/17 10:59 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
Are they already bad at 100K?
  • 2017 Toyota Sienna
Re: OEM or Aftermarket for Sway Bar Links & Bushings [Re: smc733] #4522734
09/22/17 12:03 AM
09/22/17 12:03 AM
California
boom10ful Offline
boom10ful  Offline
California
I'd go with Moog for the sway bar links and bushings. I usually grease the suspension every other oil change.
Re: OEM or Aftermarket for Sway Bar Links & Bushings [Re: smc733] #4522774
09/22/17 02:10 AM
09/22/17 02:10 AM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
I was in your position when I just did the front end work on my Camry
I'm being a guinea pig for Meyle HD sway bar links
$32 for the pair, made in Germany, let's see how long it lasts
I had bad luck with MAS units on a Rav4, so keep an eye out for something with wrench flats
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: OEM or Aftermarket for Sway Bar Links & Bushings [Re: smc733] #4522817
09/22/17 05:04 AM
09/22/17 05:04 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Well, I have been using the MOOG SBL's for two vehicles (Mazda3/Chevy Equinox) with good success thus far however, it's only been ~ 1.5 yrs.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: OEM or Aftermarket for Sway Bar Links & Bushings [Re: smc733] #4522882
09/22/17 07:04 AM
09/22/17 07:04 AM
socal
barkingspider Offline
socal
Go w whatever is cheaper since u are trading it in after another 40k miles
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: OEM or Aftermarket for Sway Bar Links & Bushings [Re: smc733] #4522893
09/22/17 07:18 AM
09/22/17 07:18 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Anything new will last another 40,000 miles.
Re: OEM or Aftermarket for Sway Bar Links & Bushings [Re: JMJNet] #4522974
09/22/17 08:47 AM
09/22/17 08:47 AM
Massachusetts
smc733 Offline OP
smc733  Offline OP
Massachusetts
Did you do the rears at this time, too? I'm at 98.5k to be precise right now, but two opinions have told me the rears are perfectly fine right now, while the front is "soft". Only went with the KYBs over Monroes because I could get them in time for a day next week that I can work from home to have my guy install them. $129 ea on Rock Auto.
One side (driver) has a definitely bad balljoint and clunking sway bar link. It isn't much more labor to replace them in pairs, especially since each wheel is coming off for the front struts.
Based on all the other feedback, it seems like Moog, which is also significantly cheaper, is the way to go. How often do I have to grease them?
I'm hoping everything else in the suspension lasts until 140-160k on the car, NTB tried to sell me an inner tie rod when I had my tires installed, but two opinions on that and my own diagnostic show they're perfectly tight. In fact, it seems like ever doing an inner tie rod on a Toyota is extremely rare nder 200k.
Re: OEM or Aftermarket for Sway Bar Links & Bushings [Re: smc733] #4523068
09/22/17 10:22 AM
09/22/17 10:22 AM
Georgia
DeepFriar Offline
DeepFriar  Offline
Georgia
I've got three years on the Moog Problem Solvers on a 2004 Buick Rainier, replaced all four, and so far so good. But I agree with Linctex, anything will probably get you by for 40K. You're gonna be amazed at the improved feel of new ones. Note that Moog has a less costly and probably less long term quality line that I think is called R Line. Be careful.
Re: OEM or Aftermarket for Sway Bar Links & Bushings [Re: smc733] #4523096
09/22/17 11:25 AM
09/22/17 11:25 AM
Wet side WA
Wet side WA
Did both the front and rear and an alignment. I plan on driving this car at least ten more years if my wife can stand it. At 73 she's getting tired of shifting. The car has always had good maintenance and I expect that I could get 300K out of it without a big problem. I'm the original owner of this car so I know everything its been through and its had a good life in a good home!
2004 Corolla 129932
2006 Duramax 74725
Re: OEM or Aftermarket for Sway Bar Links & Bushings [Re: smc733] #4523144
09/22/17 12:40 PM
09/22/17 12:40 PM
Canada
i_hate_autofraud Offline
Canada
When you install greasable Moog links, grease 'em fully at the install, watch for the boots to bulge.
There after, I grease them twice a year when I change to /from winter tires, with 1 shot of grease or
just less, watching for grease to weep from vents at the base of the boots.
Typically, you'd watch for water coming out with the grease when they get older. When that happens
I keep pumping grease gently til it comes out clean and up the grease interval to get water out sooner.
I do have one pal who doesn't like Moog greasable links, he's had 2 break, snapping off
where the 'bone' is welded to the joint, I saw the dead ones, I know he's hard on his Chevy Venture van!
