How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Careers.....Boomers vs Millennias
by ZZman. 03/18/19 08:05 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
108 registered members (aquariuscsm, AandPDan, advocate, aircooled, 2003f7, 53' Stude, 13 invisible), 2,309 guests, and 55 spiders.
Topics286,017
Posts4,900,829
Members67,548
Most Online2,967
Mar 10th, 2019
06 TSX - Under VC - 223k #4522636
09/21/17 08:53 PM
09/21/17 08:53 PM
Virginia
cpayne5 Offline OP
cpayne5  Offline OP
Virginia
I've owned this car since 10k miles. Steady diet of synthetics (usually SOPUS products, but no bias), mostly 5w30, with some xW40s here and there - running Edge 0w40 this fill. OCIs dictated by the dashboard. Usually 6-7k miles. Fram Ultra swapped every other oil change.
It's my daily driver. Six speed manual. Rural daily commutes of either 110 or 50 mile round trips (two desks...). About 15-20k per year.
Re: 06 TSX - Under VC - 223k [Re: cpayne5] #4522641
09/21/17 09:01 PM
09/21/17 09:01 PM
Virginia
bbhero Online sick
bbhero  Online Sick
Virginia
Extremely clean. Wonder about the cam lobes and how good they are. I'm not saying they are bad but I am curious as to what other members will say about them.
You have done a very good job taking very good care of this vehicle.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: 06 TSX - Under VC - 223k [Re: cpayne5] #4522681
09/21/17 10:15 PM
09/21/17 10:15 PM
California
Kool1 Offline
Kool1  Offline
California
I believe Honda and Acura engines rev high and aren't known for valve float issues. Valve spring pressure is probably fairly stiff to control high rpm valve float. Over time something has to wear and ultimately, the camshaft is the sacrificial lamb.
Re: 06 TSX - Under VC - 223k [Re: cpayne5] #4522685
09/21/17 10:20 PM
09/21/17 10:20 PM
WI.
dblshock Offline
dblshock  Offline
WI.
no timing chain to shred the motor oil.
16 Civic Coupe Touring 38k
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Falken Wildpeak AT3W
Re: 06 TSX - Under VC - 223k [Re: cpayne5] #4522693
09/21/17 10:30 PM
09/21/17 10:30 PM
Spring,Texas
Bud_One Offline
Bud_One  Offline
Spring,Texas
Looks great, is this the 2.0 - K20 engine ?
16 Civic-QSUD 0W-20, XG7317
14 Civic-Idemitsu Zepro 0W-20, XG7317
05 Chevy 2500HD-QSUD 10W-30, XG3675
97 Accord Wagon-Havoline ProDS 10W-30, TG7317
Re: 06 TSX - Under VC - 223k [Re: cpayne5] #4522694
09/21/17 10:31 PM
09/21/17 10:31 PM
FL, USA
gregk24 Offline
gregk24  Offline
FL, USA
Looks excellent! Normal looking lobes for a Honda K-series.
2012 Honda Accord EX-L K24z3
56,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
44,xxx miles
Castrol Edge 0w40 / OEM filter
Re: 06 TSX - Under VC - 223k [Re: dblshock] #4522700
09/21/17 10:41 PM
09/21/17 10:41 PM
WA state, USA
NothingNew Offline
NothingNew  Offline
WA state, USA
Nope, it has a timing chain.
Re: 06 TSX - Under VC - 223k [Re: Bud_One] #4522701
09/21/17 10:42 PM
09/21/17 10:42 PM
WA state, USA
NothingNew Offline
NothingNew  Offline
WA state, USA
2.4L - K24A2
Re: 06 TSX - Under VC - 223k [Re: cpayne5] #4522711
09/21/17 10:49 PM
09/21/17 10:49 PM
WI.
dblshock Offline
dblshock  Offline
WI.
add pack on w40 are huge compared to w20 good work/result.
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Re: 06 TSX - Under VC - 223k [Re: NothingNew] #4522713
09/21/17 10:49 PM
09/21/17 10:49 PM
Spring,Texas
Bud_One Offline
Bud_One  Offline
Spring,Texas
2.4L - K24A2
thumbsup
Re: 06 TSX - Under VC - 223k [Re: cpayne5] #4522880
09/22/17 06:57 AM
09/22/17 06:57 AM
socal
barkingspider Offline
socal
Looks real good. Thanks for the pics
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: 06 TSX - Under VC - 223k [Re: cpayne5] #4522910
09/22/17 07:37 AM
09/22/17 07:37 AM
Virginia
cpayne5 Offline OP
cpayne5  Offline OP
Virginia
Yes, K24A2 with a chain...which is why the VC was off.
Kind of an embarrassing maintenance snafu on my part. I had read where the chain tensioners on these engines can fail causing the engine to jump time and eat itself, so as a BITOG kind of guy I ordered a new one to throw in as preventative (over-)maintenance. I replaced it Sunday, using the FSM as my guide. Followed it to a T, but apparently something went awry during the procedure as when I went to start it up - it wouldn't. Darn.
Pulled the VC, set it to TDC and sure enough, the intake cam rotated 3 teeth beyond TDC. This was Sunday, so I immediately started tearing it down, but my impact was unable to remove the crank bolt (first one it's failed at doing so), so I ordered the Lisle super socket overnight from Amazon, which worked. I got it re-timed (with the new tensioner!) and checked the valves for leakage. All was good, so I put it back together and gave the Permatex Ultra Grey I used on the timing cover 24 hours to cure. Took it out last night for a test drive and all is right in the world again.
Don't let your kids grow up to be like me. Leave well enough alone sometimes.
Re: 06 TSX - Under VC - 223k [Re: barkingspider] #4522911
09/22/17 07:38 AM
09/22/17 07:38 AM
Virginia
cpayne5 Offline OP
cpayne5  Offline OP
Virginia
Very welcome. I enjoy other people's pics, so I like to return the favor when I can.
Re: 06 TSX - Under VC - 223k [Re: cpayne5] #4523259
09/22/17 02:57 PM
09/22/17 02:57 PM
America
Alfred_B Offline
Alfred_B  Offline
America
Nice and clean!
