The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
39 registered members (berniedd, 555, aleneros, carlprop, Brad_C, Chesterr, 3 invisible), 609 guests, and 65 spiders.
Topics286,097
Posts4,902,480
Members67,560
Most Online2,967
Mar 10th, 2019
Toyota Oil Filter Question #4522633
09/21/17 08:50 PM
09/21/17 08:50 PM
In The Region Between
Cristobal Offline OP
My 1996 Avalon has a Toyota oil filter, size 90915-YZZD1 on it. It has gone about 5000 miles.
I had my local mechanic order a new tail light switch and do some minor maintenance. I had him change the oil and leave the 90915-YZZD1 on it. The new oil is clean as a whistle.
I want to run the filter 5000 to 7500 more miles? Your thoughts? I think I am doing OK as the engine has 250,000 miles on it.
Surrounded by ferocious, snarling, & spoiled Poodles!
Re: Toyota Oil Filter Question [Re: Cristobal] #4522640
09/21/17 08:58 PM
09/21/17 08:58 PM
California
Ed_Flecko Offline
Ed_Flecko  Offline
California
I don't understand why you want to push an OEM filter WAY past it's useful life just to save $5 for the price of a new oil filter?
I think that's a bad idea...but that's just me.
Ed
K-9s teach the suspect that if you run...you'll only be arrested tired.
Support YOUR local law enforcement K-9 Unit!
https://www.ssdk9.com/
Re: Toyota Oil Filter Question [Re: Ed_Flecko] #4522642
09/21/17 09:02 PM
09/21/17 09:02 PM
By the way, the filter was made in Thailand.
Re: Toyota Oil Filter Question [Re: Cristobal] #4522665
09/21/17 09:57 PM
09/21/17 09:57 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Another job for Universal Answer Man : Nobody knows, but it probably doesn't matter.
AFAIK the worst that could happen is that the filter disintegrates or holes, but that's probably not very likely. Next worst is it goes into bypass, which isn't too bad.
If you particularly want to do it, Maybe defer and cut it open this time to get some subjective clues for next time?
Re: Toyota Oil Filter Question [Re: Ducked] #4522670
09/21/17 10:01 PM
09/21/17 10:01 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
A great idea looking at some facts before acting on impulse. Maybe even a UOA would supply some good data for the future.
2004 Corolla 129932
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Toyota Oil Filter Question [Re: Ed_Flecko] #4522706
09/21/17 10:46 PM
09/21/17 10:46 PM
VA
Gebo Offline
Gebo  Offline
VA
Ed
Iím with Ed. +1
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Schaeffer in the first two.
Re: Toyota Oil Filter Question [Re: Cristobal] #4522723
09/21/17 11:14 PM
09/21/17 11:14 PM
Canada
mcwilly Offline
mcwilly  Offline
Canada
Next time pick up an Ultra XG3614 and run it for 20,000 miles if you want with a lot more peace of mind.
2010 Subaru Sti 74,000km
2001 Toyota Echo 245,000km
Re: Toyota Oil Filter Question [Re: Cristobal] #4522778
09/22/17 02:20 AM
09/22/17 02:20 AM
Canada
mcwilly Offline
mcwilly  Offline
Canada
Well if you haven't hit maximum rated capacity...
Re: Toyota Oil Filter Question [Re: Cristobal] #4522864
09/22/17 06:38 AM
09/22/17 06:38 AM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
It will hold up well, sleep easy. The element is tough as nails, if it is a spin on, hack it open to see how the adbv does when you are done with it.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 106K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 40k Idemitsu 0w20, 57047
Re: Toyota Oil Filter Question [Re: Linctex] #4522869
09/22/17 06:46 AM
09/22/17 06:46 AM
Wet side WA
Wet side WA
Originally Posted By: Linctex
Originally Posted By: JohnnyJohnson
LOL yah but you know some people have to figure out how many times they can use a condom before it fails!
It's NOT the same thing.
"Apples to ink pens" comparison.... not even the least bit related, or comparable.
Oh but it is!
2004 Corolla 129932
2006 Duramax 74725
Re: Toyota Oil Filter Question [Re: Cristobal] #4522977
09/22/17 08:51 AM
09/22/17 08:51 AM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
Very familiar with maintaining that engine. Toyota filters like the D1 have about twice as much media as most others, it will be fine. Of all the many filters I used on that engine the Toyota worked best. Some others had start up rattle as the filter angles down and can drain out faster if the adbv leaks.
Re: Toyota Oil Filter Question [Re: JohnnyJohnson] #4522978
09/22/17 08:55 AM
09/22/17 08:55 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
What parameter of a standard UOA would you look at to get good data?
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Toyota Oil Filter Question [Re: Cristobal] #4522997
09/22/17 09:13 AM
09/22/17 09:13 AM
Michigan
khittner Offline
khittner  Offline
Michigan
Uh, how can OP, with 2400 BITOG posts, really have this question?
Re: Toyota Oil Filter Question [Re: Ed_Flecko] #4523013
09/22/17 09:27 AM
09/22/17 09:27 AM
Boston, MA
HerrStig Offline
HerrStig  Offline
Boston, MA
Ed
Apparently filters are expensive and engines are cheap.
Re: Toyota Oil Filter Question [Re: khittner] #4523030
09/22/17 09:44 AM
09/22/17 09:44 AM
I am always interested in what others have to say.
