2003 Ford CVPI, 86kmi, 6kmi on Edge HM Ti 5W30
by Colt45ws. 12/18/18 12:35 PM
2017 Kia Sportage recall notice
by SlavaB. 12/18/18 12:26 PM
My VW Service Experience
by Delta. 12/18/18 11:36 AM
Nissan high idle, P0507
by LeakySeals. 12/18/18 11:23 AM
Should i go for even thinner fluid ?
by NICAT. 12/18/18 11:06 AM
Viscosity question
by dbierman. 12/18/18 10:50 AM
48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
115 registered members (14Accent, 28oz, 97prizm, 87sammy, 15 invisible), 1,987 guests, and 38 spiders.
Topics295,221
Posts4,930,285
Members66,716
Most Online2,553
Oct 27th, 2018
2006 Honda Civic Oil and Filter Change #4522438
09/21/17 04:02 PM
09/21/17 04:02 PM
VA
maverickfhs Offline OP
VA
As the title suggests, engine is R18 and I have a lot of oil in my stash. So planning to do an oil change but have 2 questions:
1-I changed oil with A02 Honda OEM filter in March time frame of 2017. Car sees mostly short trips, did one 1500 miles trip on current oil and also do highway miles on it, usually 1-2 times a week. Should I leave oil filter because current oil has 5300ish miles on it?
2-Oil life indicator is still reading 40% and current oil has almost 5300ish miles. Should I just change oil?
Or just wait altogether until it reaches to 15% and/or 7500 miles and do both at the same time. Currently, it has conventional oil in it.
I mean, I can do both without any problem but wanted to check with pro's smile
Thanks
2006 Civic EX 202K/AT
2006 Acura TSX 180K/AT
Re: 2006 Honda Civic Oil and Filter Change [Re: maverickfhs] #4522445
09/21/17 04:09 PM
09/21/17 04:09 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
Short trips are very hard miles. Loose the mineral oil and go synthetic. Synthetic will give you 50% less wear!
2004 Corolla 126884
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: 2006 Honda Civic Oil and Filter Change [Re: maverickfhs] #4522471
09/21/17 04:41 PM
09/21/17 04:41 PM
New England
gathermewool Offline
New England
The oil filter is only required to be changed with every other oil change.
Follow the maintenance minder.
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: 2006 Honda Civic Oil and Filter Change [Re: maverickfhs] #4522480
09/21/17 04:55 PM
09/21/17 04:55 PM
Texas
Bud Offline
Bud  Offline
Texas
I would just follow your MM. Also from prices I have seen on Honda oem filters, you can get an ultra for not much more money. I also agree with using synthetic.
2016 Honda Pilot EX-L with NAVI.....Mobil 1 0w20 AFE and Honda OEM Filter
Re: 2006 Honda Civic Oil and Filter Change [Re: maverickfhs] #4522486
09/21/17 05:00 PM
09/21/17 05:00 PM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
5300 miles is a good run for dino oil that's been primarily short tripped. I'd change it.
2018 Hyundai Elantra VE -- 6K
2013 Honda Pilot EX-L 4WD -- 57K
2002 Honda Accord EX-L -- 212K
Re: 2006 Honda Civic Oil and Filter Change [Re: maverickfhs] #4522494
09/21/17 05:07 PM
09/21/17 05:07 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
If you have plenty of oil in your stash, why not?
How long are the weekly highway runs? 45min or more = follow olm. 30min is edging into borderline. 20min or less. Change oil
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: 2006 Honda Civic Oil and Filter Change [Re: maverickfhs] #4522501
09/21/17 05:14 PM
09/21/17 05:14 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
You can use the MM's full recommend OCI (when it gets to 15%) with no problems smile
The only exception is if it doesn't drop down to 15% after a whole year.
The A02 is a cardboard Fram, an orange can but with a silicone ADBV, which Fram just started putting on the Extra Guard/PH orange cans now, too. So the new Fram PH7317 is essentially identical to the A02.
For MM/OLM cars, I like to use the cheapest synthetic on sale.
Re: 2006 Honda Civic Oil and Filter Change [Re: maverickfhs] #4522626
09/21/17 07:43 PM
09/21/17 07:43 PM
VA
VA
Thanks guys, think I'll drop the oil and keep the oil filter until 10k miles.
Will add synthetic, have a lot of it in the stash.
Re: 2006 Honda Civic Oil and Filter Change [Re: JohnnyJohnson] #4522813
09/22/17 03:54 AM
09/22/17 03:54 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
It will?
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: 2006 Honda Civic Oil and Filter Change [Re: maverickfhs] #4522980
09/22/17 07:56 AM
09/22/17 07:56 AM
Vancouver, Canada
dubber09 Offline
dubber09  Offline
Vancouver, Canada
IIRC, Germans started using synth oil on their planes during WWII; that oil wasn't cheap or easy to produce and planes had chances of not coming back either, but they still used the oil in the engines, why? I bet engines lasted a fair bit longer and it was worth doing so...
Back to OP's topic.. we have Acura CSX in family and I chose to use Mahle 707 filters and PP 5w-30 with 4K miles OCI due to infrequent and mostly short trips. The filters can be had from Rock Auto at very reasonable price. Air filters and spark plugs are well priced there as well as per personal experience.
Kia Sportage 2014 GDI 2.4L
Kia Forte 2014 MPI 1.8L
Re: 2006 Honda Civic Oil and Filter Change [Re: maverickfhs] #4535347
10/06/17 10:49 AM
10/06/17 10:49 AM
VA
VA
I am so glad I did it. I know there's no sure way without UOA, but I drained oil today and kept oil filter I could smell slight gasoline from engine oil or maybe just being paranoid.
OLM was showing 30%(~6k miles). Replaced with Valvoline 5W20 synthetic dura blend in blue quarts!
Car is happy laugh
Re: 2006 Honda Civic Oil and Filter Change [Re: maverickfhs] #4535397
10/06/17 11:48 AM
10/06/17 11:48 AM
Hawaii, USA
anndel Online content
anndel  Online Content
Hawaii, USA
Do what your owner's manual states. Our 3 Toyotas say to change the filter every oil change.
1993 Toyota 4x4 p/u, 2.4L 22RE 4 cyl - Amsoil SS 10W-30, Yota OEM Filter
2005 Toyota Avalon XL, 3.5L V6, Amsoil SS 5W-30, Yota OEM Filter
2014 Toyota Tacoma 4.0L V6, Amsoil SS5W-30, Yota OEM Filter
Re: 2006 Honda Civic Oil and Filter Change [Re: Garak] #4535403
10/06/17 11:56 AM
10/06/17 11:56 AM
Wet side WA
Wet side WA
It will?
http://newsroom.aaa.com/2017/06/aaa-spills-truth-oil-changes/
2004 Corolla 126884
2006 Duramax 74478
Re: 2006 Honda Civic Oil and Filter Change [Re: JohnnyJohnson] #4535413
10/06/17 12:09 PM
10/06/17 12:09 PM
Indiana
njohnson Offline
njohnson  Offline
Indiana
It will?
I thought you were referring to the new Valvoline Synpower bottles. Besides being the new easy to pour design, Valvoline put new labels on it. I was looking at it yesterday, and on the front, it says something like "50% better wear proection than our conventional oil".
