Wagner OEX vs Akebono ProACT
by Patrick0525. 03/24/19 08:12 AM
Plasti Diping my OEM rims question
by dblshock. 03/24/19 07:53 AM
"The new" Mobil 1 Racing Oil ?
by lawnguy. 03/24/19 06:32 AM
Arlen Ness passes
by 02SE. 03/24/19 03:15 AM
Plants - they learn and remember
by Shannow. 03/24/19 03:02 AM
Rotella Gas Truck
by jpstiles02. 03/24/19 02:53 AM
The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
GSXRBullwinkie, Mark1970, FixItDad28, RandomJoe, Sciascia
67599 Registered Users
77 registered members (4WD, alarmguy, AdditiveOCD, aircooled, A1O, 2009Edge, 10 invisible), 1,541 guests, and 66 spiders.
Topics286,323
Posts4,906,403
Members67,599
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Strange Tire Crack #4522378
09/21/17 04:00 PM
09/21/17 04:00 PM
Phoenix, AZ
Nick1994 Offline OP
Nick1994  Offline OP
Phoenix, AZ
Was rotating the tires on the Sonata today and this one was on the front left, now on the right rear. Has a strange crack in it, was wondering what you guys thought? I think I'll continue on with it and just keep an eye on the tire. I bought the car 13,500 miles and 7 months ago and the tires were almost brand new when I got it. They're Kumho Solus TA11s. Tires are feathering slightly on the outer edges, I'll probably get an alignment next time I get tires.
Kind of strange how it looks like it stretches, not like a cut. No bumps in the tire and the others look fine.
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Strange Tire Crack [Re: Nick1994] #4522401
09/21/17 04:27 PM
09/21/17 04:27 PM
Anaheim, CA
zorobabel Offline
zorobabel  Offline
Anaheim, CA
You'll probably start seeing more of those cracks soon.
Aren't you supposed to cross the rears for FWD?
1997 Maxima 197k, Castrol GTX Synblend 5W-30, FL400S
2004 Corolla 197k, VWB + SSS + Rislone cocktail, MGL51516
Re: Strange Tire Crack [Re: Nick1994] #4522407
09/21/17 04:33 PM
09/21/17 04:33 PM
southeast US
friendly_jacek Offline
southeast US
notice rubber crumbling at the sharp edges. the tire is either old or overheated (underinflated?)
Re: Strange Tire Crack [Re: zorobabel] #4522418
09/21/17 04:46 PM
09/21/17 04:46 PM
Phoenix, AZ
Nick1994 Offline OP
Nick1994  Offline OP
Phoenix, AZ
When I rotated them after 6,000 miles or so, I just did front to back. This time I did an X pattern.
Tire date code is 3315, I keep them around 35 psi which is a little above door placard. Also drive a little aggressively so that might be it.
Re: Strange Tire Crack [Re: Nick1994] #4522422
09/21/17 04:47 PM
09/21/17 04:47 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
On my car this would be a change me now tire!
2004 Corolla 130035
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Strange Tire Crack [Re: Nick1994] #4522504
09/21/17 06:18 PM
09/21/17 06:18 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
Have a dealer look at this. It might be a known problem with a solution waiting.
Re: Strange Tire Crack [Re: Nick1994] #4522568
09/21/17 07:36 PM
09/21/17 07:36 PM
Warner Robins, GA
nwjones18 Offline
nwjones18  Offline
Warner Robins, GA
That wouldn't worry me at all.
2016 Ram 1500 5.7 Hemi 30k
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
Re: Strange Tire Crack [Re: Nick1994] #4522581
09/21/17 07:47 PM
09/21/17 07:47 PM
Los Angeles, CA
190E26FTW Offline
190E26FTW  Offline
Los Angeles, CA
That car isnt a heavy car unless you over load your trunk with junk. How is your alignment? If under warranty just bring it to dealer and complain. Make sure if they tell you that its nothing to worry about, have them put it in writing.
If you drive super hard maybe rotate every 5000 miles. I havent heard of people rotating in X patterns in a long time especially on newer cars as that can cause belt separation due to the different forces on the tires. What does your car manual state?
Did you balance tires before you rotated them? A lot of people get lazy and just do a garage swap.
Re: Strange Tire Crack [Re: Nick1994] #4522597
09/21/17 08:03 PM
09/21/17 08:03 PM
northern NY
Driz Offline
Driz  Offline
northern NY
I wouldn't worry about i beyond what it really is, just a junk OEM get it out the door tire. Trust me all those Kuhmo tires they use on sonatas are absolute TRASH. I know 3 other guys with Sonatas and mine took the grand prize of making 36000 miles and I ran those pigs almost bald. Everyone else's [censored] out at under 30K.
Take it to a stealer and see what line of poo he passes off on you. Maybe it will be their old standby, You didn't get them balanced and rotated twice a year mad . That's right up there with getting your disk brakes cleaned annually which is a Hyundai favorite though it is catching on with at least of the other companies stealerships as well.
Re: Strange Tire Crack [Re: Nick1994] #4522652
09/21/17 09:30 PM
09/21/17 09:30 PM
NEUS
Bandito440 Offline
Bandito440  Offline
NEUS
I had that happen on a set of BFG Rugged Trail tires that came on my 2008 Tacoma when I bought it new. The cracks spread along the circumference, and BFG replaced them under warranty with 26k miles or so on them.
Side note: the Rugged Trail was the absolute worst tire Iíve ever had. The wet and snow traction was horrendous. Do not buy.
'14 Grand Cherokee EcoDiesel
Rotella T6 5w-40 & OEM filter
Re: Strange Tire Crack [Re: Nick1994] #4522684
09/21/17 10:19 PM
09/21/17 10:19 PM
Texas
PumpPusher Offline
PumpPusher  Offline
Texas
Run it.
Re: Strange Tire Crack [Re: Nick1994] #4522724
09/21/17 11:17 PM
09/21/17 11:17 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Rubber compound ?
I would carry on with it.
Re: Strange Tire Crack [Re: Nick1994] #4522807
09/22/17 04:37 AM
09/22/17 04:37 AM
Somewhere in the US
CapriRacer Online content
CapriRacer  Online Content
Somewhere in the US
Originally Posted By: Nick1994
In addition to the crack I notice some chipping on the edges of the tread element. It is always the same edge - a partial depth cross groove, sort of within a button element. There's also some very minor chipping elsewhere.
Do you perhaps have a gravel driveway or park in a gravel lot?
Because of the shape of the crack, I think it is either from rolling over an object (like a rock) that overstressed the tread rubber.
- OR -
There is a bit of inconsistency in the tread rubber mix.
Neither of these is cause for alarm. Just check it the next time you rotate tires - and I'm hoping that is about 5K to 8K from now.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: Strange Tire Crack [Re: CapriRacer] #4523122
09/22/17 12:21 PM
09/22/17 12:21 PM
Phoenix, AZ
Nick1994 Offline OP
Nick1994  Offline OP
Phoenix, AZ
- OR -
I don't have a gravel driveway, I've driven it on a rough dirt/gravel road once for about 10-12 miles before.I usually rotate at 6-7k.
I'll keep an eye on it next time I rotate. The car is long past warranty and I bought the car used at a Subaru dealer and it came with these tires.
Re: Strange Tire Crack [Re: Nick1994] #4523447
09/22/17 06:42 PM
09/22/17 06:42 PM
Central NY/Arkansas
avacado11 Offline
avacado11  Offline
Central NY/Arkansas
Last time I read about something like that it was due to belt failure inside of the carcass. But that also comes with a bump, lots of road noise, maybe even pressure loss. With a crack that small though, it could just be slight damage from road debris.
Just keep an eye on it. Make sure it doesn't bulge out or the crack doesn't get deeper. Tires will show major signs before they blow and they're more durable than you think.
2017 Subaru Outback - 0w20 FS - Nitto NT421Q
2014 Lexus IS250 - 0w20 FS - Continental DWS06
2014 BMW i3 - Bridgestone Ecopia
2015 Nissan NV200 - 5W30 FS - Mastercraft Courser HXT
Page 1 of 3 1 2 3
