New TV bad picture some channels part2
by raaizin. 09/24/18 10:46 PM
Another Bad PCM on a Buick 3.8L!
by clinebarger. 09/24/18 10:17 PM
Funny pictures thread
by JLTD. 09/24/18 08:40 PM
Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
Lubricant Additives - A Practical Guide
by wemay. 09/24/18 01:39 PM
Fram Ultra--Any Real Competition?
by IndyFan. 09/24/18 12:59 PM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
55 registered members (Bbonez, Blkstanger, Brian123, Bailes1992, BlakeB, 5 invisible), 847 guests, and 46 spiders.
Topics290,963
Posts4,853,442
Members66,063
Most Online3,590
Jan 24th, 2017
cheap spray gun HFT? #4522228
09/21/17 01:02 PM
09/21/17 01:02 PM
indianapolis in
bmwjohn Offline OP
bmwjohn  Offline OP
indianapolis in
Spraying side door and 2 car garage door soon, thinking inexpensive pray gun, have pancake compressor, but wondering about all in one sprayer from HFT? or similar? Not be perfect but better than brush. Thoughts.? Thanks!
Re: cheap spray gun HFT? [Re: bmwjohn] #4522237
09/21/17 01:11 PM
09/21/17 01:11 PM
Indiana
nascarnation Offline
Indiana
I'd use latex house paint and brush it on, then a roller for consistent texture final finish.
I've done many this way and they look nice.
Not familiar with HFT airless unit, I've painted a house with metal siding and a good airless unit and it looked pretty nice. You do have to thin the paint a fair amount with water to get it spraying right, so runs are a worry.
Car paints with a gravity gun seems like too much trouble for what you want.
Re: cheap spray gun HFT? [Re: bmwjohn] #4522254
09/21/17 01:42 PM
09/21/17 01:42 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
2004 Corolla 124831
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74277
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 74705 4-22-18
Re: cheap spray gun HFT? [Re: bmwjohn] #4522289
09/21/17 02:25 PM
09/21/17 02:25 PM
NY
demarpaint Offline
demarpaint  Offline
NY
Brush and roller would be my choice. You have to do quite a bit of thinning of the material to get it to spray right, out of one of those units. Unless you have a good airless sprayer or a good HVLP sprayer I'd pass on spraying. I'd only spray that project if the finish has to have a sprayed look. Also by the time you get set up, and clean up those units you'll be done with a brush and roller. And you won't be thinning the product much, if any at all.
God Bless Our Troops
Re: cheap spray gun HFT? [Re: demarpaint] #4522615
09/21/17 08:27 PM
09/21/17 08:27 PM
indianapolis in
bmwjohn Offline OP
bmwjohn  Offline OP
indianapolis in
this is rustoleum oil based, on house and garage door, not auto, front door not good looking as is, prior paint oil based. thanks.
Re: cheap spray gun HFT? [Re: bmwjohn] #4522947
09/22/17 08:14 AM
09/22/17 08:14 AM
MN
Tundragod Offline
Tundragod  Offline
MN
I've used HFT airless on 4 interior doors this spring. It worked well. Used almost one gallon of paint for 4 doors on all sides. I may have lots of over spray due to inexperience with the sprayer and settings. I also used Graco 415 tip. I may use it again on a garage access, metal door. Nothing wrong with roller or brush I just like the finish of spray. I tried to use the $10 HFT HVLP sprayer, it didn't work at all because the paint was too thick. I only use it for spraying lacquer now.
12 Highlander limited, 08 Accord EXL 4, 05 Camry XLE 1MZFE, 04 MDX Tour, 02 CRV EX, 1995 Virago, I got too many cars.
Re: cheap spray gun HFT? [Re: bmwjohn] #4526535
09/26/17 09:40 AM
09/26/17 09:40 AM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
If using Rustoleum, you want to use the Marine version of it. The Marine version has built in UV protection and won't fade like made like regular Rustoleum. I have only been able to obtain this by mail order, but think Tractor Supply carries something similiar. I would also use a hardener.
That pancake air compressor won't be enough either.
