Michelin jack won't lift a load
by 10WSmuckers. 09/23/18 01:32 AM
Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
26 registered members (aleneros, csandste, Bailes1992, BlakeB, CT8, 3 invisible), 807 guests, and 37 spiders.
Topics290,867
Posts4,851,566
Members66,044
Most Online3,590
Jan 24th, 2017
Laser Pumped Phosphor Headlights #4522045
09/21/17 09:33 AM
09/21/17 09:33 AM
Idaho
SubLGT Offline OP
SubLGT  Offline OP
Idaho
http://www.drivingvisionnews.com
From this week's DVN newsletter:
Quote:
...SoraaLaser, the laser-focused outgrowth of blue/white-LED Nobel laureate Shuji Nakamura's Soraa LED lighting company, have developed the first commercially viable, efficient solid-state, white-light laser source. It boasts a luminance up to 100 times better than that of white LEDs
...SoraaLaser have produced white-light SMDs (surface-mount devices) that produce up to 500 Lm from a 300-μm emitting area…
...To produce these white-light laser SMDs, a high-power blue InGaN semipolar laser diode excites a very small (ø< 300 &#956;m) remote phosphor target that converts the laser light to eye-safe, broad-spectrum, incoherent white light….
...The 7×7-mm SMD package consists of the blue laser diode chip illuminating a 300 &#956;m area of the 1×1-mm phosphor in a reflective configuration, with a "beam dump" that blocks any blue light that could reflect from the single-crystal phosphor…
...Even though the efficacy (in Lm/W)) of laser diodes, at 30–40%, is less than the 50–60% efficacy of LEDs, the key metric in directional lighting applications is Lm(target area)/W. By this metric, laser-diode illumination improves dramatically beyond 10 m compared to LEDs.….
Right now, this technology costs substantially more than LED, but SoraaLaser says it will be showing up soon on some high end vehicles (and in other types of lighting).
I am not looking forward to having ever brighter headlights blinding me. Will welder's goggles be required equipment for night driving 10 years from now?
Re: Laser Pumped Phosphor Headlights [Re: SubLGT] #4522051
09/21/17 09:36 AM
09/21/17 09:36 AM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
I wonder how many accidents have been caused from headlights being too bright? I remember reading that if you are blinded by oncoming headlights, look towards the white line because otherwise you instinctively steer towards the light when you can't see.
2000 Jeep Cherokee 4.0L (180k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (33k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Laser Pumped Phosphor Headlights [Re: SubLGT] #4522058
09/21/17 09:45 AM
09/21/17 09:45 AM
Idaho
SubLGT Offline OP
SubLGT  Offline OP
Idaho
http://www.ledsmagazine.com/articles/201...f-lighting.html
Quote:
...Recently, SIL co-chair Bob Steele interviewed Paul Rudy [co-founder and SVP of business development at SoraaLaser] regarding the subject of laser-based light sources…
…"Just as in the case with using a blue LED as a pump source for creating white light, a phosphor is required. There are several options for pumping the phosphor, including transmissive (the white light emission is in the same direction as the pump beam) and reflective (the white light emission is at an angle relative to the pump beam). Also remote pumping, in which optical fiber is used to direct the laser light to the phosphor, is possible. This is the approach used by European automobile manufacturers to develop laser-based headlamps. We at SoraaLaser have developed a white light module using a reflective approach in which the diode laser pumps a small phosphor chip, which emits up to 500 lm of white light from a 300-micrometer spot"…
…"As noted above, these laser-pumped phosphor light sources do not suffer from droop, so high conversion efficiencies at high optical pump power are achieved. Laser-based white light sources have very high luminance values (1000 cd/mm2) relative to LEDs, so hundreds of lumens can be emitted within a small beam angle (1–2°), allowing for a high degree of optical control using very small optical elements"...
Re: Laser Pumped Phosphor Headlights [Re: SubLGT] #4522085
09/21/17 10:20 AM
09/21/17 10:20 AM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
I think people should just get their eyes checked. I have no issue with bright light thats properly aimed and doesnt blind other drivers, I do find the halogen yellow bulbs can be very dull. Some people have lights so bright that it feels they are always driving with their high beams on, its crazy.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Laser Pumped Phosphor Headlights [Re: SubLGT] #4522106
09/21/17 10:46 AM
09/21/17 10:46 AM
Idaho
SubLGT Offline OP
SubLGT  Offline OP
Idaho
The older you are, the more sensitive you are to glare. This glare sensitivity begins around the age of 50.
The linked research paper is from 2003, but still relevant
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC1771460/
Quote:
...Glare is proportional to headlamp brightness, however, so increasing headlamp brightness also increases potential glare for oncoming drivers, particularly on curving two lane roads. This problem is worse for older drivers because of their increased intraocular light scattering, glare sensitivity, and photostress recovery time. An analysis of automobile headlights, intraocular stray light, glare, and night driving shows that brightness rather than blueness is the primary reason for the visual problems that HID headlights can cause for older drivers who confront them...
Re: Laser Pumped Phosphor Headlights [Re: SubLGT] #4522199
09/21/17 12:23 PM
09/21/17 12:23 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
...SoraaLaser have produced white-light SMDs (surface-mount devices) that produce up to 500 Lm from a 300-&#956;m emitting area…
thumbsup
For sure. If you need that much light on your vehicle, have your eyes checked for cataracts.
Reading is fundamental; understanding is not a given ability.
Re: Laser Pumped Phosphor Headlights [Re: MolaKule] #4522265
09/21/17 02:00 PM
09/21/17 02:00 PM
Near Mobile
ffhdriver Offline
ffhdriver  Offline
Near Mobile
I remember in the '70s when halogen lights were just coming out and people complained that they were too bright and blinding. How things change.
Re: Laser Pumped Phosphor Headlights [Re: SubLGT] #4522364
09/21/17 03:41 PM
09/21/17 03:41 PM
Chicago, IL
dparm Offline
dparm  Offline
Chicago, IL
BMW and Audi already have laser headlamps, they just aren't legal in the US yet due to our absurd and archaic DOT regulations.
http://jalopnik.com/how-bmws-new-laser-headlights-will-work-and-not-kill-y-1521586271
2017 Chevrolet Corvette Grand Sport
Re: Laser Pumped Phosphor Headlights [Re: SubLGT] #4528460
09/28/17 01:19 PM
09/28/17 01:19 PM
pennsylvania
purelux Offline
purelux  Offline
pennsylvania
Yeah halogens were being banned in towns when they were introduced now everybody has halogen or brighter. Not to mention people who will stare at these new fangled lights then complain they're too bright. Some, usually aftermarket add on are improperly setup, though oem often is not. It's like staring at the sun if you look right at it it's blinding, go about your business like normal however and your fine.
Re: Laser Pumped Phosphor Headlights [Re: SubLGT] #4537353
10/08/17 05:22 PM
10/08/17 05:22 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
Some OEM setups are just beyond awful and almost menacing.
Seems many newish trucks have horrible lighting.. sometimes aimed very high.
Also not a fan of the "auto high beam" type setups.
Re: Laser Pumped Phosphor Headlights [Re: dparm] #4537851
10/09/17 10:43 AM
10/09/17 10:43 AM
Regina, Saskatchewan, Canada
Garak Online content
Garak  Online Content
Call me a curmudgeon, but I wish the DOT regulations were more archaic. When the only headlights were the round or rectangular sealed beams, you could have brand new, OEM headlight performance on a 20 year old car just by going to Walmart, or fix a catastrophic stone disaster for under $10. Now, everyone's headlights are faded to heck, and failures cost a fortune. Replacing the headlight assembly for my G37 would cost more than my F-150 is worth.
What I do not miss is people confusing headlight bezel screws and headlight aiming screws routinely. wink
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Laser Pumped Phosphor Headlights [Re: Rand] #4546990
10/18/17 09:24 AM
10/18/17 09:24 AM
pennsylvania
purelux Offline
purelux  Offline
pennsylvania
The problem with newer trucks can sometimes be owners raising up the front end to "level" it. Since many now are now set with a forward rake to help achieve better mileage.
Re: Laser Pumped Phosphor Headlights [Re: SubLGT] #4551797
10/23/17 09:44 AM
10/23/17 09:44 AM
Oconomowoc Wi
Boss302fan Offline
Boss302fan  Offline
Oconomowoc Wi
I totally agree. LOL... Getting older sucks.
John P
Wisconsin
2018 Subaru Outback 3.6R Limited
2006 GS 430
2006 Lexus LS 430
1990 Jaguar XJS V12
2011 Hyundai Santa Fe V6
Other fun cars
Re: Laser Pumped Phosphor Headlights [Re: Garak] #4552002
10/23/17 01:39 PM
10/23/17 01:39 PM
DFW
DBMaster Offline
DBMaster  Offline
DFW
Originally Posted By: Garak
...Now, everyone's headlights are faded to heck, and failures cost a fortune. Replacing the headlight assembly for my G37 would cost more than my F-150 is worth...
I actually think this may be one of the reasons I keep seeing people driving with high beams continuously on. If the lenses are cloudy enough it might take high beam just for the driver to have adequate lighting. That still means whatever light is making it through the lenses will be shooting too high and causing issues for others. It's pretty tough to try to force someone to pay the kind of bucks it often takes to replace cloudy lights. I don't even know if that particular vehicle chacteristic is checked during vehicles inspections in this state.
Re: Laser Pumped Phosphor Headlights [Re: DBMaster] #4555865
10/27/17 04:53 AM
10/27/17 04:53 AM
I wonder the same here. Back in the day, you had a burned out sealed beam or a cracked one, game over. Now? I couldn't begin to guess. It's certainly not reasonable to ask someone to spend $1000 to bring headlights back to new condition on a ten year old car, when I can do it on my F-150 for probably under $20. I could have brand new headlights on that every six months and never notice the financial hit. I have a rock go through a headlight on the G37, and I'll be running to insurance screaming.
