I have a Kubota LA350A with a B2150 diesel engine in it. Trying to find out what the oil capacity is and filter number and came here to see if anyone knew anything about them. I'm unsure of the year on it, the sticker has long since faded away and there's no owners manual. Every google search I've done only gives me coolant and transmission capacity and says nothing about the engine oil. As I understand it, this model was made from 1988-1996 so I don't know if the oil capacity would've stated the same all that time or not.
What oil should it get and how many hours should it be changed? Is regular Rotella or synthetic Rotella okay? Thinking about going with the synthetic for use in wintertime to help it out with cold starts. Oil filter recommendations are welcome too as long as nobody says Purolator I'm open to suggestions there. Thank you in advance!
