Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
19 registered members (2015Corolla, Aero540T, Char Baby, bbhero, Bailes1992, anndel, 1 invisible), 820 guests, and 37 spiders.
Topics295,007
Posts4,925,889
Members66,664
Most Online2,553
Oct 27th, 2018
6.5" Pads on Porter Cable 7424XP? #4521198
09/20/17 10:57 AM
09/20/17 10:57 AM
NJ
gofast182 Offline OP
NJ
I recently did an order with Autogeek and got some new pads. I ordered 6.5" pads by mistake and was wondering if anyone successfully uses them with a 7424? They're big enough against the backing plate that I'm not sure the entire pad will be effective due to lack of pressure/support. I think it would be OK with a LSP but not polish. Thoughts? Thanks!
2006 S2000 - Berlina Black - PU 10w30, PCX-004
2017 340i xDrive - Black Sapphire - Dlr Fill, 114...898
2011 MDX Tech - Aspen White - Dlr Fill, PLM-A01
Re: 6.5" Pads on Porter Cable 7424XP? [Re: gofast182] #4521258
09/20/17 11:52 AM
09/20/17 11:52 AM
Louisville, Ky.
navseawelder Offline
Louisville, Ky.
I use them all the time.
Re: 6.5" Pads on Porter Cable 7424XP? [Re: gofast182] #4521339
09/20/17 01:02 PM
09/20/17 01:02 PM
Tampa, Florida
flanso Offline
flanso  Offline
Tampa, Florida
The larger pad affords the finish additional protection from the backing plate especially when working on curved sections. IIRC, the Porter-Cable uses different counterweights for 5 inch diameter pads than 6/6.5 inch.
Re: 6.5" Pads on Porter Cable 7424XP? [Re: gofast182] #4521351
09/20/17 01:10 PM
09/20/17 01:10 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
You can try it on a little 2x2 area and see how it does. I think you might be ok since you probably only have micro-scratches to deal with knowing you.
Re: 6.5" Pads on Porter Cable 7424XP? [Re: gofast182] #4521470
09/20/17 03:57 PM
09/20/17 03:57 PM
WI
HoosierJeeper Offline
WI
The only downsides I can think of are getting it into tight places and loosing some speed (I think?), but should be just fine.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: 6.5" Pads on Porter Cable 7424XP? [Re: gofast182] #4521514
09/20/17 05:05 PM
09/20/17 05:05 PM
NJ
NJ
Thanks, fellas. I'll keep these and if I want to switch back will do it in a year or so when it's time to order new pads (although I'm still using some pads that are way older than that).
Re: 6.5" Pads on Porter Cable 7424XP? [Re: gofast182] #4521695
09/20/17 08:42 PM
09/20/17 08:42 PM
The 805, CA.
FastEddie Offline
FastEddie  Offline
The 805, CA.
I pretty much use 5.5" pads on my Griots ROP, and w/ the right backing plate, you get the exact same protection from backing plate to pad as using 6.5" pads...just sayin. You can use 6.5" pads just fine, but I find you get way better correction using the smaller diameter pads with smaller machines.
Re: 6.5" Pads on Porter Cable 7424XP? [Re: gofast182] #4521749
09/20/17 09:41 PM
09/20/17 09:41 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Just try it. The PC is more of a wax spreader, imo, I actually bought a smaller backing plate and took mine down in size.
Re: 6.5" Pads on Porter Cable 7424XP? [Re: gofast182] #4522052
09/21/17 08:36 AM
09/21/17 08:36 AM
Rochelle Park, NJ
nolesfan Offline
nolesfan  Offline
Rochelle Park, NJ
I'd try it and see. You'll get more coverage but I don't know that the PC will have enough juice to correct as quickly with the larger pad. Again, try and see how you like it.
2013.5 VW GLI
2013 Nissan Xterra Pro-4X
