Break in filter cut open/ Filtermag
by UncleDave
06/23/18 10:36 AM
Changed coil pack, now throwing cat code
by llmercll
06/23/18 10:36 AM
07 V6 Mustang oil leak.
by aquariuscsm
06/23/18 10:33 AM
Windows 10 Update, version 1803
by Sayjac
06/23/18 09:55 AM
Super Tech Euro Spec Synthetic
by Snagglefoot
06/23/18 09:48 AM
Super Tech Conventional 15w40 HDEO. CK-4/SN
by Snagglefoot
06/23/18 09:38 AM
1 gallon jug of Sta-bil for $7 at Rural King
by classic70
06/23/18 09:34 AM
Anger on BITOG
by Gebo
06/23/18 08:55 AM
2010 Acura MDX w/ 3.7 lire oil consumption issue
by Varbill
06/23/18 08:45 AM
Surprising oil filter service interval.
by jakewells
06/23/18 08:12 AM
World Population
by CourierDriver
06/23/18 08:11 AM
SBC Finned Aluminum Dress Up Kit $32
by hatt
06/23/18 07:35 AM
Meguiars
by dslofti
06/23/18 07:20 AM
Roller Bearing Setup For Dillon Shellplate
by billt460
06/23/18 05:59 AM
Omnia - the band
by Shannow
06/23/18 02:58 AM
Guest's devices cannot connect to my WiFi
by boulderdentist
06/23/18 12:54 AM
Battery stuck in flashlight.
by Chris142
06/22/18 11:53 PM
Must read for everyone watching their diet
by JLTD
06/22/18 11:28 PM
2014 Mazda5 Valvoline Synpower 0W-20 7500 miles
by PWMDMD
06/22/18 10:54 PM
VOA Ravenol ECS 0W-20
by PWMDMD
06/22/18 10:47 PM
azzid0906, OilGeek91, DRancher, Newuser, Varbill
65299 Registered Users
85 registered (4WD, 2002 Maxima SE, Atesz792, ArrestMeRedZ, aquariuscsm, advocate, 11 invisible), 1668 Guests and 28 Spiders online.
65299 Members
67 Forums
285845 Topics
#4520793 - 09/19/17 11:09 PM Oil for high mileage Nissan Pathfinder
AdamZ Offline
Loc: Ontario, Canada
I have a 1994 Nissan Pathfinder that I've owned for over 10 years. It currently has 447,000km (275~k miles) on the original motor. But recently I've noticed on trips through hilly areas where I have to gear down and rev the motor high to maintain speed, it will use oil. Not a lot, but 1/2 to 1 quart every 1500km deepening on the load. I've gotten used to just slowing down and it is fine, just like my normal city driving. I know it's probably just wear, but I'm wondering if I should step up the oil viscosity? Still running the OE spec'd 5w30, usually Pennzoil. I do all my own work but I am by no means an oil expert. All gaskets have been replaced at some point and there are no leaks, so I don't think high mileage oil will help, right? And no I won't put lucas in it! lol
94 Nissan Pathfinder 443k km M1 0w40
95 Nissan Pathfinder 180k km PYB 5w30
02 Nissan Xterra SC 170k km M1 5w30
04 VW Golf 2.0 240k km PPE 5w40
#4520809 - 09/19/17 11:46 PM Re: Oil for high mileage Nissan Pathfinder [Re: AdamZ]
oil_film_movies Offline
Loc: MN
High mileage oil will help keep ageing seals flexible so they won't begin to look. If those seals are older than 6 years and/or 80,000 miles, then you really should be using a High Mileage Oil. 5w30 is fine. Valvoline MaxLife would be my pick.
#4520861 - 09/20/17 01:40 AM Re: Oil for high mileage Nissan Pathfinder [Re: AdamZ]
FermeLaPorte Offline
Loc: Texas (south)
I would use high mileage 10w30 or Chevron Delo 10w30, fam
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
#4520918 - 09/20/17 05:21 AM Re: Oil for high mileage Nissan Pathfinder [Re: AdamZ]
JC1 Offline
Loc: Oshawa, Ontario Canada
+1 on the maxlife.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Wix Filter
1997 Honda Civic CX 5w-30 PPPP/Mahle Filter
#4521249 - 09/20/17 12:44 PM Re: Oil for high mileage Nissan Pathfinder [Re: AdamZ]
SirTanon Offline
Loc: Phoenix, Arizona - USA
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 257,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 55,000mi
#4521370 - 09/20/17 02:28 PM Re: Oil for high mileage Nissan Pathfinder [Re: AdamZ]
Spector Offline
Loc: Chattanooga, TN
Looks like time to try the HM oils and see if they make a difference.
#4521447 - 09/20/17 04:25 PM Re: Oil for high mileage Nissan Pathfinder [Re: oil_film_movies]
AdamZ Offline
They are quite new, I changed the oil pan gasket in the spring. And the rear main seal 2 years ago. Camshaft/front crank was done at last timing belt interval, as were the valve cover gaskets. About 4 years. Nothing leaks at all externally.
I will try and find some maxlife, I wish Canadian tire carried Valvoline. Walmart here seems to be a [censored] shoot as to whether it is in stock. I haven't seen chevron here either.
I sent off an oil analysis from the last change and I'm really curious as to the results. Will certainly post here!
Thank you everyone for your input. Love this site.
#4521499 - 09/20/17 05:37 PM Re: Oil for high mileage Nissan Pathfinder [Re: AdamZ]
Loc: MN
High mileage oil will help keep ageing seals flexible so they won't begin to leak. If those seals are older than 6 years and/or 80,000 miles, then you really should be using a High Mileage Oil. 5w30 is fine. Valvoline MaxLife would be my pick.
Those seals are so new, a High Mileage oil is not necessary. It won't hurt, but a normal oil is all you need. On an older vehicle like that, I'd try one of the 0w40 (very stout) oils on the shelf at walmart for about $25 per 5-quart jug. Any 0w40 you see will do great. It could slow down or halt the oil usage, and you can leave that stuff in for a year or 10k miles at a time, its that good.
#4521503 - 09/20/17 05:44 PM Re: Oil for high mileage Nissan Pathfinder [Re: AdamZ]
PimTac Online   content
Loc: Soviet State of Washington
Dittos on the Valvoline Maxlife oil. It would be a good idea to check your pcv valve too.
2017 Mazda CX-5 Grand Touring
Valvoline Advanced Synthetic 0w20
Mobil 1 M108A EP filter
#4525625 - 09/25/17 09:56 AM Re: Oil for high mileage Nissan Pathfinder [Re: AdamZ]
AdamZ Offline
So the Walmart near me had no stock of the max life, so I went with the mobil 1 0w40. I also replaced the PCV valve. I think the one in there was the original, it had the Nissan logo on it! Used an aftermarket which makes me weary, hopefully it is fine.
I also forgot to mention, I added an oil filter relocation kit. Since I have headers it is hard to squeeze the filter through there. Running the XG8A filter, oil capacity has gone from the stock 3.6L to almost 5L.
#4525628 - 09/25/17 10:01 AM Re: Oil for high mileage Nissan Pathfinder [Re: AdamZ]
SatinSilver Offline
Loc: OH
Hopefully made by a company you've at least heard of before like Fram, etc. Otherwise replace it again now or after a very short interval.
#4525809 - 09/25/17 01:52 PM Re: Oil for high mileage Nissan Pathfinder [Re: AdamZ]
AdamZ Offline
It was a Fram. Normally for stuff like this I always hit up the dealer. Surprisingly for a 23 year old vehicle they have a lot available.
