Back to Basics III
by MolaKule. 12/15/18 05:30 PM
Castrol Edge 0W40 vs. 5W40...Liqui Moly?
by TiGeo. 12/15/18 04:56 PM
Schumacher XCS15 voltage
by sweezy722. 12/15/18 04:19 PM
Solar battery tenders?
by slybunda. 12/15/18 04:10 PM
Bad Fuel Pressure Regulator.
by NICAT. 12/15/18 04:07 PM
Misfire = clogged cat
by Eric Smith. 12/15/18 04:00 PM
Cellphone Reliability
by Warstud. 12/15/18 03:29 PM
No email notification of replies anymore?
by atikovi. 12/15/18 03:07 PM
Crane EE 5301 Humidifier
by maverickfhs. 12/15/18 02:38 PM
I have sinned
by 901Memphis. 12/15/18 01:57 PM
Milwaukee m12 in vanhaus ratchet
by pda1122. 12/15/18 01:19 PM
Klein dikes
by Donald. 12/15/18 01:03 PM
Help Soldering 3.5mm mono microphone plug
by Brybo86. 12/15/18 01:02 PM
Small Trolling Motors
by wings&wheels. 12/15/18 12:49 PM
Toyota Corolla, good and bad?
by jongies3. 12/15/18 12:35 PM
Mixing oils
by bfleeman. 12/15/18 10:51 AM
Ebay 10% off Tech 15% off everything else*.
by demarpaint. 12/15/18 10:39 AM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
100 registered members (53' Stude, 69GTX, 71Chevyguy, 2004tdigls, 2003f7, 11 invisible), 1,930 guests, and 36 spiders.
Topics295,124
Posts4,928,126
Members66,688
Most Online2,553
Oct 27th, 2018
2011 Chevy Equinox 2.4L double UOA #4520446
09/19/17 03:20 PM
09/19/17 03:20 PM
Rockford, IL
euphoric85 Offline OP
Rockford, IL
Sent in the samples for my last two oil changes. I had a ringjob done at 120k miles as part of a recall for excess oil consumption, so was curious to see how the numbers would look. Unfortunately never did any analyses before the work.
First sample is Pennzoil Plat 5w-30, 2nd is Castrol Edge 5w-30
Re: 2011 Chevy Equinox 2.4L double UOA [Re: euphoric85] #4520504
09/19/17 04:25 PM
09/19/17 04:25 PM
Deep in the heart of Jersey
BigCahuna Offline
BigCahuna  Offline
I changed the oil in my wife's "11 Equinox with NAPA 5/30 wt Synthetic. And thought the oil filter design was cheezy. To me. it doesn't hold or contain anything. When I changed it, looks like anything that would be contained in a standard filter, drains back into the crankcase when you lift it out. I wonder if We'll get the same life out of it you did, before it needs a rebuild.,,,
Re: 2011 Chevy Equinox 2.4L double UOA [Re: BigCahuna] #4520562
09/19/17 05:31 PM
09/19/17 05:31 PM
Lexington, NC
tc1446 Offline
tc1446  Offline
Lexington, NC
That 2.4L Ecotec motor has been around for years and used by GM in a wide variety of cars from Malibu on down. Would have thought they had worked out any issues by 2012 when they upgraded to a 2.5L. Since this Is the first indications of problems that I've read about, I'd be interested in feedback from others who are familiar with this motor.
'13 Accord EX-L 2.4L (110K) M1 & FU
'00 Ford Ranger 4.0L {69K} M1 & FU
'18 Polaris Slingshot 2.4L GM (QS & Bosch Cart.)
'07 Kioti CK-30 (Delo & Wix)
Re: 2011 Chevy Equinox 2.4L double UOA [Re: euphoric85] #4520623
09/19/17 06:21 PM
09/19/17 06:21 PM
MN
oil_film_movies Offline
MN
Not sure why the moly was so high, at 151 ppm its way above what Castrol Edge has always used in the past (around 80 ppm). Maybe a formula change??? (Your assembly lube would have showed up on the previous oil sample, so its not from assembly lube.)
Viscosity dropped way too much, mostly due to fuel dilution. Some may be due to VII permanent shearing.
I'd suggest going to one of the great Walmart Castrol Edge black bottle 0w40 or any 0w40 you see on the shelf at Walmart (Pennzoil, Mobil1) because fuel dilution is a problem, and that will give you more viscosity reserve to spare. Your oil is currently getting too thin.
From the fuel dilution indications, those rings look like they are not sealing properly. Just a ring job without making sure the cylinders are circular and not slightly oval, means they aren't preventing blowby. Oil consumption is corrected, so the oil control rings and return holes were cleaned out anyway.
Nothing wrong with the cartridge oil filter design. The ADBV is built in to the housing, not the filter. It works.
Here is the XG9018 you should be using for maximum filtering performance:
Re: 2011 Chevy Equinox 2.4L double UOA [Re: euphoric85] #4520751
09/19/17 08:45 PM
09/19/17 08:45 PM
Iowa
Iowegian Offline
Iowegian  Offline
Iowa
GM now recommends 5k oci for your car.
I do like the fact that the fuel % went down on the second oil change. Maybe the new rings are really getting broken in? Or it's the castrol?
Might want to try pennzoil again to see if you have similar results? A 5k oci in the castrol would have produced even lesser fuel dilution.
I just had the pistons and rings replaced on my 2011 2.4l Equinox a month ago. Courtesy of GM. So thank you for your post!
2011 Equinox, 2.4l
2009 Sienna, 3.5l
Re: 2011 Chevy Equinox 2.4L double UOA [Re: Iowegian] #4520968
09/20/17 06:27 AM
09/20/17 06:27 AM
Rockford, IL
Rockford, IL
Yea the oil consumption warranty extension went to 120k, and I got it in just under the wire at 119 and some change! Got really lucky. I was burning through about double the amount they were looking for.
Re: 2011 Chevy Equinox 2.4L double UOA [Re: euphoric85] #4520977
09/20/17 06:39 AM
09/20/17 06:39 AM
Rockford, IL
Rockford, IL
I wanted to see what the metals would look like after that work, and how far I could reasonably stretch the OCI.
From other UOAs I've seen, IIRC my fuel dilution is actually pretty low for these GM DI motors. Some degree of it will always be present from what I gather. But yea I might try a w40 to see how its viscosity holds up. I'm thinking it would sheer down to a 30 pretty quick and hopefully stay in that grade through a 7500 OCI, which is about when the OLM hit 0%
Lesson learned though- I highly doubt I could pull off a 10k OCI on this motor
Re: 2011 Chevy Equinox 2.4L double UOA [Re: euphoric85] #4520980
09/20/17 06:47 AM
09/20/17 06:47 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Wow look at that iron count.
2004 Corolla 126813
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: 2011 Chevy Equinox 2.4L double UOA [Re: euphoric85] #4520997
09/20/17 07:09 AM
09/20/17 07:09 AM
DFW
JustN89 Offline
JustN89  Offline
DFW
I'm not sure that your second OCI was done with Castrol Edge. There's roughly double the amount of moly reading here and no titanium. At first I saw the moly and figured it was just an additive, but with the titanium missing, I'd say that this was some other brand.
Re: 2011 Chevy Equinox 2.4L double UOA [Re: JustN89] #4521007
09/20/17 07:24 AM
09/20/17 07:24 AM
Rockford, IL
Rockford, IL
You're right! [censored] I got the brand mixed up with my other vehicle fill.
The 2nd OCI here is a GM dealer fill. They claim to use Mobil1
Is there a way to edit the original post, despite the Edit button now being gone? Mods help a brother out! crazy
Re: 2011 Chevy Equinox 2.4L double UOA [Re: euphoric85] #4521076
09/20/17 08:41 AM
09/20/17 08:41 AM
MN
MN
You're right! I got the brand mixed up with my other vehicle fill.
Thats not Mobil1 either. Too much moly. Too much calcium too, and Mobil1 uses high magnesium detergents as well.
The moly level looks similar to what some conventional oils use, such as Pennz or Quaker conventional, but the boron levels are too low for those.
Re: 2011 Chevy Equinox 2.4L double UOA [Re: euphoric85] #4521087
09/20/17 09:02 AM
09/20/17 09:02 AM
DFW
JustN89 Offline
JustN89  Offline
DFW
Hmm.. I wouldn't say it's Mobil 1 either. It looks a lot like SOPUS product, but the Magnesium is way off. Well, sometimes things just remain a mystery. Look like it held up well, whatever it is, assuming the iron drops over the course of your next few OCIs.
Re: 2011 Chevy Equinox 2.4L double UOA [Re: euphoric85] #4521098
09/20/17 09:15 AM
09/20/17 09:15 AM
The Garden State
Whimsey Online content
Whimsey  Online Content
The Garden State
I don't think it's actually Mobil 1, more likely GM's oil formulated by Mobil/Exxon. My 7,000 mile OCI in our 2.3 EcoBoost Ford using Mobil 1 showed a Moly of 80 vs your 151, Boron was close but my Calcium was 1025, less than yours at around 1400 and my Magnesium was 544, vs your 400+++, not a big difference there. Also I believe your Zinc was higher, mine was 698. Look at the bright side you didn't have to add oil in the ~8,500 mi OCI so they've done "good".
Whimsey
Re: 2011 Chevy Equinox 2.4L double UOA [Re: euphoric85] #4521269
09/20/17 12:06 PM
09/20/17 12:06 PM
MN
MN
I don't think its AC-Delco (GM's own brand) either. Some of their formulas look like Valvoline (sodium high). Others look like Mobil1. None have this high moly.
This is a big deal because it appears the dealer told the customer it was the high-end full-synthetic when it was likely a conventional GroupII where they have to use extra moly to get it to pass GF-5 low friction requirements.
Re: 2011 Chevy Equinox 2.4L double UOA [Re: oil_film_movies] #4521442
09/20/17 03:23 PM
09/20/17 03:23 PM
DFW
JustN89 Offline
JustN89  Offline
DFW
Not sure how convinced I am that it's a conventional. While I agree that the moly makes it look like a conventional, I'd expect wear numbers and other signs of serious breakdown after nearly 9,000 miles on the oil if it were a conventional.
