Signal Oil Company radio advertising
by 21Rouge. 09/21/18 04:07 AM
Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
26 registered members (Ablebody, 53' Stude, earlyre, Duke, emod, Drosselmier, 3 invisible), 735 guests, and 37 spiders.
Topics290,746
Posts4,849,464
Members66,033
Most Online3,590
Jan 24th, 2017
Which grease? #4520411
09/19/17 03:50 PM
09/19/17 03:50 PM
VA
maverickfhs Offline OP
VA
I am going to put chain/sprocket set and wheels back together for my current motorcycle.
In manual it says yo use Lithium Soap base grease. I have 3 types of grease laying around, Super Tech Moly-Lithium and General purpose and then a tub of axle/bearing grease from Autozone.
Can I use either or? Or which one would be better?
Thanks for the help.
2006 Civic EX 202K/AT
2006 Acura TSX 180K/AT
Re: Which grease? [Re: maverickfhs] #4520435
09/19/17 04:11 PM
09/19/17 04:11 PM
USA
ArcticDriver Offline
USA
I would use either the axle/bearing since it likely has good water resistance or the Moly-Lithium.
But if you want to spend $10 then a tub of Bel-Ray Waterproof # 99540 is decent stuff and doubles for headsets and swingarm.
Multiple Diesel and Gasoline vehicles
Re: Which grease? [Re: maverickfhs] #4520438
09/19/17 04:13 PM
09/19/17 04:13 PM
VA
VA
Thanks, maybe I am overly thinking but between Moly-Lithium and Bearing grease, which would be better?
Re: Which grease? [Re: maverickfhs] #4520482
09/19/17 05:00 PM
09/19/17 05:00 PM
USA
USA
Not sure. I would probably choose wheel bearing grease but I have no hard evidence why.
Hopefully someone that actually knows these things will join in soon.
I like the Bel-Ray mentioned above but I service all my bearings regularly and so I think just about any grease would work in such intervals.
The good news is you only have 98 more times to think about it.
Re: Which grease? [Re: ArcticDriver] #4520485
09/19/17 05:02 PM
09/19/17 05:02 PM
VA
VA
LMAO
Re: Which grease? [Re: maverickfhs] #4520626
09/19/17 07:23 PM
09/19/17 07:23 PM
northwest pa
justintendo Offline
justintendo  Offline
northwest pa
the good thing about bel ray is its tendency to not really bleed at all..and its very water resistant. it would be a good choice for your head bearings. seems like all bikes like to seep oil from there if the grease bleeds. on any motorcycle i always pop the grease seals off, flush the new grease out and pack a good grease about 2/3rds full. some new bearings have next to no grease present. in the past i also used belray for this in my dirtbikes for water resistance. bearings last waaaay longer.
2013 escape 2.0 awd
2008 fusion 2.3 mtx
1996 f150 4.9 2wd mtx
1999 kaw zrx 1100
many husqvarnas
Re: Which grease? [Re: maverickfhs] #4561663
11/01/17 10:23 PM
11/01/17 10:23 PM
Ct. Usa
Bigbill Offline
Bigbill  Offline
Ct. Usa
I use a moly grease in most of my equipment and on my motorcycle steering neck, swing arm bearings and chains.
