Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
25 registered members (bmod305, Black_Thunder, Bullwinkle007, AnthemBassMan, bfleeman, 3 invisible), 474 guests, and 65 spiders.
Topics286,264
Posts4,905,497
Members67,589
Most Online2,967
Mar 10th, 2019
Shell 15W40 HTHS #4520251
09/19/17 12:19 PM
09/19/17 12:19 PM
FL USA
doolah02 Offline OP
doolah02  Offline OP
FL USA
Anyone know the HTHS for Shell T4 15W40 Oil?
Re: Shell 15W40 HTHS [Re: doolah02] #4520291
09/19/17 01:10 PM
09/19/17 01:10 PM
Balearic Islands , Spain
FordCapriDriver Offline
15W-40 means it's gotta be 3.7 or higher, it's somewhere in the 4.1 - 4.2 range if i remember correctly, which is about the normal for a 15W-40 HDEO.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Re: Shell 15W40 HTHS [Re: doolah02] #4520317
09/19/17 01:33 PM
09/19/17 01:33 PM
FL USA
doolah02 Offline OP
doolah02  Offline OP
FL USA
Thank you, it seems that most oil companies won't give HTHS specs for their oil.
Re: Shell 15W40 HTHS [Re: FordCapriDriver] #4520323
09/19/17 01:40 PM
09/19/17 01:40 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Is this the same for API certified oils?
ACEA has hths >3.7 for the 15w40....
Ocording to VOA subforum here....oils from over the pond all tend to have lower hths numbers...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Shell 15W40 HTHS [Re: doolah02] #4520339
09/19/17 01:58 PM
09/19/17 01:58 PM
FL USA
doolah02 Offline OP
doolah02  Offline OP
FL USA
I bought this oil for generator use, hope my generators like it.
Re: Shell 15W40 HTHS [Re: Kamele0N] #4520381
09/19/17 02:56 PM
09/19/17 02:56 PM
I'm quite sure? 3.5 for 0W,5W,10W-40 and 3.7 for 15W,20W,25W and SAE 40 correct?
Re: Shell 15W40 HTHS [Re: doolah02] #4520382
09/19/17 03:00 PM
09/19/17 03:00 PM
Ofcourse they don't.
We, those who know what HTHS among other things, are 0.1% of their customers, not even that probably, why disclose it if 99.9% of people don't even know what it is.
Re: Shell 15W40 HTHS [Re: doolah02] #4520470
09/19/17 04:46 PM
09/19/17 04:46 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Probably something like 4.0 to 4.3 cP
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Shell 15W40 HTHS [Re: doolah02] #4520521
09/19/17 05:50 PM
09/19/17 05:50 PM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
Your generator will love it.
Generators run at constant rpm or close, in consistent environment. Just about anything will be fine in there. If it's fine in a turbo charger diesel for 10,000 miles it's fine in a generator for 80-100 hours.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Shell 15W40 HTHS [Re: doolah02] #4525794
09/25/17 01:27 PM
09/25/17 01:27 PM
Canada
boraticus Offline
boraticus  Offline
Canada
Found these stats online. Unfortunately, many popular oils aren't on this list:
HTHS - High temperature High shear A relatively new oil test/specification, the oil is subjected to high temperature 150C and is mechanically sheared at 1 x 10^6 per second. A value of 2.8 or is considered the minumum for normal bearing wear. Here are some HTHS numbers on well known oils, the higher the number the more shear stable the oil; 4's and 5's are excellent numbers and demonstrate basestock quality e.g. Silkolene and Motul.
Mobil 1 0W40 HTHS 3.6
Castrol RS 10w-60 HTHS 3.7
Castrol RS 0w-40 HTHS 3.7
Silkolene PRO S 5w-40 HTHS 4.07
Motul 300V 10w-40 HTHS 4.19
Motul 300V 5w-40 HTHS 4.51
Redline 5w40 HTHS 4.6
Redline 10W40 HTHS 4.7
Mobil 1 15w-50 HTHS 5.11
Silkolene PRO S 10w-50 HTHS 5.11
Silkolene PRO R 15w-50 HTHS 5.23
Motul 300V 15w-50 HTHS 5.33
Redline 15W50 HTHS 5.8
