Walmart and Valvoline
by Bullwinkle007. 01/22/19 09:10 PM
Getting Our Kicks On Route 66
by 2015_PSD. 01/22/19 08:40 PM
Uploading a short film clip from an IPhone.
by Snagglefoot. 01/22/19 07:52 PM
Purolator L34631 (torn media)
by LDM. 01/22/19 07:51 PM
THIS close to getting a VDB today at TPA
by 14Accent. 01/22/19 07:48 PM
Supco Appliance Parts.
by George7941. 01/22/19 07:36 PM
Unusual Jury summons.
by Chris142. 01/22/19 06:31 PM
Vibration feeling after new tires installed?
by MONKEYMAN. 01/22/19 05:51 PM
Sudden Shake - ‘18 Accord
by Throt. 01/22/19 05:43 PM
05 Ford 500 Intake hole - melted
by Geauxtiger. 01/22/19 05:41 PM
How's K&N 1004 on Kia/Hyundai GDI
by SlavaB. 01/22/19 05:18 PM
more PSD woes with cold weather
by Donald. 01/22/19 05:10 PM
Can someone do a UOA on AmazonBasics oil?
by ThunderOne. 01/22/19 04:03 PM
Any analysis on the Mobil 1 0W-40 ESP Dexos 2?
by fnbrowning. 01/22/19 04:02 PM
Cat sick
by Eddie. 01/22/19 03:49 PM
Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
91 registered members (2015_PSD, Aero540T, AdditiveOCD, 77GrandPrix, 928, 2004tdigls, 8 invisible), 1,352 guests, and 42 spiders.
Topics297,006
Posts4,963,319
Members67,013
Most Online2,821
Jan 21st, 2019
RLI 5w30 6080 miles Mazdaspeed 3 2.3 #4520222
09/19/17 10:38 AM
09/19/17 10:38 AM
pa
jc1112 Offline OP
jc1112  Offline OP
pa
Here is an uoa and a voa on renewable lubricants 5w30 low ash.
The only additives are a fuel conditioner by Renewable lubricants called bio plus.
I believe that oxidation is naturally high in RLIs formulation.
However, I am a little concerned at how high the iron is.
Fuel dilution used to be 2.8 % and now is negligible.
Thoughts?
Comments In order to PROPERLY EVALUATE OXIDATION for synthetic oils, please provide the LUBRICANT MANUFACTURER, PRODUCT
NAME, and VISCOSITY GRADE. Base Number is MODERATELY LOW. As Base Number depletes, the ability to neutralize acids is
diminished. Iron is at a MODERATE LEVEL; IRON SOURCES in engines can be cylinder liners, iron pistons, hardened steel
camshafts, crankshafts, gears, hardened rocker arms, valve bridges,alloyed steel cam follower rollers, etc. We acknowledge
the FLUID INFORMATION was provided, however we were not able to validate it within our database or from the fluid
manufacturer. Please contact the Data Analysis Department to clarify the information. Thank you. Lubricant and filter change
acknowledged. Maintenance action indicated at time of submission (fluid/filter change , filtration, etc.) will have corrected the
issue this system is exhibiting. No further maintenance action is recommended at this time.
Wear Metals (ppm)
Contaminant
Metals (ppm) Multi-Source Metals (ppm) Additive Metals (ppm)
Sample # uoa voa
Iron 71 5
Chromium 1 2
Nickel 1
Aluminum 6 3
Copper 11
Silicon 13 4
Sodium 9 6
Antimony 413
Manganese 1
Boron 28
Magnesium 8 4
Calcium 2416 2831
Barium
Phosphorus 997 1260
Zinc 1243 1376
Lube Time 6080
mi
Unit Time 24080
mi
Lube Change Y
Lube
Added 0
gal
Filter Change Y
Fuel
Dilution % <1%
Vol
Soot .2
% Vol
Water <.1
% Vol
Viscosity 64.3
40C
cSt
Viscosity 10.4 10.5
100 C
cSt
Base
Number 2.39 11.2
mg
KOH/g
Oxidation 96
abs/cm
Nitration 17
abs/0.1
mm
Re: RLI 5w30 6080 miles Mazdaspeed 3 2.3 [Re: jc1112] #4520229
09/19/17 10:46 AM
09/19/17 10:46 AM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
Can you post the actual report? The format above is a little confusing.
Re: RLI 5w30 6080 miles Mazdaspeed 3 2.3 [Re: bigj_16] #4520237
09/19/17 10:53 AM
09/19/17 10:53 AM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
What he said. Iron 71.5 or 715?
2004 Corolla 128335
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74615
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: RLI 5w30 6080 miles Mazdaspeed 3 2.3 [Re: jc1112] #4520256
09/19/17 11:26 AM
09/19/17 11:26 AM
pa
jc1112 Offline OP
jc1112  Offline OP
pa
Re: RLI 5w30 6080 miles Mazdaspeed 3 2.3 [Re: jc1112] #4520259
09/19/17 11:32 AM
09/19/17 11:32 AM
Indiana
Phishin Offline
Phishin  Offline
Indiana
jc1112....
Why did you run the low ash formula? I'm going to buy 5 gallons of the full SAPS oil from RLI in 0w30 to run in my Accord.
2018 Chevy Silverado 3500HD 6.0L Gas: RLI 10w30
2010 Accord-LX K24: MaxLife 5w30 + Torco MPZ
2014 CR-V LX K24: M1 0w30
Re: RLI 5w30 6080 miles Mazdaspeed 3 2.3 [Re: jc1112] #4520260
09/19/17 11:34 AM
09/19/17 11:34 AM
pa
jc1112 Offline OP
jc1112  Offline OP
pa
Terry dyson recommended the low ash.
Not sure why. Due to the DI maybe?
Re: RLI 5w30 6080 miles Mazdaspeed 3 2.3 [Re: jc1112] #4520352
09/19/17 01:10 PM
09/19/17 01:10 PM
Florida
miami993 Offline
miami993  Offline
Florida
Are those UOA/VOA plus commentaries from Terry Dyson?
Re: RLI 5w30 6080 miles Mazdaspeed 3 2.3 [Re: jc1112] #4520511
09/19/17 04:34 PM
09/19/17 04:34 PM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
I love RLI, I have a ton of it and feel great using it. I buy it for about 5$ a quart.
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Re: RLI 5w30 6080 miles Mazdaspeed 3 2.3 [Re: jc1112] #4520563
09/19/17 05:31 PM
09/19/17 05:31 PM
PimTac Offline
PimTac  Offline
No lead levels?
Cannot see signatures any longer so it doesn’t matter.
Re: RLI 5w30 6080 miles Mazdaspeed 3 2.3 [Re: TheKracken] #4521002
09/20/17 07:17 AM
09/20/17 07:17 AM
Indiana
Phishin Offline
Phishin  Offline
Indiana
How you get it so cheap?
Re: RLI 5w30 6080 miles Mazdaspeed 3 2.3 [Re: jc1112] #4521128
09/20/17 09:47 AM
09/20/17 09:47 AM
KY
MCompact Offline
MCompact  Offline
KY
FYI, I ran a 2007 MS3 for 7 years and 158,000 miles on M1 5W-30 with an OCI of 5,000-8,000 miles. UOAs showed the engine to be in great shape.
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i M Sport
Son's
2009 328i
Buy what makes you smile...
Re: RLI 5w30 6080 miles Mazdaspeed 3 2.3 [Re: jc1112] #4523642
09/22/17 09:42 PM
09/22/17 09:42 PM
Chicago
danielLD Offline
danielLD  Offline
Chicago
low ash for the cats or you'll chew them up.
link to report didn't work.
Re: RLI 5w30 6080 miles Mazdaspeed 3 2.3 [Re: jc1112] #4523662
09/22/17 10:56 PM
09/22/17 10:56 PM
pa
jc1112 Offline OP
jc1112  Offline OP
pa
Re: RLI 5w30 6080 miles Mazdaspeed 3 2.3 [Re: jc1112] #4524662
09/24/17 08:51 AM
09/24/17 08:51 AM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
Lots of iron for 6k in a Mazda. Low TBN too.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: RLI 5w30 6080 miles Mazdaspeed 3 2.3 [Re: jc1112] #4531743
10/02/17 01:13 AM
10/02/17 01:13 AM
Chicago
danielLD Offline
danielLD  Offline
Chicago
woahhhh just saw this,
you have some serious issues that need addressing ASAP.
1. engine timing is seriously off but difficult to tell without water by KF. That is either the cams or the chain wearing big time.
2. you will want to have the timing chain checked and O2 sensors checked. It could be as little as a tensioner getting loose or some slack/stretch. I'd take this to a shop if you don't trust yourself evaluating it.
3. The pistons are straining again the cylinder walls, likely bad combustion dynamic as a result of timing.
4. This is not Terry's lab but are you under his supervision? I'd be placing a phone call to Terry first thing in the morning.
5. This is not something I would wait on, immediate action is required.
Your comment of "fuel dilution is negligible" is because they're estimating with FTIR. You need GC. Polaris should still have this sample on their back up racks they keep for retesting. Call them tomorrow and ask if they can add Karl Fischer(insist on KF) and fuel % by Gas Chromatography.
