One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
Walmart Tightening up Returns
by John_K
06/18/18 10:21 PM
flare nut wrench set
by spasm3
06/18/18 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
06/18/18 09:45 PM
How much is too much?
by Sealbilly
06/18/18 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
06/18/18 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
06/18/18 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
06/18/18 08:33 PM
PEAK Full Synthetic -- Anyone Try It ??
by johnnyz73
06/18/18 07:40 PM
Why high resale value on Jeeps if frames rust out?
by Vern_in_IL
06/18/18 06:48 PM
Wearever Silver Semi-Metallic Brake Pads- Break In
by ET16
06/18/18 06:37 PM
Where to Buy Motul Oil in Stores?
by Hot_Ajax
06/18/18 06:13 PM
2011 Chevy equinox overheating
by hardcore302
06/18/18 06:00 PM
Are my rotors warped?
by Dylan1303
06/18/18 05:44 PM
Ultimate Fast Finish on sale at CDN tire.
by irv
06/18/18 05:23 PM
96 Civic 5w20 Castrol GTX Ultraclean UOA
by researcher
06/18/18 04:52 PM
VOA Castrol Magnatec D1G2, 5w30
by researcher
06/18/18 04:38 PM
Unused dented silicone Fram PH8316 cut open
by slacktide_bitog
06/18/18 04:28 PM
Same grade with differing low start temps
by mjoekingz28
06/18/18 04:24 PM
Self defense
by Camprunner
06/18/18 03:13 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
41 registered (Atesz792, BigJakeChevy, AVB, bbhero, 2strokeNorthstar, Aero540T, 3 invisible), 983 Guests and 38 Spiders online.
65265 Members
67 Forums
285570 Topics
#4519936 - 09/19/17 01:15 AM New 2017 F-150 4x4 10 speed auto
Ammofirst Offline
Loc: Western usa
My Brother just purchased a 2017 F-150 4x4 3.5 ecoboost with the 10 speed Transmission. I know it's only been out a short time but does anyone have any insight on the best transmission fluid for this unit. (Just OEM?) Im not a ford guy but any recommendations for his Transfer case & Differentials as well ? I know GM full size trucks/suv's have a trans fluid temp gauge, what about ford ? He will be towing an 8500lb trailer & would like some added protection. Thanks
#4519960 - 09/19/17 02:21 AM Re: New 2017 F-150 4x4 10 speed auto [Re: Ammofirst]
tcp71 Offline
Loc: Alberta
Stick with the Ford Mercon ULV fluid. It is an ultra low viscosity fluid developed for this transmission. Even towing 8500lbs he won't need to change it before 50k miles. The newer trucks, (I have a 2016 Max Tow) use a 75w85 rear axle oil that is a departure from ford's previous 75w140 fluid. Probably for better EPA ratings. That might be the only place where he can upgrade, but not really required until he has at least 50k on it as well. Before he tows 8500lbs, make sure he has the payload rating to take the tongue weight. That and rear axle ratings. His tongue weight for anything except a boat should and will probably 10-13% of the trailer's weight to be stable. That can use up payload and axle capacity quickly.
His dash center screen has transmission fluid temperature option to be displayed. I forget exactly where it is,but it can be displayed.
Great choice, but I'm biased.
Edited by tcp71 (09/19/17 02:23 AM)
#4519993 - 09/19/17 06:00 AM Re: New 2017 F-150 4x4 10 speed auto [Re: Ammofirst]
2015_PSD Offline
Loc: SE Texas
Jim Allen (who has forgotten more about axles than any of us have ever known) says that nearly all of the wear that occurs in an axle happens during the first 10K miles and he changes his fluids early. If it were mine, I would dump the rear axle at about 10K and since he is towing, I would upgrade the viscosity back to 75W-140 which is what Ford had just a few years ago in that same axle. The front axle and transfer case can wait awhile (unless the 4x4 part is used frequently).
If 75W-140 is not desired, I would absolutely move to a 75W-110 which has the viscosity the upper range of 75W-90 had before the J306 tables were updated not so long ago. For fluid choices, I would use Amsoil Severe Gear which is arguably the best gear oil on the market today. Have a look at the UOAs from my 2010 FX4 and you can see the trending that happened regarding wear metals. The highest levels were very early and though the later runs had many more miles, less wear metals were created.
2018 MB AMG GLC43 3.0L Coupe - M1 0W-40/OEM
2018 MB C300 2.0L - M1 0W-40/OEM
2015 F-250 6.7L PS Diesel - Delo 5W-40/CQ Blue
2014 Explorer 3.5L Limited - M1 AFE 0W-20/FU
#4520015 - 09/19/17 06:48 AM Re: New 2017 F-150 4x4 10 speed auto [Re: Ammofirst]
09_GXP Offline
Loc: Indianapolis, IN
I would check the rear diff fluid ASAP. For my '15 I only was able to drain 1 qt when I pulled the cover but was able to refill with the near 3qt spec'd in the manual. I've heard of a few others on the F150 forums having the same issue. Redline is always my choice for diff fluid.
2017 Miata Global Cup Car #02 - Castol A3/B4 5w30 w/ OEM Fitler
2017 Miata RF - PP 0w20 w/ M1 Filter
2015 F-150 2.7L Ecoboost - PPPP 5w30 w/ MC
#4520108 - 09/19/17 08:57 AM Re: New 2017 F-150 4x4 10 speed auto [Re: Ammofirst]
MNgopher Offline
Loc: Lakeville, MN
OEM fluid in the transmission.
Truck should have both a needle type guage on the dash showing the transmission temp, and the actual transmission temp is available in the many screen selections. If he has not had a ford transmission like this, he should be prepared to see higher transmssion temps than he is used to seeing (190+), but they are perfectly normal (assuming the 10 speed runs at the same temps - Ford has been running these temps in earlier units like the 6R80 going back 10 years in various platforms, and the transmissions have a good reputation).
#4520249 - 09/19/17 12:14 PM Re: New 2017 F-150 4x4 10 speed auto [Re: 09_GXP]
Ethan1 Offline
Loc: 'murica
That's messed up crzy
#4520376 - 09/19/17 02:45 PM Re: New 2017 F-150 4x4 10 speed auto [Re: Ammofirst]
WyrTwister Offline
Loc: Texas
I would document it being low on factory fill . In case you have problems latter on .
I agree , very bad deal . :-(
Best of luck to you , :-)
Wyr
God bless
#4520810 - 09/19/17 11:49 PM Re: New 2017 F-150 4x4 10 speed auto [Re: Ammofirst]
panthermike Offline
Loc: Phoenix, AZ
Nothing wrong with the LV. I like LG red as well, although you'll get a lot opposed to that. For diff I would at least go 75w110( Redline or Amsoil). I think the t-case is LV as well not positive though. Your brother bought a nice truck!
'15 Lexus RX350; PP 0w20, 33K
'10 Impala; Frankenbrew, MG 114K
'70 F100; Valvoline 15w40/Biotech, Motorcraft
#4520872 - 09/20/17 02:04 AM Re: New 2017 F-150 4x4 10 speed auto [Re: Ammofirst]
Ammofirst Offline
Loc: Western usa
I'd never heard the theory that the majority of wear occurs in the first 10k miles (Axle gears). I've been doing mine about every 40-50k. (Front & back). As a side note I've noticed (on traditional trucks & SUV's) the fluid in the front differential always looks much worse. I believe this is due to lack of use. Probably a good idea (when safe) to engage that front differential more often. For City / suburban dwellers with little snow or nearby trails, it makes it tough.
#4521075 - 09/20/17 09:41 AM Re: New 2017 F-150 4x4 10 speed auto [Re: Ammofirst]
2015_PSD Offline
Loc: SE Texas
Neither had I until I collaborated with Jim Allen, but you can easily see it happening in my UOAs of my rear axle. Here is a snapshot:
Code:
Truck Mileage:	149,289	69,600	13,300
Oil Mileage:	79,689	56,300	13,300
Iron:		120	148	429
Look at the oil mileage versus the iron. The last UOA had nearly 6x the mileage but produced 3.5x less iron versus the first UOA.
#4521084 - 09/20/17 09:57 AM Re: New 2017 F-150 4x4 10 speed auto [Re: Ammofirst]
KrisZ Online   happy
Loc: Toronto, Canada
I also follow Jim Allen's advice. If one understands machining and surface finish processes, it makes perfect sense.
2015 Dodge Grand Caravan-21k miles.
2006 Mazda 3-155k miles
#4521531 - 09/20/17 06:24 PM Re: New 2017 F-150 4x4 10 speed auto [Re: Ammofirst]
WyrTwister Offline
Loc: Texas
Yes first few thousand miles all the burrs and rough spots get " worn in " .
Good reason to dump the initial fill of engine , transmission & differential ( or trans-axle ) pretty " early " .
Get rid of those metal particles that are floating around .
Best Wishes , :-)
Wyr
God bless
