WoO driver Jason Johnson injured
by bdcardinal
06/24/18 01:08 AM
Plastic burning smell when WOT
by Jaha24k
06/24/18 12:57 AM
Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
06/24/18 12:00 AM
Ruger LCP .380
by PW01
06/23/18 11:24 PM
Launching boat with stick shift
by troutfisher
06/23/18 11:22 PM
Free oil
by Spitter
06/23/18 10:53 PM
Porsche Panamera buying advice
by CharlieBauer
06/23/18 10:04 PM
RC cars
by red7404
06/23/18 09:36 PM
Any Good 4K Movies ?
by Warstud
06/23/18 09:06 PM
Gray on Oil Dipstick?
by chinee
06/23/18 08:41 PM
Clear plastic scratch remover?
by Quattro Pete
06/23/18 08:15 PM
Parking wars show.
by Chris142
06/23/18 08:15 PM
set for years
by 93cruiser
06/23/18 08:07 PM
Looking to replace 2005 Sienna with SUV
by i6pwr
06/23/18 07:26 PM
Trying to fix chainsaw
by turtlevette
06/23/18 06:48 PM
tire rotation
by marine65
06/23/18 06:48 PM
Reese hitch $30 Walmart YMMV
by pda1122
06/23/18 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
06/23/18 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
06/23/18 06:00 PM
New belt squeal cause damage to belt?
by pda1122
06/23/18 05:33 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
15 registered (billt460, 4WD, chainblu, AMC, Char Baby, David1), 784 Guests and 37 Spiders online.
65303 Members
67 Forums
285889 Topics
Page 1 of 2 1 2 >
#4519828 - 09/18/17 10:13 PM My 08 Mazda6; Inside cabin whining noise
miden851 Offline
Loc: GA
I had developed two minor problems recently;
One is body vibration thru my car that's coming perhaps from the engine bay; it is a very hard to point out th source because once you get outside you cannot hear what's the issue; I can hear it but someone else I doubt it when I turn the engine off there is like rattle/vibrate sound that comes from the left side of engine bay; it lasts like less 1s. One really need closely to listen in order to hear it;
Second one and that is more of concern to me is a whining/buzzing sound that reminds me of a current throughout the cabin; when you play with lights or door/window switches it change its sound; when you hold the parking hand in hand you can feel like a current/vibration in it; again once you stepped outside you barely can hear it; my initial thought is that could be fuel pump, but the car still cranks up at first or have a performance gas efficiency not changer to my knowledge.
All original parts on it to this day. Help
I Thank You
2008 Mazda6i GT; @195K miles
2016 Honda CR-V EX-L; @29K miles
#4519851 - 09/18/17 10:46 PM Re: My 08 Mazda6; Inside cabin whining noise [Re: miden851]
SF0059 Offline
Loc: Lynchburg, VA, USA
For your first problem, I can almost guarantee that the rattle is your upper motor mount. They are fluid filled and they will split and spill the fluid. Look on the wheel well underneath the mount to see if there is staining from the leaking fluid. The symptoms sound very much like the mount.
As for the whining noise... I have no clue there.
2014 Honda Odyssey EX-L/RES: 54K mi, M1 0w-40 & FU, VCMuzzler V2
2017 Mazda 6 Touring 6MT: 22k mi, M1 AFE 0w20, OEM Filter
#4520060 - 09/19/17 07:44 AM Re: My 08 Mazda6; Inside cabin whining noise [Re: miden851]
TinyVoices Offline
Loc: Vienna, VA
Definitely upper motor mount. Super common issue with these cars. It's fluid filled. Any shop can do this for an hour labor plus parts. I had a mazdaspeed6 and I had 2 upper motor mounts fail (same mount design but different engine) in 2 years before going to aftermarket performance mount.
1993 Toyota MR2 Hardtop N/A - 157k miles - Valvoline Max Life 5w30
2006 Toyota Matrix XR AWD (Fiancee) - 126k miles - Valvoline Max Life 5w30
#4520104 - 09/19/17 08:50 AM Re: My 08 Mazda6; Inside cabin whining noise [Re: miden851]
miden851 Offline
Loc: GA
Thanks for your input all good people!
I was wondering what is the easiest way to check for engine mounts, especially the one with fluid, perhaps to use a floor jack and lift a engine somewhat up and see if there is change in sound
Also what is the easiest way to test fuel pump, something that I can do before I take the next step
#4520155 - 09/19/17 09:53 AM Re: My 08 Mazda6; Inside cabin whining noise [Re: miden851]
HerrStig Offline
Loc: Boston, MA
HVAC blower bearings.
#4520166 - 09/19/17 10:08 AM Re: My 08 Mazda6; Inside cabin whining noise [Re: SF0059]
oil_film_movies Offline
Loc: MN
Solution: Let your mother-in-law out of the back seat, or trunk, whatever.
#4520218 - 09/19/17 11:35 AM Re: My 08 Mazda6; Inside cabin whining noise [Re: miden851]
miden851 Offline
Loc: GA
a HVAC Blower issue seems so easy to spot it
#4520267 - 09/19/17 12:42 PM Re: My 08 Mazda6; Inside cabin whining noise [Re: miden851]
miden851 Offline
Loc: GA
Guess what... It just died on me cry luckily on my place of work
It cranks but it wont start
#4520282 - 09/19/17 01:00 PM Re: My 08 Mazda6; Inside cabin whining noise [Re: miden851]
Chester11 Offline
Loc: PA
I was going to say the trans mount might be shot (it's on top of the trans, driver's side). But it sounds like you have bigger problems now.
#4520341 - 09/19/17 02:00 PM Re: My 08 Mazda6; Inside cabin whining noise [Re: miden851]
miden851 Offline
Loc: GA
Thank You Guys!
I am buying the parts today $300
tomorrow Ill be wrenching it
Motor mountains will be next on my to do list
#4520688 - 09/19/17 08:28 PM Re: My 08 Mazda6; Inside cabin whining noise [Re: miden851]
miden851 Offline
Loc: GA
Here is an update;
After the job today, the car started after several tries sequentially, so I got lucky and I got it to my home; now I got an Delphi fuel pump at AutoZone and I got the tool to untie the pump; I took the seat cushion out exposing the pump position; I tried to start the car but in vain; that sound when you give power by turning the key (like valve opening) is now missing, so my question is whether is this a pump related or the relay related; of course no whining sound while car is down sound until you started it
Again thanks for all your suggestions!
#4521068 - 09/20/17 09:36 AM Re: My 08 Mazda6; Inside cabin whining noise [Re: miden851]
miden851 Offline
Loc: GA
I have parts ready, so I was wondering how difficult is to the job, on a scale 1-10, and what I should watch for in the process, please
I Thank You
#4521965 - 09/21/17 08:08 AM Re: My 08 Mazda6; Inside cabin whining noise [Re: miden851]
miden851 Offline
Loc: GA
Job's done and I got my freedom back again grin
#4522273 - 09/21/17 02:14 PM Re: My 08 Mazda6; Inside cabin whining noise [Re: miden851]
Chester11 Offline
Loc: PA
so it was the pump? it looks like the cover is sealed with silicone? or am I seeing a reflection?
#4522967 - 09/22/17 08:44 AM Re: My 08 Mazda6; Inside cabin whining noise [Re: miden851]
miden851 Offline
Loc: GA
Yeah it was the pump, on the way out; I'd replace it now then be stranded on the road next; no silicone, just a reflection from gas;
everything went smoothly except for the screws that hold the flange and the pump secured; they were rusty and very soft made so I needed to take them out with a drilling bit and extractor; I went to home depot and got stainless steel screws this time...
Page 1 of 2 1 2 >
