ATF Filter oem vs aftermarket any differences?
by 97prizm. 12/18/18 03:50 PM
Depth-Fiberglass Filter Media.
by Al. 12/18/18 03:43 PM
O2 sensor B1S1 no voltage??
by David1. 12/18/18 03:43 PM
Brilliant payback for package thieves
by SirTanon. 12/18/18 01:22 PM
Calling all Ford Owners
by dogememe. 12/18/18 01:01 PM
2003 Ford CVPI, 86kmi, 6kmi on Edge HM Ti 5W30
by Colt45ws. 12/18/18 12:35 PM
2017 Kia Sportage recall notice
by SlavaB. 12/18/18 12:26 PM
My VW Service Experience
by Delta. 12/18/18 11:36 AM
Nissan high idle, P0507
by LeakySeals. 12/18/18 11:23 AM
Should i go for even thinner fluid ?
by NICAT. 12/18/18 11:06 AM
Viscosity question
by dbierman. 12/18/18 10:50 AM
48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
108 registered members (28oz, 97prizm, A310, Al, AdditiveOCD, 11 invisible), 2,120 guests, and 40 spiders.
Topics295,226
Posts4,930,484
Members66,716
Most Online2,553
Oct 27th, 2018
2008 CR-V, Which Oil?? #4519730
09/18/17 07:17 PM
09/18/17 07:17 PM
Southern VA
klt1986 Offline OP
klt1986  Offline OP
Southern VA
I have a 2008 Hpnds CR-V with about 138k on the odometer. Has had a steady diet of mainly M1 EP 5w-20 and a couple changes of Castrol Syntec with Titanium. I have followed the maintenance minder the whole life and it always comes on between 9,800 and 10,300 miles. Usually add between 1/2 quart and 1 quart in that 10k mile oil change. Think this vehicle would benefit from a high mileage oil or should I just stick with the M1 EP?
Wife: 08 Honda CR-V 4WD, M1 5W-20
Me: 11 Toyota Tundra DC 4WD 5.7L, PP 5W-30
Me Work: 06 Ford Explorer 4WD 4.0L, Pennzoil 5W-30
Son: 14 Toyota Corolla S, M1 AFE 0W-20
Re: 2008 CR-V, Which Oil?? [Re: klt1986] #4519749
09/18/17 07:34 PM
09/18/17 07:34 PM
PimTac Offline
PimTac  Offline
It really depends on if the engine is leaking or burning the oil. If leaking, where does it leak from? If burning, HM oil will make no difference.
Cannot see signatures any longer so it doesn’t matter.
Re: 2008 CR-V, Which Oil?? [Re: klt1986] #4519758
09/18/17 07:40 PM
09/18/17 07:40 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
I think that staying with the Mobil 1 extended performance could be fine. Like PimTac said questions are is it burning oil or leaking it?? Also do you drive short trips mostly or mostly highway miles or a combination of both. If it is burning oil then maybe going up to Mobil 1 extended Performance 5w30 maybe a good idea. Wouldn't lose hardly any gas mileage.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: 2008 CR-V, Which Oil?? [Re: klt1986] #4520006
09/19/17 05:42 AM
09/19/17 05:42 AM
Southern VA
klt1986 Offline OP
klt1986  Offline OP
Southern VA
There are not any visible leaks around the outside of the engine, the concrete driveway or my carport. I guess the engine is consuming oil but my thoughts are 1/2 quart every 5k is not bad at all. I had thought about trying a 5w-30 or possibly the M1 AFE 0w-30.
Re: 2008 CR-V, Which Oil?? [Re: klt1986] #4520030
09/19/17 06:13 AM
09/19/17 06:13 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
Step it up to M1 EP 5W-30.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: 2008 CR-V, Which Oil?? [Re: klt1986] #4520033
09/19/17 06:15 AM
09/19/17 06:15 AM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
Ours consumes about the same even with 5W20 Maxlife.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: 2008 CR-V, Which Oil?? [Re: klt1986] #4520036
09/19/17 06:19 AM
09/19/17 06:19 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Have you ever checked your PCV valve?
Or is the dealership supposed to be doing that? The reason I ask is I just changed over to QSUD 5w-30 and in the first 421 miles the oil dropped 4 Oz. I check my PCV man it was unbelievably grimy. The car had just been in for service 8K earlier so I changed it out. Now 600 miles later the oil has had no more perceptible drop. Usually my oil drop for a whole OCI is about 4 Oz.
2004 Corolla 126884
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: 2008 CR-V, Which Oil?? [Re: klt1986] #4520040
09/19/17 06:21 AM
09/19/17 06:21 AM
Nor Cal
Swifty Offline
Swifty  Offline
Nor Cal
Going up a grade may help cut down your consumption rate and the K24 won't mind it one bit, no ill effects. HM oil you will get plenty of answers for and against. You can always try HM oil for an OCI and see if it makes a difference. Might help answer your own question.
2013 Civic SI Sedan Amsoil 5/30 ASL Fram Ultra 83k miles
2018 Acura RDX Tech, VCM disabled, oil TBD...
2003 Toyota Highlander M1 10/30HM Fram Ultra Filter (wife's) 167k miles...retired
Re: 2008 CR-V, Which Oil?? [Re: klt1986] #4520204
09/19/17 10:19 AM
09/19/17 10:19 AM
Texas
FZ1 Offline
FZ1  Offline
Texas
Low level of burn. The engine will last indefinitely. Just stay with the 5w-20 EP.
Re: 2008 CR-V, Which Oil?? [Re: klt1986] #4520304
09/19/17 12:21 PM
09/19/17 12:21 PM
Dallas,Tx USA
aquariuscsm Online content
aquariuscsm  Online Content
Dallas,Tx USA
1/2 a quart in 10,000 miles is nothing. Keep using what you're using,the M1 20wt.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum 5W20
Re: 2008 CR-V, Which Oil?? [Re: klt1986] #4520573
09/19/17 05:40 PM
09/19/17 05:40 PM
West Michigan
Balrog006 Offline
Balrog006  Offline
West Michigan
I experience the same in my '08 CRV now that I've rolled up to 250 K miles. Previously I'd replace the PCV and get 75-100k before I saw a drop on the dipstick in the same 10k OCI you see. I replaced it last at 225k and it helped for 2 OCI's or so but now the level drops 1/2-3/4 qt, at this point I'll just deal with it and replace the PCV again just past 300k to say I did it.
At 250k or beyond if the K24 uses a little oil within its ~10k OCI, I'm ok with that.
19 Ridgeline RTL-E >1K factory fill, A01
08 CRV 275K+ VSyn w/ML, A01
04 JD L130 740H, Mobil S 5w30
13 JD 2032r 325H, JD Plus 50 ii 15w40
M1Delvac 5w40 in OPE
Re: 2008 CR-V, Which Oil?? [Re: Balrog006] #4520598
09/19/17 05:58 PM
09/19/17 05:58 PM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
Off topic have you ever done a valve adjustment on your K24?
Re: 2008 CR-V, Which Oil?? [Re: klt1986] #4520690
09/19/17 07:29 PM
09/19/17 07:29 PM
Southern VA
klt1986 Offline OP
klt1986  Offline OP
Southern VA
Just changed the oil in the CR-V this afternoon and decided to stick with M1 EP 5w-20. I'm going to take a look at the PCV valve this weekend.
Re: 2008 CR-V, Which Oil?? [Re: ARB1977] #4526231
09/25/17 08:24 PM
09/25/17 08:24 PM
West Michigan
Balrog006 Offline
Balrog006  Offline
West Michigan
No, I'm not that much of a DIY'er and not sure at this point it would be worth doing...
Re: 2008 CR-V, Which Oil?? [Re: klt1986] #4526232
09/25/17 08:25 PM
09/25/17 08:25 PM
West Michigan
Balrog006 Offline
Balrog006  Offline
West Michigan
Buy a genuine Honda part, aftermarket ones are cheap and prone to failure.
It's a ~5 minute job from opening the part bag to closing the hood-done.
