Separating toddlers from their parents?
by fdcg27
06/19/18 08:50 PM
gm 8.6 truetrac
by Spitter
06/19/18 08:45 PM
New addition to my garage: 2000 Corvette FRC
by MrHorspwer
06/19/18 08:34 PM
Rockauto 5% off
by Spitter
06/19/18 08:32 PM
fumoto oil valve
by Santo
06/19/18 08:19 PM
Grand solar minimum...
by ridgerunner
06/19/18 07:57 PM
Pentofrost coolant $10 Autozone
by PD001
06/19/18 07:49 PM
The things you find cleaning Garage 30+ btls slob
by digger327
06/19/18 07:20 PM
Castrol GTX Magantec 0w20 - 6 pack $21.99 - Amazon
by 04SE
06/19/18 07:07 PM
Havoline Pro DS 5w20 $3.15/quart - Amazon
by 04SE
06/19/18 07:06 PM
Needing New Dipstick
by Geauxtiger
06/19/18 05:11 PM
'98 Mercedes E300TD Rotella T5 10W-30 5k miles
by KenO
06/19/18 04:35 PM
Premium guard oil filters
by Jaha24k
06/19/18 04:09 PM
76 super motor oil- synthetic blend 5w-30
by Jaha24k
06/19/18 04:07 PM
Who makes the Mopar 5038041AA filter?
by Quattro Pete
06/19/18 03:55 PM
Ruger Mini-14, yay or nay?
by 28oz
06/19/18 03:51 PM
USPS long long delivery to BlackStone Labs
by Pajero
06/19/18 02:58 PM
House A.c. vent leaking water
by motor_oil_madman
06/19/18 02:55 PM
"synthetic" gear oil and LS additive?
by nthach
06/19/18 01:54 PM
Supertech wix ST8 5514 miles
by jakewells
06/19/18 01:38 PM
Santo, aligoodn, memyself, MichiganKid419, kaphouston
65273 Registered Users
104 registered (addyguy, 2002 Maxima SE, AITG, Aero540T, 2015_PSD, 9050lx, 15 invisible), 1582 Guests and 30 Spiders online.
65273 Members
67 Forums
285621 Topics
Page 1 of 2 1 2 >
#4519437 - 09/18/17 01:41 PM Mixing mobil 1high mileage with rotella
chevytherealdeal Offline
Loc: ohio
Can i mix rotella t4 and mobil 1 high mileage to make my own syn blend for better cold starts this winter? 94 f150 302 165000 miles. Or will the additives not blend?
#4519442 - 09/18/17 01:46 PM Re: Mixing mobil 1high mileage with rotella [Re: chevytherealdeal]
JohnnyJohnson Offline
Loc: Wet side WA
Why would you even want to bother when you can get Mobil 1 on Rollback for $22.88 and get a Mobil rebate?
2004 Toyota Corolla 121598
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74016
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4519443 - 09/18/17 01:48 PM Re: Mixing mobil 1high mileage with rotella [Re: chevytherealdeal]
Phishin Offline
Loc: Indiana
They all blend. No issues. Some may not be "optimum", but no one here has EVER shown a real problem with mixing oil.
Mix away.
2018 Chevy Silerado 3500HD 6.0L Gas: Undecided
2010 Accord-LX K24: VSP 0w20/MaxLife 10w30 + LG BioTech HD
2014 CR-V LX K24: M1 0w30
#4519448 - 09/18/17 01:52 PM Re: Mixing mobil 1high mileage with rotella [Re: chevytherealdeal]
Loc: ohio
I would rather run mobil 1 but i just fear it might start to leak
#4519450 - 09/18/17 01:53 PM Re: Mixing mobil 1high mileage with rotella [Re: chevytherealdeal]
demarpaint Offline
Loc: NY
The oil will mix fine, the outcome is anyone's guess though. The problem is there is no guarantee your blend is going to be 'better' for cold winter starts. It might be, and it might not be better. I'd pick one oil and use it, if you're concerned with cold starts get a 0W30 synthetic.
God Bless Our Troops
#4519463 - 09/18/17 02:13 PM Re: Mixing mobil 1high mileage with rotella [Re: chevytherealdeal]
69GTX Offline
Loc: Connecticut
If you're mixing a 20/30 grade Mobil 1 with Rotella, they have very different chemical add packs. I wouldn't bother. Now at least the M1 0w-40 is similar. And I would suspect so are the other M1 40/50 grades.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
#4519490 - 09/18/17 02:52 PM Re: Mixing mobil 1high mileage with rotella [Re: chevytherealdeal]
Bronco1 Offline
Loc: Colorado
Why would you want to? Wouldn't it make more sense to get a quality synthetic blend instead? Motocraft, Valvoline Maxlife, etc., there are a bunch of quality blends to choose from. I believe your owner's manual calls 5w30 cold weather and 10w30 rest of the year. I'm too lazy to go out to the Bronco and check
07 F150 Lariat 4x2
07 Honda Fit
96 Ford Bronco 4x4
"If you always do what you always did, you will always get what you always got" Albert Einstein
#4519494 - 09/18/17 02:56 PM Re: Mixing mobil 1high mileage with rotella [Re: chevytherealdeal]
LeakySeals Offline
Loc: Hudson, NH
Yes. It will blend into a diluted version of both.
06 Escalade 6.0L AWD 160k. M1 5w30 Fram TG
03 Maxima 3.5L 149k ST HM 10w30
#4519558 - 09/18/17 04:19 PM Re: Mixing mobil 1high mileage with rotella [Re: chevytherealdeal]
Bandito440 Offline
Loc: NEUS
It'll blend fine, but there won't be any tangible benefit. Just pick one.
'14 Grand Cherokee EcoDiesel
Rotella T6 5w-40 & OEM filter
#4519589 - 09/18/17 05:16 PM Re: Mixing mobil 1high mileage with rotella [Re: chevytherealdeal]
lawrencerd Offline
Loc: NC
If you want a synblend why not run rotella t5 or similar (Delo 10w30 blend etc)?
#4519677 - 09/18/17 07:29 PM Re: Mixing mobil 1high mileage with rotella [Re: chevytherealdeal]
justintendo Offline
Loc: northwest pa
just run the mobil 1 in 5w-30 hm and relax. oil wont cause leaks for you
2013 escape 2.0 awd
2008 fusion 2.3 mtx
1996 f150 4.9 2wd mtx
1999 kaw zrx 1100
many husqvarnas
#4519686 - 09/18/17 07:37 PM Re: Mixing mobil 1high mileage with rotella [Re: justintendo]
Loc: Wet side WA
And its on Rollback at Walmart!
2006 Duramax 74016
#4519694 - 09/18/17 07:43 PM Re: Mixing mobil 1high mileage with rotella [Re: chevytherealdeal]
CT8 Online   content
Loc: Idaho
Mix away all will be ok , Making a better oil I doubt it.
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4519798 - 09/18/17 09:25 PM Re: Mixing mobil 1high mileage with rotella [Re: chevytherealdeal]
K23Turbo Offline
Loc: Pennsylvania
Go ahead a mix em. My unscientific guess is, it will run fine and normal.
#4519816 - 09/18/17 09:48 PM Re: Mixing mobil 1high mileage with rotella [Re: chevytherealdeal]
Shannow Online   content
Loc: 'Stralia
It will mix, and not blow chunks, nor drop the additives out of suspension.
But if you are doing it to improve cold start performance, that's precisely the area that the (very) rare industry examples of issues have occurred...
What's the viscosity of the M1 that you are planning on using ?
Haven't seen that info.
what temperature are you trying to improve it at ?
Page 1 of 2 1 2 >
