I know a hose can be pulled and all the fluid pumped out as new fluid is added. I know many use the "turkey baster" or some type of suction method to empty the reservoir and refill it many times to replace old fluid with new.
What technique do you use and how many refills of the reservoir do you think it takes to do a decent job replacing the fluid?
