Mobil @ Bomgaars sale
by Duffyjr. 09/23/18 04:45 AM
More California BS!
by dogememe. 09/23/18 04:04 AM
Optimum No Rinse Wash and Wax or Shine?
by anndel. 09/23/18 03:44 AM
Michelin jack won't lift a load
by 10WSmuckers. 09/23/18 01:32 AM
Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
48 registered members (Ablebody, Boomer, 65convertible, 2013ecof150, 53' Stude, 4 invisible), 907 guests, and 38 spiders.
Topics290,870
Posts4,851,615
Members66,044
Most Online3,590
Jan 24th, 2017
Bubbles in the upper radiator hose #4518974
09/17/17 08:59 PM
09/17/17 08:59 PM
Venezuela, South America
Emanuel Offline OP
Emanuel  Offline OP
I have been very aware about how is the cooling system is working because I am going to do a long travel with my car the next month. I have noticed that when I get home and the engine is at operating temp I can feel bubbles in the upper radiator hose (the coolant is boiling), my coolant temp gauge is as normal in the middle and my cooling fan isnīt always on in this condition, I mean the cooling fan switch turns the fan on and off, it isnīt on all the time like when the engine is really overheating. I have keeping track off the coolant levels for one week and I havenīt lost any coolant.
Are this bubbles normal? Should the coolant boil at normal engine operating temp?
I am going to do a 2nd coolant flush and put a new radiator cap anyway but I would like to know if this condition is normal.
Re: Bubbles in the upper radiator hose [Re: Emanuel] #4519037
09/17/17 10:13 PM
09/17/17 10:13 PM
USA
Reddy45 Offline
Reddy45  Offline
USA
New radiator cap may fix it. If the system cannot hold pressure then the water/coolant will want to boil at a lower temp than normal.
Re: Bubbles in the upper radiator hose [Re: Emanuel] #4519038
09/17/17 10:17 PM
09/17/17 10:17 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
Bubbles in coolant is not normal and if the engine is not over-heating it usually indicates a blown head gasket.
If I were you I would be looking for another vehicle to take on your long trip next month.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Bubbles in the upper radiator hose [Re: Emanuel] #4519045
09/17/17 10:23 PM
09/17/17 10:23 PM
USA
ArcticDriver Offline
USA
Do you know the coolant is 50/50 mix with water?
Do you have an actual gauge that provides the temperature of the coolant in Celcius?
I agree with the possibilty of a bad radiator cap if the coolant mixture is unknown but the risk of a blown head gasket is also a real possibilty.
Multiple Diesel and Gasoline vehicles
Re: Bubbles in the upper radiator hose [Re: Emanuel] #4519048
09/17/17 10:25 PM
09/17/17 10:25 PM
JimPghPA Offline
JimPghPA  Offline
If it is over-heating and also with over-heating having bubbles in the coolant then it could either be a clogged radiator, or a water-pump that is not circulating enough coolant.
But if it is not over-heating and has bubbles in the coolant then look for a blown head gasket.
JimPghPa
Re: Bubbles in the upper radiator hose [Re: ArcticDriver] #4519051
09/17/17 10:27 PM
09/17/17 10:27 PM
Emanuel Offline OP
Emanuel  Offline OP
The gauge isnīt in celsius, but I thought that the middle in the gauge was normal operating temp...
Re: Bubbles in the upper radiator hose [Re: Emanuel] #4519053
09/17/17 10:28 PM
09/17/17 10:28 PM
Emanuel Offline OP
Emanuel  Offline OP
The head gasket was changed the last year, and the head was resurfaced too so I think it might be the radiator cap
Re: Bubbles in the upper radiator hose [Re: Emanuel] #4519061
09/17/17 10:42 PM
09/17/17 10:42 PM
Emanuel Offline OP
Emanuel  Offline OP
I don't think the problem is related to not enough flow from the water pump, because the temp gauge will be higher and the cooling fan would be on all the time.
Re: Bubbles in the upper radiator hose [Re: Emanuel] #4519070
09/17/17 11:03 PM
09/17/17 11:03 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Another vote for a cap. If that doesn't fix it, the increase in pressure may make the trouble worse enough to make the diagnosis easy. Carry a few gallons of water and pay attention to what the engine sounds and smells like. If the coolant is mixing with the oil, that is bad. But if the oil is clear, all you need is to carry enough water. This is a manageable trouble, but you have to pay attention grin2
Thick oil is better grin2
Re: Bubbles in the upper radiator hose [Re: Emanuel] #4519099
09/18/17 01:12 AM
09/18/17 01:12 AM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Agree with coolant cap. There are hot spots in the engine that will boil coolant if there is no pressure. Its possible you are not working the car hard enough to overheat it but this condition will usually lead to overheating.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
Re: Bubbles in the upper radiator hose [Re: Emanuel] #4519143
09/18/17 06:06 AM
09/18/17 06:06 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Odds are it is the radiator cap, but it could also be the head gasket. I've seen replaced head gaskets fail in less than a year. I would pressure test the cooling system and test the radiator cap as well, and go from there. There's nothing wrong with playing it safe, especially in a case where the head gasket was replaced.
God Bless Our Troops
Re: Bubbles in the upper radiator hose [Re: JimPghPA] #4519258
09/18/17 09:13 AM
09/18/17 09:13 AM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
+1 That being said I would check the oil and coolant and possibly sending a sample to have it tested. Only way to be sure. Otherwise I would replace the cap and try burping the system of any air.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: Bubbles in the upper radiator hose [Re: Emanuel] #4519288
09/18/17 10:16 AM
09/18/17 10:16 AM
Emanuel Offline OP
Emanuel  Offline OP
There arenīt any traces of oil in the coolant or traces of coolant in the oil, and Iīm not loosing any coolant. Today I will put the new radiator cap and see
Re: Bubbles in the upper radiator hose [Re: Bgallagher] #4519439
09/18/17 01:43 PM
09/18/17 01:43 PM
NY
demarpaint Offline
demarpaint  Offline
NY
Pressure testing will tell you in a matter of minutes if the HG is bad or not.
Re: Bubbles in the upper radiator hose [Re: demarpaint] #4519459
09/18/17 02:06 PM
09/18/17 02:06 PM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
True but I always preferred to have it sent out and see just how much if any is being contaminated.
