Just have to mention, these things work awesome! This style with the bellville spring washer assembly that takes up slack from the expansion/contraction heat cycle of a hose.
https://www.napaonline.com/en/p/BK_7051504
I had to replace a small water bypass hose on the water pump for my Corolla and it's pretty much impossible to get the factory spring clamps back on there without a lift or removing the power steering pump, since it's on the back of the engine. I tried regular and lined heavy duty worm gear clamps and couldn't get it to stop leaking, but the constant tension ones has stayed leak free. Just an FYI if anyone has to use worm gear clamps and they end up leaking.
