What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
Lubricant Additives - A Practical Guide
by wemay. 09/24/18 01:39 PM
Fram Ultra--Any Real Competition?
by IndyFan. 09/24/18 12:59 PM
Used generator price.
by Eddie. 09/24/18 11:55 AM
More energy concerns about Bitcoin
by OVERKILL. 09/24/18 10:01 AM
albert001, LG_Electronics, TCam, OzFrog, Kursk
66062 Registered Users
116 registered members (2013ecof150, 99Eclipse, 14Accent, ABomb369, 53' Stude, 19 invisible), 1,819 guests, and 38 spiders.
Topics290,956
Posts4,853,226
Members66,062
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
Generator for all electric home #4518471
09/17/17 10:24 AM
09/17/17 10:24 AM
Upstate NY
Donald Offline OP
Donald  Offline OP
Upstate NY
The home in DE I have bought has two heat pumps each with electric backup. Prior homes in the Northeast were oil hot water. So this is a change. There is a 750 gallon buried propane tank used mainly for domestic hot water and two fireplaces.
One of the heating systems circuit breaker was 65 amps. I could see needing 100 amps just for heat. Then there is a well pump and refrig & freezer.
No basement so garage will be crowed with wife's car and workshop.
I am thinking I need 35kw to 40kw.
One idea is to get a diesel generator on a trailer and rent a storage space for it. Then how do you easily connect a portable 40kw generator to your home?
2015 Ford F250 w/Powerstroke
Re: Generator for all electric home [Re: Donald] #4518485
09/17/17 10:56 AM
09/17/17 10:56 AM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Big cord into a utility disconnect so you don't charge the rest of neighborhood. Farmers around here do it all the time to keep confinement operations going.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Generator for all electric home [Re: Donald] #4518509
09/17/17 11:28 AM
09/17/17 11:28 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
If you have a LP tank , consider an LP powered generator . Even if you have to add another LP tank .
Are you thinking of powering the whole house of just enough to " rude out a storm " ?
Easy to connect such a generator to your home . But doing it cheaply , safely & with in code is another matter .
Also , quickly and easily if power goes out at night in a pounding storm ( it most likely will ) .
Automatic transfer switches are easily obtainable , but not cheap .
Will you have the discipline to maintain it and exercise it once or twice a month ? If you go LP , at least you will not have to worry about fuel storage and fuel degrading with time .
You probably will not be able to DIY this . You may need some professional assistance , at least some where along the way .
Best of luck & stay safe , :-)
Wyr
God bless
Re: Generator for all electric home [Re: Donald] #4518523
09/17/17 11:52 AM
09/17/17 11:52 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Wabbout a wood or pellet stove as back up heat?
Thick oil is better grin2
Re: Generator for all electric home [Re: Donald] #4518532
09/17/17 12:03 PM
09/17/17 12:03 PM
Upstate NY
Donald Offline OP
Donald  Offline OP
Upstate NY
Well riding out the storm will probably mean powering the first floor heat pump and it's electric booster coils if it's less than 30F.
I can forget the 2nd floor one as there are only guest bedroom on 2nd floor. Kids are gone.
But just that one heat pump system will require a large generator. And well pump, septic air pump and refrig/freezer.
That's the minimum to "rude" out the storm.
Clearly propane is an option. My tank should be large enough. HOA rules no above ground fuel tanks.
This is thinking in progress. I will bring my 8kw propane generator when I move.
Re: Generator for all electric home [Re: Donald] #4518566
09/17/17 12:39 PM
09/17/17 12:39 PM
Texas
JustinH Offline
JustinH  Offline
Texas
Interesting to hear of an electric heat house in Delaware.
The cost of propane must be out of sight if they went that route over propane.
I would assume that natural gas is not an option if you are setup for propane?
I had an apartment in Central Texas that was all electric and the heat bill was insane. Mind you its not cold down here for long.
'11 Hyundai Sonata GLS
'11 Scion XB
Re: Generator for all electric home [Re: Donald] #4518619
09/17/17 01:52 PM
09/17/17 01:52 PM
Pennsylvania
Boomer Offline
Boomer  Offline
Pennsylvania
PP&L in southeast PA pushed all electric houses back in the 60's and 70's so there are many, many thousands in their service area. I know; I had one when I lived in Lancaster and had a heat pump installed to cut my bills.
2013 VW Passat TDI SE, 59,300 miles Castrol Professional VW507 5W-30
2017 VW Golf All Track 17,470 miles Castrol Professional VW505 5W-40
Re: Generator for all electric home [Re: andyd] #4518655
09/17/17 02:53 PM
09/17/17 02:53 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Very good idea .
Since you have a LP tank , Install one or more LP fired heaters / furnaces .
That would help reduce the size needed for the generator .
Wyr
God bless
Wyr
God bless
Re: Generator for all electric home [Re: Donald] #4518658
09/17/17 02:54 PM
09/17/17 02:54 PM
Northern, NY
Rob_Roy Offline
Rob_Roy  Offline
Northern, NY
How cold does it get there? The draw of the heat pumps should not be too scary, but the electric backup is. You may be better off adding some sort of alternative heat, rather than trying to power the entire heating system with a generator.
My dad just had a 22kw Generac installed, which was sized to run his entire house, including three heat pump air conditioners...however, his heat is provided by an oil boiler.
2016 Ford Expedition 3.5 Ecoboost
2015 Subaru Legacy 3.6
2014 Subaru Outback 2.5
1999 Ford F350, V10
Re: Generator for all electric home [Re: JustinH] #4518699
09/17/17 03:30 PM
09/17/17 03:30 PM
Upstate NY
Donald Offline OP
Donald  Offline OP
Upstate NY
All except the very coldest days the heat pump will provide the heat, not electric coils.
Re: Generator for all electric home [Re: Donald] #4518704
09/17/17 03:39 PM
09/17/17 03:39 PM
Kansas
Kruse Offline
Kruse  Offline
Kansas
I have something like this outside of my home.
http://www.ronkelectrical.com/non-fused-disconnect-single-throw-switches.php
I think mine is rated for 200 amps. You need one of these so the electricity doesn't back-feed upline and potentially kill a lineman working down the road.
Re: Generator for all electric home [Re: Donald] #4518710
09/17/17 03:46 PM
09/17/17 03:46 PM
Pennsylvania
Astro_Guy Offline
Astro_Guy  Offline
Pennsylvania
What is the LRA (Locked Rotor Amperage) rating on the nameplate of the heat pump you want to run? This is the momentary inrush current needed to start the compressor. The RLA (Running Load Amperage) should also be listed on the nameplate, and it will be a small fraction of the LRA. Don't be surprised if the LRA exceeds the capacity of the breaker that protects the unit because we are talking about a momentary load.
When starting an inductive load, such as the compressor on a heat pump, the voltage will drop momentarily which results in more amperage at the same level of power output from your generator. I've read that covering 70% of your LRA load is considered acceptable for commercial applications, and that homeowners might be able to push that figure closer to 50%.
The bottom line here is that you are going to need to perform a load calculation, and that inductive loads like heat pumps cannot be treated the same way as resistive loads like a water heater or electric range. Installing a large, stationary generator is not normally a DIY project, so have some pros help you with this.
'01 Volvo V70XC, 228k, 0W-40 M1
'16 Accord, 17k, 0W-20 M1 EP
Re: Generator for all electric home [Re: Donald] #4518753
09/17/17 04:37 PM
09/17/17 04:37 PM
Elizabethtown, Pa
Al Online content
Al  Online Content
Elizabethtown, Pa
If you have money to burn fine. But what is the liklihood of loosing electricity for more than a few days. You should make an assessment of what level of comfort you expect for what period of time.
I am most concerned with winter and loss of electricity. So I have a propane heater with a 500 gal propane tank. I just want to stay warm and have some lioghts at night. Thats why I opted for a small 1800 wat generator. I keep enough food in the house for say a month (at least). If it gets much worse than that, you better get out your guns.
If you expect a generator to run for your survival..its probably a bad plan. Things can and do break down. Best to keep it simple.
Re: Generator for all electric home [Re: Donald] #4518784
09/17/17 05:23 PM
09/17/17 05:23 PM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Pellet stove still needs some electricity. If you have a gas fireplace already the install of a high efficiency fireplace with a blower would probably produce 30-40k btu with a electrical need of less than 250 watts. That would keep a floor of a modest home from freezing and the immediate room cozy and probably very economical over electric using zone heat unless propane is crazy high. I have a freestanding fireplace stove that does not require electricity at all for here in the country but does have a fan for higher efficiency.
13 Scion Xb
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Generator for all electric home [Re: Astro_Guy] #4518814
09/17/17 06:09 PM
09/17/17 06:09 PM
Upstate NY
Donald Offline OP
Donald  Offline OP
Upstate NY
I understand the load concerns of starting an electric motor. But my real concern is when the electric booster coils kick in. It's all integrated and I am not sure there is any control of when it kicks in the booster coils.
Page 1 of 3 1 2 3
