MC FL-500S CUT OPEN
by 53' Stude. 09/18/18 05:15 PM
FORD FACTORY FILTER CUT OPEN
by 53' Stude. 09/18/18 05:06 PM
2019 Harley Davidson FXDR 114
by DuckRyder. 09/18/18 04:59 PM
USS Forrestal question
by cjcride. 09/18/18 03:52 PM
Breaker Box
by Throt. 09/18/18 03:00 PM
Honda metal fuel tank seam leak
by wing0. 09/18/18 02:49 PM
Cracked single stage paint
by JHZR2. 09/18/18 01:45 PM
Options versus dealer oil changes
by Schmoe. 09/18/18 01:34 PM
Longevity of Mercon LV in a 2017 Ford Escape?
by mrdctaylor. 09/18/18 01:24 PM
I'm on a Lawn Boy jag
by andyd. 09/18/18 01:13 PM
Old (New) Tires
by ET16. 09/18/18 12:05 PM
iOs 12 for Apple
by madRiver. 09/18/18 12:01 PM
Synthetic oil overrated??
by Ablebody. 09/18/18 12:01 PM
Ferrari Monza SP 1/2
by DeepFriar. 09/18/18 11:58 AM
Any option to "Mark all forums read"
by Rick505. 09/18/18 11:54 AM
1981 280ZX Turbo
by 16HC. 09/18/18 11:12 AM
Muscle car emblems
by Snagglefoot. 09/18/18 10:15 AM
Burn out question
by Fitter30. 09/18/18 10:15 AM
tomkat22, tabar2004, SierraMan, Rennmeister, KeithCoates
66004 Registered Users
89 registered members (Astro14, AVB, 53' Stude, BAJA_05, 65convertible, 25ring, 10 invisible), 1,365 guests, and 36 spiders.
Topics290,604
Posts4,847,323
Members66,004
Most Online3,590
Jan 24th, 2017
Fuel injected generator - advantages #4518368
09/17/17 07:34 AM
09/17/17 07:34 AM
key largo,fl
henni Offline OP
henni  Offline OP
key largo,fl
What are the advantages for a fuel injected generator vs carburetor equipped ?
ie.
1. No more clogged carb due to storage ?
2. Better fuel economy ?
What about disadvantages ?
Re: Fuel injected generator - advantages [Re: henni] #4518374
09/17/17 07:50 AM
09/17/17 07:50 AM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
If thinking of a standby go with propane with a auto exerciser.
My experience with smaller fuel injected engines is they start way easier and seem way more responsive to load. The negative is the brain box is expensive if it fails.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Fuel injected generator - advantages [Re: henni] #4518394
09/17/17 08:20 AM
09/17/17 08:20 AM
FL USA
Blueskies123 Offline
FL USA
How often are you going to use it. If it is once every 5 years, simpler is better assuming you do not leave any gas in it. Zero gas in the carb, and bottom of the fuel tank.
Re: Fuel injected generator - advantages [Re: henni] #4518396
09/17/17 08:22 AM
09/17/17 08:22 AM
OH
fdcg27 Online content
fdcg27  Online Content
OH
The primary disadvantage with a seldom used engine is that you get an enormous increase in complexity with the benefit of easier starting, in that the FI engine will either start or it won't along with likely lower fuel consumption.
Carburetors are fairly simple assemblies and a carbureted engine can usually be coaxed into life with a little fiddling if it hasn't been run for a while.
Why go for a vast increase in cost and complexity in a backup genset?
17 Forester 12K MSS 0W-20
12 Accord LX 92K PP 5W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: Fuel injected generator - advantages [Re: henni] #4518398
09/17/17 08:26 AM
09/17/17 08:26 AM
ME
eljefino Offline
eljefino  Offline
ME
A carb is happy at one speed and a consistent load. Perfect for generators or lawnmowers. I could see a go cart or pit bike benefiting from FI.
My newest lawnmower has a tight EPA-approved fuel system without much ventilation. This keeps the lighter parts of gas from evaporating off and it starts right up in the spring. I do use sta-bil for its part but keeping gas dry and dark has its advantages. This should be the approach generator makers follow as well... plus maybe add a second petcock to drain the tank.
Re: Fuel injected generator - advantages [Re: henni] #4518403
09/17/17 08:37 AM
09/17/17 08:37 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
ie.
Go for propane if you want simple and reliable.
2015 Ford F250 w/Powerstroke
Re: Fuel injected generator - advantages [Re: Donald] #4518408
09/17/17 08:40 AM
09/17/17 08:40 AM
ME
eljefino Offline
eljefino  Offline
ME
+2 and if you're ferrying fuel in your car daily propane won't stink it up.
So long as your supplier has a generator, or you can find an exchange place.
Re: Fuel injected generator - advantages [Re: henni] #4518605
09/17/17 01:39 PM
09/17/17 01:39 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
What would it take to rig a generator to a junker car engine and trans.Make a shed for it in back of the shop. Use exhaust heat to heat water. The engine has only 128 HP. It is 2.7L 6 cyl BMW engineered for economy. I could loaf it along at 1200 RPM and put the trans in D, which is an OD. Hhhhmn. The gears are whirling. grin2
Thick oil is better grin2
Re: Fuel injected generator - advantages [Re: andyd] #4518863
09/17/17 06:57 PM
09/17/17 06:57 PM
OH
OH
So the noble old 528e is officially done?
Sorry to hear that.
Two Camrys?
Welcome to the dark side, LOL.
95 318i
Re: Fuel injected generator - advantages [Re: henni] #4519042
09/17/17 10:22 PM
09/17/17 10:22 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
I bought that '88 back in '96 with 150 K on it. I drove it for 12 yrs and 200 k more miles.It retired back in '08 due to rust I had another 2 '88s and a pair of '88 parts cars I had 2 or 3 528es on the road for about 8 yrs just after the turn of the millennium. I'm parting all but 1 528e to keep for sheet metal and other good stuff for a fairly intact '83 533i. That is gonna be my "toy" grin2
