Mobil 1 or Mobil 1 HM
Pa, USA
If both Mobil 1 and Mobil 1 High Mileage were the same price, which would you pick? Which is better? Why?
2004 Ford Explorer Sport Trac and it is over 95000 miles. No leaks or loss.
I would wait for one to come on sale.
Regular M1 will do the job, but M1 HM will do it better. M1 HM is slightly higher viscosity. That is a good thing with higher miles like your engine. Also M1 HM has slightly more detergents and seal conditioners, which is a good thing, unless you REALLY REALLY want to replace your engine seals instead of letting the oil deal with it. Extra detergents only improve cleanliness, as far as Im concerned - that is a good thing. Overall M1 HM is a superior product compared to regular M1. The only place where regular M1 has a slight winning edge is anything below -20°.
P.S. Many race teams use HM oils because they are just as cheap as regular synthetics, but hold up to the engine torture on the track a lot better through higher viscosity and higher dose of various additives.
Originally Posted By: bigj_16
That M1 10W-30 HM is stout
Yes that was my summer oil before changing to QSUD 5w-30 a few weeks ago for the winter.
Yes it Euro A3/B3 rated with HTHS = 3.5 cP and KV100 = 12.1 cSt.
The old formula was better, it was API SL with elevated zinc levels, a race oil in disguise. Then they dropped it to SN levels of zinc, but it's still a good oil and very strong. Just not as racey as before, especially if you had flat tappets.
My 1991 Ford F-150 has 153,000 miles on it. I use regular, plain 10W-30 Mobil 1. And change oil and filter twice a year. It leaks a bit from the rear main. It doesn't burn a drop, and passes emissions with flying colors. I see no need or reason to buy any of this, "high mileage" stuff. To me it's just a selling gimmick.
