Diesel engines and emissions
by spasm3. 12/16/18 03:31 PM
Experiment time
by 53' Stude. 12/16/18 02:52 PM
2019 2.7L EB - Edge ST & Catch Can
by -SyN-. 12/16/18 02:51 PM
15 Grand Caravan
by zrxkawboy. 12/16/18 02:18 PM
Pennzoil Platinum 5w30 at walmart.com
by Irishman. 12/16/18 11:08 AM
pcv cleaning
by macdole99. 12/16/18 10:39 AM
Solar lights that last all night
by Snagglefoot. 12/16/18 09:20 AM
Things Santa might say......
by ZZman. 12/16/18 08:24 AM
ULTRA-POWER 57082
by ET16. 12/16/18 06:56 AM
No collision totaled vehicle
by madRiver. 12/16/18 06:32 AM
Brightest backup light for my daughters car?
by BobsArmory. 12/16/18 06:26 AM
M1 0W20 EP Good To At Least 10K Miles ?
by ChrisD46. 12/16/18 03:29 AM
Gift for young Army Cadet
by Snagglefoot. 12/16/18 12:33 AM
Instacart Grocery Delivery
by dogememe. 12/16/18 12:26 AM
Cpcz9382, PPWarrior, Robwashere4oil, saleen367, Rickeagle
66696 Registered Users
100 registered members (71Chevyguy, 2004tdigls, 69Torino, -SyN-, 240_Ed, 1foxracing, 8 invisible), 2,196 guests, and 42 spiders.
Topics295,149
Posts4,928,736
Members66,696
Most Online2,553
Oct 27th, 2018
Fluid Film as Undercoating Question #4518088
09/16/17 06:15 PM
09/16/17 06:15 PM
IL
lukejo Offline OP
lukejo  Offline OP
IL
Using FF as undercoating just about everywhere on my Silverado. I know SOP is to put on in warm weather, blast off and wash after winter, and apply again. However, I'm crawling under the truck and coating places that I guarantee I will never be able to get to with a pressure washer or car wash. At the same time, the FF will undoutedly collect grime and salt here.
Question--Does anyone know for sure, can an old coat of FF with grime (and SALT) just be covered with a new coat of FF and still protect?? FF's website talks of sealing and self-healing, so surely this would work? If so, I likely won't mess with washing any of it before reapplying.
Re: Fluid Film as Undercoating Question [Re: lukejo] #4518107
09/16/17 06:44 PM
09/16/17 06:44 PM
One Step Beyond
larryinnewyork Offline
One Step Beyond
My situation:
I always had my vehicle 'oil' treated in the Fall.
Never washed it off after Winter / Yes it's very dirty & greasy underneath.
A lot of the oil stayed on after Winters / I never worried about the oil absorbing any salt, but always thought about it.
Now I don't drive as much in Winter weather so every Spring it still oily.
On the rare occasion I go to an Indy Mechanic, I will first go to the self-serve car wash and clean up the area for them.
Re: Fluid Film as Undercoating Question [Re: lukejo] #4518124
09/16/17 07:01 PM
09/16/17 07:01 PM
USA
stephen9666 Offline
stephen9666  Offline
USA
Why would you blast it off after the winter? I would just recommend a touch-up of high-spray areas before winter. That's always been my strategy. The FF will last a long time on areas that don't get a constant spray of water.
I don't think FF or any oil "absorbing" salt and causing rust is an issue. We've all seen oil prevent rust on vehicles, whether it was from oil leaks or whatever. If it absorbed salt and made rust worse, we'd know it.
Re: Fluid Film as Undercoating Question [Re: lukejo] #4518126
09/16/17 07:04 PM
09/16/17 07:04 PM
PA
dnastrau Offline
dnastrau  Offline
PA
I would not worry about trying to remove the remaining Fluid Film before reapplying. I have been using it for a couple of years and it works better than I expected it would as an undercoating. It creeps well and seems to do a great job displacing moisture and penetrating existing corrosion. Once it gets dirty it does not seem to wash off easily either. As long as it is still coating everything, I don't think that any dirt or salt that is stuck to it will bother anything. Rust needs moisture and oxygen to spread.
Andrew S.
Re: Fluid Film as Undercoating Question [Re: lukejo] #4518132
09/16/17 07:12 PM
09/16/17 07:12 PM
Iowa
biggusblockus Offline
Iowa
I just wash off the big chunks of dirt, mud, etc and re coat every fall.
The underside of my 01 Wrangler looks amazing even after Iowa and Wisconsin winter after winter.
Re: Fluid Film as Undercoating Question [Re: lukejo] #4518170
09/16/17 07:59 PM
09/16/17 07:59 PM
ME
eljefino Offline
eljefino  Offline
ME
Oil (lanolin) and water don't mix. So the water will bead on top of the oil and the salt will dissolve in the water, not the oil. FF slowly drips off over the summer so by next fall you're down to bare metal again.
I hose FF on in fall before the first road salt, and don't really care if I get it on road grime/ sand. Makes a mud that protects.
Someone needs to lick a representative glob of FF midwinter to see if it tastes salty. wink
Re: Fluid Film as Undercoating Question [Re: lukejo] #4518195
09/16/17 08:18 PM
09/16/17 08:18 PM
West Michigan
buck91 Offline
buck91  Offline
West Michigan
Been using the bulk FF on my F150 for a couple winters now and I will say it both washes off as well as stays in place... If that makes any sense. The more of a grimey caked up layer of grunge that is present the more durable it is. A bulk coating will result in some rinsing off with a good hose down but its not possible to quickly rinse it off. Over the course of a winter it will rinse off in high wash areas regardless of the amount of grunge you try to build up.
What seems to be working for me (I say seems because its only a few years old) is to spray on some time during mid to late summer. This balances (hopefully) a lot of driving in rain and such after the road salt is long gone to rinse out the under carriage (along with some intentional hosing off, especially of obvious areas of build up and entrapment). Later in the summer while there is still hot weather left (to help with both application and subsequent creep_ I like to respray on a nice hot and dry day. In a perfect world I then go cruise some dry dusty dirt roads.
Some areas seem to rinse clean over the winter but the majority of the underbody has built up a bit of a grimy coating. Doesn't SEEM to be developing any new rust in most areas (one trouble spot on the cab in a high wash area that I'm not sure how to address short of pulling the doors for a repaint).
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Fluid Film as Undercoating Question [Re: lukejo] #4518208
09/16/17 08:36 PM
09/16/17 08:36 PM
South Eastern, CT
AMC Offline
AMC  Offline
South Eastern, CT
The little bit of grime and salt that the fluid film will hold is no big deal. I too give it a good pressure wash in the spring and start over in the fall, that strategy works great.
Now, I must warm you. I don't know what year your truck is but Fluid film will majorly soften the black coating GM uses on their frames. I use fluid film on my Silverado too but I do not get it on the black frame. Again, DO NOT PUT IT ON THE BLACK FRAME! Everywhere else is fine but avoid the black waxy coating, if your truck still has it. If your black frame coating is curling or peeling than a very light coat of fluid film may actually soften it and make it repair itself but otherwise, I wouldn't get it on the black frame.
18 Honda CR-V - Mobil-1 AFE 0w-20
17 Ram 1500 SLT - Napa Synthetic 5w-20
14 Yamaha Super Tenere - Mobil Delvac 15w-40
Re: Fluid Film as Undercoating Question [Re: lukejo] #4518221
09/16/17 08:57 PM
09/16/17 08:57 PM
USA
E365 Online content
E365  Online Content
USA
My 2015 Focus has had FF applied twice now and I'm surprised how much is STILL coated. The old wives tale is that it rinses off easily. I haven't experienced that much at all.
Whatever’s on sale...
Re: Fluid Film as Undercoating Question [Re: AMC] #4518232
09/16/17 09:14 PM
09/16/17 09:14 PM
IL
lukejo Offline OP
lukejo  Offline OP
IL
Yeah, I had read that elsewhere, but that black coating is already wearing thin or flaking in spots. Plus, if I plan to keep FF on constantly, I guess it doesn't matter if the black is dissolved of it now or flakes off next year. (That's my thinking anyway.) Also, where the black is flaking up, there is already rust under the flakes...no better than regular coats of FF.
'05 Corolla 285k
'09 Silverado 2500HD 6.0, 95k
'12 Camry LE 4cyl, 155k
Re: Fluid Film as Undercoating Question [Re: AMC] #4518320
09/17/17 04:35 AM
09/17/17 04:35 AM
Minnesota
leje0306 Offline
leje0306  Offline
Minnesota
Yes, and Amsoil HDMP is a great alternative for the black frame
Re: Fluid Film as Undercoating Question [Re: leje0306] #4518331
09/17/17 05:04 AM
09/17/17 05:04 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Perhaps. I didn't have success using Hampton on scored/exposed areas on a car I used it on.
I only like waxes on areas not subject to damage.
Were you able to confirm that hdmp actually "merged" with the existing OEM coating to be seamless?
Re: Fluid Film as Undercoating Question [Re: lukejo] #4518334
09/17/17 05:16 AM
09/17/17 05:16 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I like areas to be clean before applying a coat, or re-coating with a rust preventive product. Clean is the operative work, not sterile. In other words I give it a quick once over and get off what I can, allow a few days for it to dry and apply the coating. That method has served me well with vehicles I've treated. I'd rather not spray a coating over road salt residue, or caked on mud if I can clean it off. Hard to access areas, I do the best I can with, but won't lose sleep if they're a little dirty.
God Bless Our Troops
Re: Fluid Film as Undercoating Question [Re: leje0306] #4518389
09/17/17 07:15 AM
09/17/17 07:15 AM
South Eastern, CT
AMC Offline
AMC  Offline
South Eastern, CT
No, it isn't. I tried Amsoil HDMP and Corrosion-X HD before I tried fluid film on my truck and all of them still softened the coating to the point of making the coating come off very easily. Even just accidentally rubbing my pant leg on the frame treated with HDMP while crawling under the truck made a smear and thin spot in the coating.
If you have a GM truck and want to preserve the frame coating, I recommend you purchase a relatively light duty / low powered pressure washer and rinse the undercarriage once a week or so during the winter. Once the coating has come off in large areas, game on. Coat the frame down with whatever heavy duty rust preventative you like and don't ever stop re-applying it while you still want to care for it. IMO, GM really dropped the ball with that black waxy frame coating they use.
Re: Fluid Film as Undercoating Question [Re: AMC] #4518561
09/17/17 11:34 AM
09/17/17 11:34 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Are they replacing frames the way Toyota has to?
