Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Joey Logano and the 2019 Mustang
by Malo83. 12/13/18 02:40 PM
BMW LL01FE Spec
by The Critic. 12/13/18 02:03 PM
I Tried and Failed to Not Buy a New Car
by badtlc. 12/13/18 01:49 PM
OEM Brand Coolant by Rocochem
by NumbersGuy. 12/13/18 01:15 PM
Motomaster Dexron Vi Fully Synthetic
by Gannet167. 12/13/18 12:55 PM
Hacked
by Smoky14. 12/13/18 12:41 PM
Scanning for U codes.
by LeakySeals. 12/13/18 12:23 PM
Food photography trickery
by nthach. 12/13/18 11:29 AM
oil for 2.5 2013 vw passat?
by jstert. 12/13/18 09:47 AM
Scotty Kilmer Parody
by oilpsi2high. 12/13/18 09:41 AM
ID this old tool
by John_Conrad. 12/13/18 09:30 AM
Weak New CR2032/remote start + fob batteries
by redhat. 12/13/18 09:23 AM
Smart charges/time
by Duffyjr. 12/13/18 08:24 AM
7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
WondrousBread, slickoo9, turntable_life, Poles19, HinaMach
66669 Registered Users
109 registered members (andyd, Alfred_B, 28oz, A310, 97prizm, AnonOIl, 10 invisible), 1,941 guests, and 33 spiders.
Topics295,028
Posts4,926,383
Members66,669
Most Online2,553
Oct 27th, 2018
2015 Ford PSD 6.7 38,000km OCI #4518018
09/16/17 04:35 PM
09/16/17 04:35 PM
Northern Alberta
DustinC Offline OP
DustinC  Offline OP
Northern Alberta
They went a little over the recommended
OEM motorcraft filter and Delo 5W40 oil
Re: 2015 Ford PSD 6.7 38,000km OCI [Re: DustinC] #4518103
09/16/17 06:41 PM
09/16/17 06:41 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Fe at 166 is little high, but will be for so many miles...
Aluminum is only 17 - that pretty good!
Lots of Silicon - K&N air filter????
Re: 2015 Ford PSD 6.7 38,000km OCI [Re: Linctex] #4518106
09/16/17 06:43 PM
09/16/17 06:43 PM
Northern Alberta
DustinC Offline OP
DustinC  Offline OP
Northern Alberta
nope OEM motorcraft filter
Re: 2015 Ford PSD 6.7 38,000km OCI [Re: DustinC] #4518133
09/16/17 07:13 PM
09/16/17 07:13 PM
Oklahoma
Arkandspark Offline
Arkandspark  Offline
Oklahoma
Kinda harsh treatment for such an expensive engine.
Re: 2015 Ford PSD 6.7 38,000km OCI [Re: DustinC] #4518188
09/16/17 08:12 PM
09/16/17 08:12 PM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
Not sure why they ran it for so long; way past the IOLM I would gather. What was their logic there?
Engine wasn't "harmed", but I'd not let that be a habit.
Does the vehicle not have a air filter meter also? Any idea of the status of that as well?
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 2015 Ford PSD 6.7 38,000km OCI [Re: DustinC] #4518201
09/16/17 08:28 PM
09/16/17 08:28 PM
Planet Earth
2015_PSD Offline
2015_PSD  Offline
Planet Earth
Cut the oil filter open. I would bet it is trashed. SMH why someone would do that to a $20K engine.
Re: 2015 Ford PSD 6.7 38,000km OCI [Re: DustinC] #4518239
09/16/17 09:24 PM
09/16/17 09:24 PM
Northern Alberta
DustinC Offline OP
DustinC  Offline OP
Northern Alberta
Filter minder was still good but I installed a new OEM filter as I have no idea when I get to see this truck again, I installed an Amsoil Dual bypass kit, full DPF/SCR delete, and 5W40 MAX Duty Amsoil HDEO so next UOA should look A lot better.
I'll check to see if I still have the filter in my bin I was planning on cutting it open.
Re: 2015 Ford PSD 6.7 38,000km OCI [Re: 2015_PSD] #4520842
09/20/17 12:01 AM
09/20/17 12:01 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Those numbers are higher than what you are "used to seeing" - that's all.
NOTHING in that UOA indicates anything is "trashed". I dare you to prove it.
Re: 2015 Ford PSD 6.7 38,000km OCI [Re: Linctex] #4520998
09/20/17 07:11 AM
09/20/17 07:11 AM
Planet Earth
2015_PSD Offline
2015_PSD  Offline
Planet Earth
I am not talking about the engine. I am talking about the oil filter, but it still makes no sense why someone would do that to an engine
Re: 2015 Ford PSD 6.7 38,000km OCI [Re: DustinC] #4521153
09/20/17 10:11 AM
09/20/17 10:11 AM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
Before that filter is cut open, I'd love it if someone has the ability to put it on a test fixture and see if it's in perpetual bypass or not (I doubt it is, but would be nice to know for sure).
Then cut open and autopsy.
Re: 2015 Ford PSD 6.7 38,000km OCI [Re: dnewton3] #4521218
09/20/17 11:20 AM
09/20/17 11:20 AM
Planet Earth
2015_PSD Offline
2015_PSD  Offline
Planet Earth
An MC FL-2051s ran for 38,000 miles would be in "bypass". Why? Because the media is probably torn open. They look pretty bad with far less miles on them and though I could be wrong I cannot imagine it would last for 38,000 miles without tearing.
Re: 2015 Ford PSD 6.7 38,000km OCI [Re: 2015_PSD] #4521317
09/20/17 12:44 PM
09/20/17 12:44 PM
GA
drtyler Offline
drtyler  Offline
GA
Not that it matters much, but the OCI on this sample is 38,000 km (24,600 miles).
Re: 2015 Ford PSD 6.7 38,000km OCI [Re: drtyler] #4521337
09/20/17 01:00 PM
09/20/17 01:00 PM
Planet Earth
2015_PSD Offline
2015_PSD  Offline
Planet Earth
Missed that, it may make it better for the oil filter (maybe, but I am guessing it is still torn), but worse for the UOA. Wear metals drop on a per mile basis on longer runs. The mileage is about 3.5x my longest run to date, but the iron is more than 10x what mine produced.
Re: 2015 Ford PSD 6.7 38,000km OCI [Re: DustinC] #4521872
09/21/17 04:54 AM
09/21/17 04:54 AM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
I don't necessarily agree that it would have suffered a void or plugging, but I have no proof, as do none of us. It's speculation until we see the evidence of the filter.
The problem with cutting one open is that it's a destructive test; it alters things that you cannot put back.
That's why I'd like to see it tested on a dP gauge prior to being cut.
This is the challenge that eludes most BITOG conversations. Rather than speculate, why not KNOW? It takes effort, and that's not near as much fun as just guessing from the keyboard. Not picking on you, 2015 Ford PSD 6.7; it's not a thing unique to any one person here, but more of a pervasive societal thing. Heck even I fall victim to it at times. That's why I like to run "tests" outside of the norm; my UOAs are always from conditions that most folks won't do on their own, for example.
I've thought about making a rig to test filter dP from some old components, but never got around to it. Take an old log splitter, add on some flow and pressure gauges, and then make up an adaptive filter mount where the center thread post can be changed out quickly. May have to manipulate the drive to a variable speed pully so that you can get the flow you want, and also put a ball valve downstream so you can mimic the resistance of the engine. Viola! Unfortunately it's about #97 on my list behind a bunch of honey-do items ...
Re: 2015 Ford PSD 6.7 38,000km OCI [Re: dnewton3] #4522002
09/21/17 07:45 AM
09/21/17 07:45 AM
Planet Earth
2015_PSD Offline
2015_PSD  Offline
Planet Earth
I don't necessarily agree that it would have suffered a void or plugging, but I have no proof, as do none of us. It's speculation until we see the evidence of the filter. The problem with cutting one open is that it's a destructive test; it alters things that you cannot put back. That's why I'd like to see it tested on a dP gauge prior to being cut.
I am not in disagreement with what you say--it is indeed, speculation on all of our parts. However, based upon what I have seen, the FL-2051s (and its equivalents, unless wire backed) has a very long filter element with unsupported media and I lean heavily towards that element failing after that many miles. Obviously, it may have been just fine, but (as you say) at this point we can only speculate. One thing I am pretty confident of is that had the person changed the oil 3 or 4x in the 24K run instead of one time, the cumulative iron produced would not have been 166PPM. Does that mean anything in the long term? Who knows...it is just not how I would maintain my engines.
