VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Zahndkile, duradick, Harold1031, Skendread, NGK
67590 Registered Users
45 registered members (antik, 4WD, billt460, AurionX2, 97K15004WD, BlakeB, 6 invisible), 705 guests, and 53 spiders.
Topics286,270
Posts4,905,647
Members67,589
Most Online2,967
Mar 10th, 2019
Mobil 1 5w30 ESP vs. Mobil 1 0w40 ESP #4517896
09/16/17 02:34 PM
09/16/17 02:34 PM
Outside U.S
Floydian Offline OP
Floydian  Offline OP
Outside U.S
Which one is more suitable for my car which is a Mini Cooper S which has direct injection, twin-scroll turbocharger, and variable valve timing. Oil temp is usually between 105-120 degrees C. Which would be low in calcium and still provide adequate protection.
Re: Mobil 1 5w30 ESP vs. Mobil 1 0w40 ESP [Re: Floydian] #4517921
09/16/17 03:07 PM
09/16/17 03:07 PM
Western usa
Ammofirst Offline
Ammofirst  Offline
Western usa
What does the owners manual say ? Are you restricted to a low/ mid saps oil ?
Re: Mobil 1 5w30 ESP vs. Mobil 1 0w40 ESP [Re: Floydian] #4517926
09/16/17 03:14 PM
09/16/17 03:14 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
0w40 is Mobil's flagship
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: Mobil 1 5w30 ESP vs. Mobil 1 0w40 ESP [Re: Floydian] #4517930
09/16/17 03:21 PM
09/16/17 03:21 PM
Ohio
Dorian Offline
Dorian  Offline
Ohio
M1 0W40 is high in Calcium, FWIW.
15 Camry Hybrid SE 48K 0W20 Kendall bulk
14.5 Camry SE 2AR 0W20 M1 AFE 44K (Mom's)
98 Chevy Prizm 1ZZ M1 AFE 0W30 148K (Brother's)
Re: Mobil 1 5w30 ESP vs. Mobil 1 0w40 ESP [Re: Ammofirst] #4517932
09/16/17 03:21 PM
09/16/17 03:21 PM
Outside U.S
Floydian Offline OP
Floydian  Offline OP
Outside U.S
Owners manual says any of the following SAE 0w 40, SAE 0W 30, SAE 5W 40, SAE 5W 30
Re: Mobil 1 5w30 ESP vs. Mobil 1 0w40 ESP [Re: Dorian] #4517940
09/16/17 03:31 PM
09/16/17 03:31 PM
Outside U.S
Floydian Offline OP
Floydian  Offline OP
Outside U.S
High calcium means more prone to LSPI?
Re: Mobil 1 5w30 ESP vs. Mobil 1 0w40 ESP [Re: Dorian] #4517943
09/16/17 03:35 PM
09/16/17 03:35 PM
Great Lakes
Quattro Pete Offline
Great Lakes
OP is asking about M1 0w-40 ESP, which is not the same as the regular M1 0w-40.
The ESP version is not high in calcium, AFAIK, because it's a low SAPS oil.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Mobil 1 5w30 ESP vs. Mobil 1 0w40 ESP [Re: Quattro Pete] #4517947
09/16/17 03:40 PM
09/16/17 03:40 PM
Outside U.S
Floydian Offline OP
Floydian  Offline OP
Outside U.S
What is SAPS? thanks.
Re: Mobil 1 5w30 ESP vs. Mobil 1 0w40 ESP [Re: Floydian] #4517955
09/16/17 04:05 PM
09/16/17 04:05 PM
USA
slacktide_bitog Offline
USA
What year is your Mini Cooper S? What spec does it say to use? Does it use LL-01 like US-market MCS calls for? What are your driving conditions? smile
Re: Mobil 1 5w30 ESP vs. Mobil 1 0w40 ESP [Re: Floydian] #4517968
09/16/17 04:32 PM
09/16/17 04:32 PM
Great Lakes
Great Lakes
Sulphated Ash, Phosphorous, Sulphur
Re: Mobil 1 5w30 ESP vs. Mobil 1 0w40 ESP [Re: slacktide_bitog] #4517976
09/16/17 04:40 PM
09/16/17 04:40 PM
Outside U.S
Floydian Offline OP
Floydian  Offline OP
Outside U.S
Actually it is not a Mini Cooper S but a BMW 1.20i with the N13 engine (Same as N18 engine found in the Mini Cooper S only it is mounted longitudinally.) I mentioned my car as a Mini Cooper S as the 1 series is not sold in the U.S and not to confuse you guys. smile
Re: Mobil 1 5w30 ESP vs. Mobil 1 0w40 ESP [Re: Floydian] #4517978
09/16/17 04:42 PM
09/16/17 04:42 PM
Great Lakes
Great Lakes
OK, but viscosity grades aside, does it call for any particular mfg spec such as BMW LL-01 or LL-04?
Re: Mobil 1 5w30 ESP vs. Mobil 1 0w40 ESP [Re: Quattro Pete] #4517993
09/16/17 04:56 PM
09/16/17 04:56 PM
Outside U.S
Floydian Offline OP
Floydian  Offline OP
Outside U.S
LL-01, LL-01 FE, LL-04.
Re: Mobil 1 5w30 ESP vs. Mobil 1 0w40 ESP [Re: Floydian] #4517994
09/16/17 04:57 PM
09/16/17 04:57 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
The owners manual will not only give a viscosity, it should also give a BMW oil specification.
BMW LL-01 is a high SAPS oil with Euro ACEA A3/B4 spec
BMW LL-04 is a low or mid SAPS oil with Euro C3 spec
Those M1 ESP oils are C3 oils. Good oils of that is what you are looking for. But so are the high SAPS (non-ESP) versions if that is preferred.
May I ask what country you live in and what is the sulphur content of your fuel ?
If high sulphur I would run an A3/B4 and BMW LL-01 oil.
If low sulphur fuel then the C3 with BMW LL-04 is fine.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Mobil 1 5w30 ESP vs. Mobil 1 0w40 ESP [Re: SR5] #4518003
09/16/17 05:07 PM
09/16/17 05:07 PM
Outside U.S
Floydian Offline OP
Floydian  Offline OP
Outside U.S
10mg/kg according to state refinery report. I have no idea if this is high or low. I live in Istanbul, Turkey. Summers here are usually between 27 C - 35 C while in winters it can get cold as -5 C.
Full report of the petrol found here is in the link:
https://www.tupras.com.tr/uploads/Urunler_en/UNLEADED_MOTOR_GASOLINE_95_RON-243.pdf
