Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
69 registered members (AndyB, Astro_Guy, avi1777, alarmguy, 69Torino, 2015_PSD, 6 invisible), 800 guests, and 52 spiders.
Topics286,106
Posts4,902,673
Members67,563
Most Online2,967
Mar 10th, 2019
Gear lube in engine oil #4517873
09/16/17 01:43 PM
09/16/17 01:43 PM
Ontario
Ccruji Offline OP
Ccruji  Offline OP
Ontario
I have a 75hp Mercury 4 stoke. I changed the oil and filter and added 5 litres of new oil. I needed a little more to top it off but unfortunately I grabbed my gear lube. I quickly caught myself but probably added 50ml of gear oil to the engine oil. Question, am I ok to run the engine with this little bit of gear oil or do I need to drain and add new oil? Thanks
Re: Gear lube in engine oil [Re: Ccruji] #4517879
09/16/17 01:53 PM
09/16/17 01:53 PM
Texas
Neely97 Offline
Neely97  Offline
Texas
That is under 2 ounces , that isn't much.
My only experience with this was years ago at a car dealer, the bulk oil tank for 30 w got filled with 90 gear.
Several vehicles came back with damaged engines .
6.7 cummins, Toyota 4 runner
FUMOTO
Re: Gear lube in engine oil [Re: Ccruji] #4517903
09/16/17 02:42 PM
09/16/17 02:42 PM
USA
ArcticDriver Offline
USA
5 Liters = 5,000 mL oil and 50 mL gear oil.
So you added slightly less than 1% gear oil (please check my math).
I would not worry about it in my boat and I have Mercs.
10w30 or 25w40 ?
Multiple Diesel and Gasoline vehicles
Re: Gear lube in engine oil [Re: Ccruji] #4517910
09/16/17 02:53 PM
09/16/17 02:53 PM
Ontario
Ccruji Offline OP
Ccruji  Offline OP
Ontario
It was 25w40. Thanks
Re: Gear lube in engine oil [Re: Ccruji] #4517920
09/16/17 03:07 PM
09/16/17 03:07 PM
USA
USA
Follow-up.
Now you have me wondering what the effect will actually be. grin
Is it the Mercury High Performance Gear Lube SAE-90 or the Premium 80W90 ? I am assuming you use premium for outboards?
For some reason these two are not be mixed:
https://www.mercurymarine.com/en/us/part...ants/gear-lube/
I don't think 1% is enough to matter but lets see what a tribologist says.
Edit:
I am running by West Marine shortly and I will ask them why the two lubes can't be mixed. That might provide some insight as to they will countersct with motor oil.
Re: Gear lube in engine oil [Re: Ccruji] #4517924
09/16/17 03:11 PM
09/16/17 03:11 PM
ME
eljefino Offline
eljefino  Offline
ME
Gear lube has sulfur in it which will attack your engine internals. How much, IDK, but it's not good.
Re: Gear lube in engine oil [Re: Ccruji] #4517948
09/16/17 03:43 PM
09/16/17 03:43 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
I would change it before winter storage.
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: Gear lube in engine oil [Re: MolaKule] #4517964
09/16/17 04:24 PM
09/16/17 04:24 PM
USA
USA
Good to know but the OP lives in FL, his winter may not be the winter you think. grin
Re: Gear lube in engine oil [Re: Ccruji] #4518118
09/16/17 07:54 PM
09/16/17 07:54 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I don't think it'll hurt anything. I have known many people who have added an entire quart to their car engines in the past.
Maybe run the OCI a little shorter than usual.
Re: Gear lube in engine oil [Re: ArcticDriver] #4518119
09/16/17 07:54 PM
09/16/17 07:54 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Ontario is in Canada.
Re: Gear lube in engine oil [Re: Linctex] #4518181
09/16/17 09:06 PM
09/16/17 09:06 PM
USA
USA
What the heck, I could have sworn it said Orlando.
Guess its time to get a stronger eyeglass prescription. grin
Re: Gear lube in engine oil [Re: Ccruji] #4520371
09/19/17 02:36 PM
09/19/17 02:36 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Gear lube and yellow metals may not be compatible (depends on the lube)... 25W-40 is stout oil and the add pak will likely absorb the gear oil OK. I would not be concerned as this is tiny dose.
But I'd try real hard not to do it again laugh
