2014 Mazda5 Valvoline Synpower 0W-20 7500 miles
by PWMDMD
06/22/18 10:54 PM
VOA Ravenol ECS 0W-20
by PWMDMD
06/22/18 10:47 PM
2020 mid-engine Corvette spy vid?!
by AZjeff
06/22/18 10:45 PM
'05 base impala. NO turn signals.FAST blinking.
by Lee4212
06/22/18 10:34 PM
Motul 15w-50, 5 Liter 4 Pack $19.42
by hatt
06/22/18 10:10 PM
High Lead Redline 5W40 thoughts? Ty
by Pajero
06/22/18 09:40 PM
Source of the Mighty Columbia River
by Snagglefoot
06/22/18 09:32 PM
Another thick/thin article to discuss
by JLTD
06/22/18 09:23 PM
Ethylene Glycol Long Life Coolant for KUBOTA
by pburchett
06/22/18 09:11 PM
Mobil 1 5W-30, 6,200 mi, 2017 2.3 EB Explorer
by Whimsey
06/22/18 08:48 PM
Chevron 10w-40, 97 Nissan Maxima, 3000 miles
by OilGeek91
06/22/18 08:36 PM
Old green antifreeze in garage storage is gelling
by JLawrence08648
06/22/18 08:32 PM
VWs at Pick n Pull
by Eric Smith
06/22/18 08:17 PM
Single Data Point: CK-4 destroys the flat tappet
by Gokhan
06/22/18 08:12 PM
Breaking in new short block
by Bub
06/22/18 07:00 PM
Should I buy a mill or a drill press?
by Vern_in_IL
06/22/18 06:32 PM
Weber Q300 Grill Parts Help
by gathermewool
06/22/18 05:24 PM
I Had To Tell Somebody- Banquet
by Zee09
06/22/18 05:13 PM
Xfinity mobile cell service
by jay929
06/22/18 04:37 PM
Fuse "failure"
by dlundblad
06/22/18 04:32 PM
azzid0906, OilGeek91, DRancher, Newuser, Varbill
65299 Registered Users
77 registered (4WD, 2015_PSD, ag_ghost, 92saturnsl2, 69Torino, 6 invisible), 1270 Guests and 31 Spiders online.
65299 Members
67 Forums
285812 Topics
Page 1 of 2 1 2 >
#4517871 - 09/16/17 01:38 PM 6 month old battery corrosion on (+) terminal
mclasser Offline
Loc: The Northeast
This is on my Pilot; battery's from Batteries Plus (East Penn). I cleaned and polished the cables during installation and coated everything w/dielectric grease.
Why would a relatively new battery start fuzzing up so soon, that too an East Penn? The factory JCI Honda battery didn't start doing this until the last year of its life.
2018 Hyundai Elantra VE -- 3K
2013 Honda Pilot EX-L 4WD -- 55K
2002 Honda Accord EX-L -- 210K
#4517877 - 09/16/17 01:48 PM Re: 6 month old battery corrosion on (+) terminal [Re: mclasser]
bbhero Offline
Loc: Virginia
Possibly over tightening the connection of the battery cable to the post?? That could be a possibility.
Edited by bbhero (09/16/17 01:49 PM)
Nissan Altima 3.5 Coupe Valvoline Advanced Full Synthetic 5w30 Federated Auto 4612ex
"Treat your family like your friends and treat your friends like your family."
#4517888 - 09/16/17 02:22 PM Re: 6 month old battery corrosion on (+) terminal [Re: mclasser]
ArcticDriver Offline
Loc: USA
I don't think this is very surprising but is it happening on both terminals or just one? If the negative it can be sign of a failing alternator and positive is overcharging.
Are you terminals clean? Is it possible that corrosion has moved into the cable and below the insualtion further back from the terminal and causing resistance? Maybe check the level of the cells as they can sometimes boil out onto the battery top and encourage what you are seeing.
Sounds like you are already doing good battery maintenance of washing it with a baking soda/water combo and wire brushing the terminals and the re-application of a grease?
Multiple Diesel and Gasoline vehicles
#4517893 - 09/16/17 02:33 PM Re: 6 month old battery corrosion on (+) terminal [Re: mclasser]
SatinSilver Offline
Loc: OH
I had the same thing happen on an Exide battery which is common on those apparently. But 5 years later it's still clicking along just fine. The spray protectants wouldn't last very long. Had Walmart TLE do their NOCO battery treatment service and zero corrosion since then. That was a few years ago. They clean the terminals, install the felt washers and put a nice thick protectant on them. I did both cars since the JCI on the Camry was starting to fuzz up as well.
#4517914 - 09/16/17 02:59 PM Re: 6 month old battery corrosion on (+) terminal [Re: mclasser]
bubbatime Offline
Loc: South Florida
This stuff is what you need. No more green fuzz after applying. Best stuff I have ever used. Much better than dielectric grease, as it continues working long after applied. Use the battery cleaner, then the battery protector.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
#4517957 - 09/16/17 04:10 PM Re: 6 month old battery corrosion on (+) terminal [Re: mclasser]
Kuato Offline
Loc: Colorado
After you clean it off, glue a penny near the positive terminal. The penny will attract the corrosion.
Thick vs Thin test: 15k / 43k miles complete
#4517961 - 09/16/17 04:16 PM Re: 6 month old battery corrosion on (+) terminal [Re: Kuato]
SatinSilver Offline
Loc: OH
I tried that before having the NOCO treatment done. Didn't help at all in my case. Then some yutz took it off while having some service done to the car. And said something along the lines of, good news we saved you some money today. Hands me a penny and said we found it on the battery with a big smile on his face. I said yes I put it there on purpose to keep the corrosion off of it.
Edited by SatinSilver (09/16/17 04:19 PM)
#4517975 - 09/16/17 04:39 PM Re: 6 month old battery corrosion on (+) terminal [Re: mclasser]
bullwinkle Offline
Loc: Cincinnati, OH, USA
Dang-this problem is why I switched from JC to East Penn for new batteries, the JC ones were leaking everywhere, even without being overcharged.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
#4517985 - 09/16/17 04:46 PM Re: 6 month old battery corrosion on (+) terminal [Re: bbhero]
HerrStig Offline
Loc: Boston, MA
+1 You don't have to lean on the wrench.
#4518022 - 09/16/17 05:39 PM Re: 6 month old battery corrosion on (+) terminal [Re: mclasser]
ejes Offline
Loc: Kansas
Almost always caused by over-tightening the cable to the posts.
#4518041 - 09/16/17 06:08 PM Re: 6 month old battery corrosion on (+) terminal [Re: mclasser]
NHGUY Offline
Loc: USA
I blame the auto parts chains for the battery post leakage.They stack batteries at the bottom of a pallet with everything else stacked atop them.Not so bad for batteries like VW/Audi that have recessed posts (Or GM Sideposts),but everything else with posts standing proud atop the battery case are susceptible to 100s of pounds of load.
#4518160 - 09/16/17 08:49 PM Re: 6 month old battery corrosion on (+) terminal [Re: mclasser]
kb27 Offline
Loc: Singapore
Over-tightening and weak seal.
My battery supplier originally use this. We get quite a lot of corrosion leakage.
Then they change to this, presumably less prone to leakage.
#4518309 - 09/17/17 04:46 AM Re: 6 month old battery corrosion on (+) terminal [Re: Kuato]
Loc: USA
Are you sure about this?
#4518864 - 09/17/17 06:58 PM Re: 6 month old battery corrosion on (+) terminal [Re: mclasser]
mclasser Offline
Loc: The Northeast
I cleaned up the battery today and carefully re-tightened the connections in-case I over-tightened them initially. My tool-of-choice for battery connections is a small 10 mm wrench. I give the nuts a final snugging with 2 fingers on the wrench.
Now I have to get the OBDII drive cycles ready again since my inspection's due by the end of the month.
Edited by mclasser (09/17/17 07:01 PM)
#4518877 - 09/17/17 07:13 PM Re: 6 month old battery corrosion on (+) terminal [Re: ArcticDriver]
JustinH Offline
Loc: Texas
Aren't pennies less and less copper than the old days?
'11 Hyundai Sonata GLS
'11 Scion XB
Page 1 of 2 1 2 >
