Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
111 registered members (1978elcamino, Alfred_B, ABerns, Agnosto, 2015_PSD, 17 invisible), 2,431 guests, and 63 spiders.
Topics286,019
Posts4,900,954
Members67,548
Most Online2,967
Mar 10th, 2019
Understanding gears #4517754
09/16/17 11:20 AM
09/16/17 11:20 AM
MA.
Camprunner Offline OP
MA.
I was wondering about rear end gear ratios for example my 2013 Mustang GT has a 3:73 rear axle ratio so does that mean that the rear wheel turns 3:73 times for every one revolution of the engine? I know that 3:73 is a lower gear then the other ratios for the Mustang being 3:55 or 3:33 and it gives you more acceleration off the line with the negative being lower fuel millage. But I don't quite understand how to explain it? Is 3:73 where one wheel turns 3:73 times with one complete engine revolution?
Thanks!
Re: Understanding gears [Re: Camprunner] #4517757
09/16/17 11:27 AM
09/16/17 11:27 AM
Texas
4WD Offline
4WD  Offline
Texas
Ring 41 teeth - pinion 10 teeth 41/10= 4.10 gear ratio
Re: Understanding gears [Re: Camprunner] #4517758
09/16/17 11:28 AM
09/16/17 11:28 AM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
Google is your friend
If your ratio is 3.73, the drive shaft turns 3.73 times for each turn of the rear wheel.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Understanding gears [Re: Camprunner] #4517764
09/16/17 11:45 AM
09/16/17 11:45 AM
out there
spasm3 Online content
spasm3  Online Content
out there
3.73 turns of the drive shaft for each 360 of the wheel/axle.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: Understanding gears [Re: Camprunner] #4517772
09/16/17 11:53 AM
09/16/17 11:53 AM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
It's the ratio of input vs. output speed of the differential - 3.73 tevs of the driveshaft to one of the wheels. Whether that correlates to engine RPM's depends what the transmission is. A manual transmission with no overdrive, in high gear? Yes. Non-overdrive automatic? Slightly higher engine speed. Overdrive? Engine RPM will be lower to the tune of whatever the transmission's OD ratio is.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Understanding gears [Re: 69GTX] #4517774
09/16/17 11:54 AM
09/16/17 11:54 AM
USA
ArcticDriver Offline
USA
I say half right.
The explanation was right on the money but the part about Google being our friend is a claim I ambeginning to doubt.
A friend respects your privacy.
grin
Multiple Diesel and Gasoline vehicles
Re: Understanding gears [Re: Camprunner] #4517785
09/16/17 12:06 PM
09/16/17 12:06 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Thanks!
Numbers above are correct....a higher ratio, say 4:11 to 1, allows the driveshaft to turn faster than a 3.73, so it is easier for the engine to accelerate the vehicle. You lose (potentially) some top speed and mpg at the expense of that performance.
Thick vs Thin test: 15k / 43k miles complete
Re: Understanding gears [Re: Camprunner] #4517790
09/16/17 12:10 PM
09/16/17 12:10 PM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
Yep. Not as important today with multi speed transmissions. My 2014 RAM has a 3.91 rear gear and with two overdrives it is still happy at highway speeds.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: Understanding gears [Re: Camprunner] #4517816
09/16/17 12:36 PM
09/16/17 12:36 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Thanks!
Drive shaft turns 3.73 times for each revolution of the axles .
Best wishes , :-)
Wyr
God bless
Re: Understanding gears [Re: SteveSRT8] #4517819
09/16/17 12:40 PM
09/16/17 12:40 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Tire diameter plays an important part , too . The larger the tire diameter , the further the car travels with each revolution of the tire .
As far as engine rpm , this has the same effect as a slightly lower numeric deferential ratio .
Best wishes , :-)
Wyr
God bless
Re: Understanding gears [Re: WyrTwister] #4517865
09/16/17 01:31 PM
09/16/17 01:31 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
Just to punctuate this thread-not to highjack it.
My Dad had a 1970 Mercury Monterey 400-2V (spelled OINK-OINK) which had a 1.75 rear end. It had the C6 transmission.
Even cars with "economy rear axles" (some Cadillacs were so marketed during a gas shortage) weren't as long legged as that Mercury.
Anybody experience a higher rear axle ratio?
Re: Understanding gears [Re: Camprunner] #4517875
09/16/17 01:46 PM
09/16/17 01:46 PM
The Canyons
02SE Offline
02SE  Offline
The Canyons
I believe the tallest gear set Mercury offered was 2.50:1.
I know of taller custom gear sets in custom differentials, than 1.75:1, but they are in Landspeed vehicles.
Re: Understanding gears [Re: Camprunner] #4517936
09/16/17 03:26 PM
09/16/17 03:26 PM
ME
eljefino Online content
eljefino  Online Content
ME
I've always figured the actual proper terminology would be 1:3.73 but the 1: gets dropped in casual notation.
Motor trend etc when they do a car test will list a chart that includes "engine RPM at 60 MPH in high gear" to combine the cumulative effects of overdrive transmissions, tire size, and axle ratio.
Re: Understanding gears [Re: Kira] #4517959
09/16/17 04:14 PM
09/16/17 04:14 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
That's the tallest ratio I've heard of. I know some Chrysler products from the 70s had 2.76.
My brother built a 440 into an early 70s Road Runner....727 automatic and 3.21, it would chirp leave long black streaks (as the rear end walked sideways a bit) on the road when it shifted into third gear. At around 120mph.
Re: Understanding gears [Re: 02SE] #4518071
09/16/17 06:52 PM
09/16/17 06:52 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
As a teen ager , I drove a 1966 Comet 289 . The rear end ratio was numerically slightly smaller that 3 : 1 . Had 14" wheels which partially compensated for the high differential gearing .
Best wishes , ;-)
Wyr
God bless
