Replaced halogen headlight with LED
by gman2304
06/22/18 11:18 AM
Web Archive
by Duffyjr
06/22/18 10:25 AM
Sonoma This weekend!
by racin4ds
06/22/18 10:22 AM
low water pressure on new kitchen faucet
by Joe1
06/22/18 09:40 AM
Flashing third tail light
by Brigadier
06/22/18 08:59 AM
Intermittent AC Cooling
by Gebo
06/22/18 08:59 AM
Who includes full size spare in tire rotation?
by Parlay_Slow
06/22/18 08:45 AM
Crude and foul behavior
by mjoekingz28
06/22/18 08:31 AM
Best Off The Shelf Car Wash Liquid ?
by ChrisD46
06/22/18 08:30 AM
Wrecking Yards
by Snagglefoot
06/22/18 08:26 AM
F1 - 2018 French Grand Prix
by gofast182
06/22/18 08:14 AM
AAP 25% Off
by Egg_Head
06/22/18 06:03 AM
GM Ecotec 2.4 - Cracked Exhaust Manifold
by The Critic
06/22/18 05:05 AM
Half Price - Shell Helix HX7, Castrol Edge and GTX
by SR5
06/22/18 03:59 AM
Why hang your bicycle from the ceiling?
by mjoekingz28
06/22/18 03:47 AM
Oil For High Sustained RPM on BMW S52
by ZEK
06/21/18 10:41 PM
Chevy brought the blazer back
by WiskyBadger
06/21/18 10:07 PM
LC20 and uses in modern motor oil
by synman
06/21/18 10:01 PM
Full Synthetic CJ-4 or > 5W-30 or 10W-30
by LeTempt
06/21/18 09:57 PM
2018 RAM 1500 EcoDiesel
by OVERKILL
06/21/18 08:37 PM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
72 registered (2012AccentSE, 4WD, bdcardinal, asiancivicmaniac, Al, beanoil, 3 invisible), 1477 Guests and 37 Spiders online.
65294 Members
67 Forums
285764 Topics
#4517643 - 09/16/17 08:22 AM 2012 Burgman 400
Jarlaxle Offline
Loc: New England
First oil analysis on my Burg...~18,000 miles on the bike, about 2600 on the oil. Oil was Maxima 10W-40 MC (JASO MA2) oil.
First: Blackstone's comments...
Quote:
This a fine first look at your Burgman scooter. Universal averages show typical wear results for this
type of Suzuki motor with oil run ~2,200 miles. Using those as a reference, you've got metals reading either
at the same level or lower, and that shows internal parts that are getting along well together. The only
(minor) issue here is a low viscosity, but that's not uncommon for engines like these and it clearly hasn't
caused any trouble, so no worries there. No fuel or coolant was detected and insolubles (solid material)
measured at just a trace. Nice report!
I might switch to 15W-40 in the future, due to shearing.
Numbers...
Aluminum: 1
Chromium: 0
Iron: 16
Copper: 5
Lead: 0
Tin: 0
Moly: 4
Nickel: 0
Manganese: 0
Silver: 0
Titanium: 0
Potassium: 4
Boron:18
Silicon: 5
Sodium: 22
Calcium: 1731
Magnesium: 38
Phosphorus: 971
Zinc: 1140
Barium: 0
Viscocity @210F: 54.9
Viscocity @100C: 8.74
Flashpoint: 390
Fuel: <0.5%
Coolant: 0
Water: 0
Insolubles: Trace
1979 Coupe de Ville, 542 stroker, Super Tech 15W40, Delco
2011 Crown Vic P71, 5W-20 NextGen, Motorcraft
2014 Harley Sportster 1200T, dealer fill
#4517648 - 09/16/17 08:33 AM Re: 2012 Burgman 400 [Re: Jarlaxle]
spasm3 Offline
Loc: North Carolina
Looks good but it did shear down quite a bit. I would try a 15w40.
13 elantra 68k 5w30 QSUD
03 chevy avalanche76k synpwr 10w30
01 saturnsc1 185k synpwr rebuilt
17 mazda cx-5 3900 miles m1 0w20/0w40 mix
#4517653 - 09/16/17 08:38 AM Re: 2012 Burgman 400 [Re: Jarlaxle]
Jarlaxle Offline
Loc: New England
That's the plan. The engine is a super-high revver...if not idling, it's over 3500RPM and usually 5000+. It spins 7000+ on the highway, and redlines at 9200. Also, it only holds about 1.25 quarts. (There is no wet clutch.)
#4517775 - 09/16/17 11:57 AM Re: 2012 Burgman 400 [Re: Jarlaxle]
jeff78 Offline
Loc: New York
[censored], that oil got destroyed - 8.74 cst makes it a 20. But it could just be that this particular oil is more shear-prone. And the small sump capacity doesn't help.
I'm not too familiar with the Burgman, does it use a belt CVT?
Definitely try the 15W-40. Or even a monograde 40 if it's not going to see freezing starts.
#4517861 - 09/16/17 01:26 PM Re: 2012 Burgman 400 [Re: Jarlaxle]
bubbatime Offline
Loc: South Florida
I wonder if a 10W40 synthetic would shear less?
I'd probably just run cheap 15W40 in it and change it every 1500 miles.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
#4518162 - 09/16/17 08:52 PM Re: 2012 Burgman 400 [Re: Jarlaxle]
Jarlaxle Offline
Loc: New England
Yes: belt and roller CVT, like a snowmobile.
I used to run synthetic: unfortunately, it drank it. (For some reason, not that unusual on B400s.) Next change will be with 15W-40, probably Rotella.
#4613616 - 12/25/17 06:14 AM Re: 2012 Burgman 400 [Re: Jarlaxle]
Sealbilly Offline
Loc: EasTn
I ran rotella T6 in my Burgman, you right, it drank it. I switched to T5 15w40 and consumption went way down.
