Any news on what happened to this plane?
by Exhaustgases
Today at 02:36 AM
E4OD fluid ?
by Exhaustgases
Today at 02:23 AM
Update password ?
by meadows
Yesterday at 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
Yesterday at 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
Yesterday at 10:40 PM
revive Nicd battery
by Donald
Yesterday at 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
Yesterday at 10:07 PM
ceratec with redline 5w30?
by 08z06
Yesterday at 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
Yesterday at 09:50 PM
I hate stuck thermostats
by jakewells
Yesterday at 09:49 PM
Mag1 75w90
by SavagePatch
Yesterday at 09:32 PM
Old batteries at HD
by bbhero
Yesterday at 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
Yesterday at 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
Yesterday at 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
Yesterday at 08:13 PM
Shure stylus replacement
by aquariuscsm
Yesterday at 07:54 PM
Any 'crazy UCL overdose' fans out there?
by addyguy
Yesterday at 07:11 PM
Source for Castrol Edge Supercar 5w50 oil?
by Rainier42
Yesterday at 06:50 PM
Cherry vs orange hand cleaner
by JHZR2
Yesterday at 06:27 PM
Why buy low mileage tires?
by HowAboutThis
Yesterday at 05:49 PM
mostdecent, T1TN, Piper58, dunlop0078, Truth_Syrup
65258 Registered Users
26 registered (Char Baby, d00df00d, Buzzinhalfdozen, BoiseBound, Brad_C, 3 invisible), 691 Guests and 29 Spiders online.
65258 Members
67 Forums
285504 Topics
#4517640 - 09/16/17 08:12 AM 01 Tahoe - fresh air blend door issue (?)
mjk Offline
Loc: Wishin' I was in Wi
A problem started yesterday afternoon. As I left a gas station, I started to get a loud clicking noise from behind the glove box. It sounds a bit like a relay being tripped, about 1 click per second.
Turning the HVAC controls to recirculate eliminates the problem.
In doing a search, it sounds like a fresh air actuator is shot? I also heard the entire dash might have to be removed to replace it.
Any thoughts or ideas are appreciated. I am going into my mechanic on Monday, I am just trying to prepare myself for the worst.
Appreciate it.
#4517672 - 09/16/17 09:05 AM Re: 01 Tahoe - fresh air blend door issue (?) [Re: mjk]
Warstud Offline
Loc: MIchigan
You might be able to access it by removing the lower panel on the drivers side.
#4517689 - 09/16/17 09:30 AM Re: 01 Tahoe - fresh air blend door issue (?) [Re: mjk]
Chris142 Offline
Loc: Deplorable in apple valley, ca
Its the teeth in the actuator. Depending on which one is bad the dash may have to be layed back to get to it. We get 6 hrs and replace all while its opened up. There is 1 that can be done without removing the dash.
Edited by Chris142 (09/16/17 09:31 AM)
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#4517704 - 09/16/17 09:47 AM Re: 01 Tahoe - fresh air blend door issue (?) [Re: mjk]
JohnnyJohnson Offline
Loc: Wet side WA
Appreciate it.
Yes I was talking to a guy at NAPA just yesterday. They problem with new cars is they run pretty well but its all this kind of carp that kills cars and makes them unmaintainable in 8 to 12 years. So next time your looking for that shiny new ride pick the basic model without all the bells and whistles and you'll still be driving it in 20 years if you want to be.
2004 Toyota Corolla 121525
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74016
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4517726 - 09/16/17 10:25 AM Re: 01 Tahoe - fresh air blend door issue (?) [Re: mjk]
LeakySeals Offline
Loc: Hudson, NH
Hopefully its just the blend door actuator. Pretty easy fix for DIY.
https://www.2carpros.com/articles/replace-blend-door-motor
06 Escalade 6.0L AWD 160k. M1 5w30 Fram TG
03 Maxima 3.5L 149k ST HM 10w30
#4517810 - 09/16/17 12:29 PM Re: 01 Tahoe - fresh air blend door issue (?) [Re: mjk]
Warstud Offline
Loc: MIchigan
A cheap fix is to rotate the Gear instead of replacing.
#4517844 - 09/16/17 01:08 PM Re: 01 Tahoe - fresh air blend door issue (?) [Re: mjk]
WyrTwister Offline
Loc: Texas
If the part is reasonably priced , if I managed to get to the old one , I would replace it , not just turn the gear .
But it is your money , each to his / her own .
Best wishes , :-)
Wyr
God bless
#4517937 - 09/16/17 03:26 PM Re: 01 Tahoe - fresh air blend door issue (?) [Re: LeakySeals]
mjk Offline
yeah, unfortunately, it isn't that one. All my HVAC works correctly, it is the actuator that must open/close the fresh air intake....
It is right behind the glove box. I can put my hand on the black box behind it, and feel the actuator trying to work.
#4517944 - 09/16/17 03:39 PM Re: 01 Tahoe - fresh air blend door issue (?) [Re: mjk]
Nick1994 Offline
Loc: Phoenix, AZ
Yup, those GM door actuators are always going out.
2015 Hyundai Sonata 2.4L 79k PU 5w30 & OEM
2000 Toyota Camry 2.2L 228k M1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 146k M1 HM 10w40 & Fram Ultra
#4518487 - 09/17/17 11:00 AM Re: 01 Tahoe - fresh air blend door issue (?) [Re: Nick1994]
Warstud Offline
Loc: MIchigan
It's 16 years old....somethings bound to break.
#4518488 - 09/17/17 11:03 AM Re: 01 Tahoe - fresh air blend door issue (?) [Re: mjk]
WyrTwister Offline
Loc: Texas
Would be nice if they made those gears out of metal , preferably ferrous metal .
Best wishes , :-)
Wyr
God bless
#4518529 - 09/17/17 11:57 AM Re: 01 Tahoe - fresh air blend door issue (?) [Re: WyrTwister]
Chris142 Offline
Best wishes , :-)
then the blend door would break instead.
#4518538 - 09/17/17 12:07 PM Re: 01 Tahoe - fresh air blend door issue (?) [Re: Chris142]
Warstud Offline
Loc: MIchigan
Best wishes , :-)
Kinda like a shear pin? Weak point.
#4518662 - 09/17/17 02:56 PM Re: 01 Tahoe - fresh air blend door issue (?) [Re: Chris142]
WyrTwister Offline
Loc: Texas
Best wishes , :-)
You could be correct . :-(
Best of luck to you , :-)
Wyr
God bless
