Michelin jack won't lift a load
by 10WSmuckers. 09/23/18 01:32 AM
Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
26 registered members (BlakeB, Billbert, ArrestMeRedZ, CleverUserName, Astro14, ctechbob, 1 invisible), 731 guests, and 41 spiders.
Topics290,867
Posts4,851,572
Members66,044
Most Online3,590
Jan 24th, 2017
Oil Cooler on Harley Davidson #4517556
09/16/17 02:38 AM
09/16/17 02:38 AM
Girard, Ill
yankees1 Offline OP
yankees1  Offline OP
Girard, Ill
How efficient are these and wouldn't it be more efficient with a fan activated cooler instead of the no fan cooler as installed on 2018 Harleys ? Most of my riding will be non stop and go or heavy traffic.
Re: Oil Cooler on Harley Davidson [Re: yankees1] #4517599
09/16/17 06:36 AM
09/16/17 06:36 AM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
Point of the fan is moving stagnant air. In motion you have air moving, no point of having a fan.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 100K Napa 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 20K VR1 20w50, NG1515
14 RX450h 33k PP MIX, NG7047
Re: Oil Cooler on Harley Davidson [Re: yankees1] #4517618
09/16/17 07:42 AM
09/16/17 07:42 AM
Deep in the heart of Jersey
BigCahuna Offline
BigCahuna  Offline
Harley has a unique way of dealing with heat related issues. A standard oil cooler works the same as a radiator in your car. When moving, air is directed across the fins and cools whatever fluid your trying to cool . Like Anti- freeze, trans fluid. Works the same way on a Harley for it's motor oil. Now a new stock Harley will give off alot of heat when run normally. The oil temperature is engineered to run in a certain range under normal use. If the motor gets too hot from slow or stop and go riding in hot areas, the rear cylinder will shut off, lessening the amount of heat felt by the rider.I'm guessing it was easier and cheaper to make that happen with the onboard computer, then to add a mechanical part to the bike. As long as your moving, air will pass over the oil cooler and remove heat.,,,
Re: Oil Cooler on Harley Davidson [Re: yankees1] #4517900
09/16/17 02:37 PM
09/16/17 02:37 PM
AZ
leroyd92 Offline
leroyd92  Offline
AZ
Add a 12" dual pass cooler.
Fastest way to drop 50 to 80F from the oil...
My 18" dropped 280 down to 180. durring the 120 summer
Supertech Junky
