Toyota Genuine oil 10W30
by gordond. 09/22/18 09:27 AM
Good Dealers
by HowAboutThis. 09/22/18 09:12 AM
electric brakes rely on heat to work?
by motor_oil_madman. 09/22/18 09:09 AM
help please 7.25 briggs idle too fast
by edwardh1. 09/22/18 08:49 AM
Java update and Flash not working
by JLTD. 09/22/18 08:47 AM
Bought a Giulia
by RamFan. 09/22/18 08:38 AM
by gordond. 09/22/18 08:37 AM
Mobil 1 Extended Protection High Mileage Test
by njohnson. 09/22/18 07:57 AM
WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Craigslist time wasters
by Anduril. 09/21/18 09:41 PM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
88 registered members (2015_PSD, 77GrandPrix, 53' Stude, 2004tdigls, 2013ecof150, 14Accent, 9 invisible), 1,679 guests, and 40 spiders.
Topics290,820
Posts4,850,928
Members66,040
Most Online3,590
Jan 24th, 2017
trailer brake controller sticking? #4517440
09/15/17 09:31 PM
09/15/17 09:31 PM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
Recently it's been doing this at low speeds. i'll have it set at like 8 and boost at 1 and I'll find that it will go all the way to 4 with just a slight touch of the pedal going like 10mph. I don't get it. It seems to be okay at faster speeds, but it's kind of annoying. Usually it will be at like 1.5-2.0 at low braking speeds.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: trailer brake controller sticking? [Re: motor_oil_madman] #4517442
09/15/17 09:32 PM
09/15/17 09:32 PM
Houston, Texas
Houston, Texas
I wouldn't say that sticking is the correct term, it just applies more than it usually does.
Re: trailer brake controller sticking? [Re: motor_oil_madman] #4517445
09/15/17 09:35 PM
09/15/17 09:35 PM
Houston, Texas
Houston, Texas
Why does it do this? One thing I noticed is if you change the angle of the controller it will change the amount it brakes just sitting still, so maybe I'm bumping it with my knee when I get in the truck and not realizing it? I think this is when it occurs, then it goes back to normal after a few stops.
Re: trailer brake controller sticking? [Re: motor_oil_madman] #4517450
09/15/17 09:43 PM
09/15/17 09:43 PM
Georgia
AVB Offline
AVB  Offline
Georgia
Some brake controllers have inertia switches in them and need to be mounted in a certain position.
Re: trailer brake controller sticking? [Re: motor_oil_madman] #4517485
09/15/17 11:07 PM
09/15/17 11:07 PM
Utah
CKN Offline
CKN  Offline
Utah
try www.etrailer.com
lots of help there
Re: trailer brake controller sticking? [Re: motor_oil_madman] #4517486
09/15/17 11:09 PM
09/15/17 11:09 PM
Houston, Texas
Houston, Texas
It's a prodigy p3. Maybe I need to secure it better. I may not have used the lock washers that came with it. I can't remember. It stays put as long as you don't bump it
Re: trailer brake controller sticking? [Re: motor_oil_madman] #4517508
09/15/17 11:33 PM
09/15/17 11:33 PM
Houston, Texas
Houston, Texas
The brakes also lock up in reverse. I got out thinking I backed into something. It feels like I ran into a curb.
Re: trailer brake controller sticking? [Re: motor_oil_madman] #4517692
09/16/17 09:33 AM
09/16/17 09:33 AM
Alberta
tcp71 Offline
tcp71  Offline
Alberta
My prodigy had a boost type of setting for initial engagement strength. Your P3 has the same and it is set too high. From tekonsha:
5 storable setting options for pulling different trailers or preferences of multiple drivers.
A distinct, easy-to-read LCD display with multiple screen color options.
Up-Front controls provide easy access to all P3 features.
Easy to understand diagnostics show output current, battery, brake, and output voltage.
A flashing red warning system alerts user to No Trailer Brake situations.
Select Electric over Hydraulic or Electric trailer brake mode.
Screen information display in English, French or Spanish.
The Original Boost feature allows for different levels of customized braking.
Compact, dash-hugging design.
Integrated Plug-N-Play port for 2-plug adapters.
Snap-in mounting clip allows user to remove and store the control when not in use.
Electric trailer brake control for up to 4 braking axles.
Limited Lifetime Warranty
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: mobil 0w40 (varies)
Re: trailer brake controller sticking? [Re: motor_oil_madman] #4517694
09/16/17 09:36 AM
09/16/17 09:36 AM
North Carolina
spasm3 Offline
spasm3  Offline
North Carolina
Go back through the owners manual and installation manual. My prodigy is older, but it should be mounted with out any wiggle or movement. I think the newer ones are not as picky about mounting angle, but check it. I love my podigy and its an 05 model!
13 elantra 70k 5w30 QSUD
03 chevy avalanche79k synpwr 10w30
01 saturnsc1 185k synpwr rebuilt
17 mazda cx-5 5600 miles m1 0w30
Re: trailer brake controller sticking? [Re: motor_oil_madman] #4518187
09/16/17 09:10 PM
09/16/17 09:10 PM
Houston, Texas
Houston, Texas
It seems to be the boost doing it. I only have it at 1. I set it at 0 and found the brakes didnt really apply much even set at 8. So I don't know. Works great with the boost set at 1 except for it randomly overly applying at times.
