1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
30 registered members (citationxeleven, billt460, anndel, DirtyOilGuy, Cornershop, 3 invisible), 928 guests, and 31 spiders.
Topics296,903
Posts4,961,304
Members66,997
Most Online2,688
Jan 19th, 2019
2014 Jeep 3.2L Pentastar, PP 5W20 7600 mi #4517413
09/15/17 08:08 PM
09/15/17 08:08 PM
USA
fusseli Offline OP
fusseli  Offline OP
USA
Another OCI done. I ended this one early with 14% left on the OLM due to lots of dusty and offroad early this year.
Everything's in the clear, and my oil consumption has FINALLY reduced from 1.5 qts to 0.5 qts it really did take 30k for my rings to seat, I guess...
2014 Jeep Cherokee 3.2L - PPHM 5W20 & M1-456C, aFE ProDry CAI
1984 Ford Thunderbird 2.3L Turbo - Rotella T6 5W40 & MC FL300, MC FA970
Re: 2014 Jeep 3.2L Pentastar, PP 5W20 7600 mi [Re: fusseli] #4517613
09/16/17 06:28 AM
09/16/17 06:28 AM
pa
benjy Offline
benjy  Offline
pa
everything today is done for MPG's, low tension rings + thinner oils that prolly delay ring seal. girlfriends new in 13 malibu 2.5 was using 5-20, a qt in a thou, enter 10-30 a qt between yearly changes!!! once the warranty is gone manufactures care less when your engine dies or how much oil it uses, + DI can make it worse with higher compression, think oil spray on the back of your valves!!!
Re: 2014 Jeep 3.2L Pentastar, PP 5W20 7600 mi [Re: fusseli] #4517624
09/16/17 06:53 AM
09/16/17 06:53 AM
Virginia
bigt61 Offline
bigt61  Offline
Virginia
Good report - thanks for posting. Some will argue, but I still think rings break in better/faster on dino or blend. I switch over after 25,000 miles.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
Re: 2014 Jeep 3.2L Pentastar, PP 5W20 7600 mi [Re: fusseli] #4517736
09/16/17 09:47 AM
09/16/17 09:47 AM
WI
HoosierJeeper Offline
WI
Nice report. I'm VWB in mine (with Formula shell on the shelf for the next changes), 15k miles and it hasn't used a drop of oil between changes.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: 2014 Jeep 3.2L Pentastar, PP 5W20 7600 mi [Re: HoosierJeeper] #4517839
09/16/17 12:04 PM
09/16/17 12:04 PM
USA
fusseli Offline OP
fusseli  Offline OP
USA
Which oil is VWB?
Re: 2014 Jeep 3.2L Pentastar, PP 5W20 7600 mi [Re: fusseli] #4517876
09/16/17 12:46 PM
09/16/17 12:46 PM
Michigan, USA
Bighorn2500 Offline
Bighorn2500  Offline
Michigan, USA
Which oil is VWB?
Valvoline white bottle I'm guessing.
Did you notice any change with the aftermarket air filter, silicone still appears to be controlled well with it according to the UOA. Been running the PP as well due to $2.99 a quart after rebate and sale pricing.
2012 Ram 2500 SLT 6.7L Cummins 4x4
2015 Jeep Cherokee 3.2L Latitude 4x4
Re: 2014 Jeep 3.2L Pentastar, PP 5W20 7600 mi [Re: fusseli] #4517883
09/16/17 01:05 PM
09/16/17 01:05 PM
USA
fusseli Offline OP
fusseli  Offline OP
USA
Unfortunately I don't have any UOAs from when I was using the OE paper filter. I asked Blackstone on my last UOA, which is probably why they mentioned it again this time, but they said silicone is healthily low and controlled. This is impressive to me, after offroading in Moab this spring I knocked a layer of fine dust off the filter-- which it is clearly keeping out of the engine cheers My two UOAs above are proof that the washable dry media filters don't let anything through as some people continue to believe.
And same here, the mail in rebate on the PP is too good of a deal. I would run pennzoil ultra but all I have off the shelf nearby is platinum, so I just run that.
I did switch to a Fram XG for this next OCI, we will see how it compares to the last two with the Mopar AB.
Re: 2014 Jeep 3.2L Pentastar, PP 5W20 7600 mi [Re: fusseli] #4819657
07/21/18 11:11 AM
07/21/18 11:11 AM
USA
fusseli Offline OP
fusseli  Offline OP
USA
Another one for the records, previous two oil changes were both PP 5w20 and Mopar AB oil filter, and AFE drop-in dry media air filter. This present analysis is from switching to a full AFE CAI dry media, and a Fram XG filter, and again PP 5w20. Notice how there's no increase in filterable particles or dirt in the oil, and how my numbers are lower than the universal averages or comparable.... OLM was at 9%. I've given up on my oil consumption and have decided 1qt of consumption is normal at 7k miles on my engine. Blackstone doesn't seem worried.
Re: 2014 Jeep 3.2L Pentastar, PP 5W20 7600 mi [Re: fusseli] #4820978
07/23/18 04:26 AM
07/23/18 04:26 AM
NJ
crainholio Offline
crainholio  Offline
NJ
Moly concentration in regular PP seems to be about half that of PP High Mileage...Blackstone showed 156 PPM in my PP HM 5W-30 sample from March.
edit: checked PQIA and this seems to be the case across the board with their testing of PP...moly < 100 PPM.
Re: 2014 Jeep 3.2L Pentastar, PP 5W20 7600 mi [Re: fusseli] #4822480
07/24/18 09:54 PM
07/24/18 09:54 PM
USA
fusseli Offline OP
fusseli  Offline OP
USA
Interesting you mention that, instead of PP I put in PP HM this time in its place. Wild hair I guess, and I'm wondering if it will have any effect on my oil burning.
Re: 2014 Jeep 3.2L Pentastar, PP 5W20 7600 mi [Re: fusseli] #4822485
07/24/18 10:02 PM
07/24/18 10:02 PM
Texas
4WD Offline
4WD  Offline
Texas
Can most of you imagine if this was an M1 run ? And did you notice the poor guy with single digit iron M1 post go by all crickets Im not saying Im a big UOA fan but the hypocrisy of a half dozen here ruins the site
Not a terrible run BTW
Re: 2014 Jeep 3.2L Pentastar, PP 5W20 7600 mi [Re: fusseli] #4822515
07/25/18 12:00 AM
07/25/18 12:00 AM
USA
fusseli Offline OP
fusseli  Offline OP
USA
What if it was an M1 run? Not sure what you mean
Re: 2014 Jeep 3.2L Pentastar, PP 5W20 7600 mi [Re: fusseli] #4822592
07/25/18 06:27 AM
07/25/18 06:27 AM
Atlanta
DuckRyder Offline
DuckRyder  Offline
Atlanta
He means that everyone would be freaking out over the iron readings which appear quite high on a PPM/1000mi basis. Do you know if this particular engine has a reputation for shedding iron? It appears it might based on the universal averages.
Robert
  • 2007 Toyota Prius Touring
  • 2005 Honda Civic Sedan
  • 1972 Ford F100
Re: 2014 Jeep 3.2L Pentastar, PP 5W20 7600 mi [Re: fusseli] #4822667
07/25/18 08:36 AM
07/25/18 08:36 AM
NJ
crainholio Offline
crainholio  Offline
NJ
Can't wait to see the oil analysis data with PP HM versus regular PP.
Re: 2014 Jeep 3.2L Pentastar, PP 5W20 7600 mi [Re: DuckRyder] #4822686
07/25/18 09:10 AM
07/25/18 09:10 AM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
I am quite surprised by this as well but like Duckryder mentions below, I am sure this engine, and the fact that a litre and and half had to be added between the OC, there is something up with this/these engines?
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
