The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
29 registered members (Agnosto, Bailes1992, carlprop, c502cid, chance, 4 invisible), 634 guests, and 62 spiders.
Topics286,097
Posts4,902,471
Members67,560
Most Online2,967
Mar 10th, 2019
Direct shift/Dual Clutch fluids #4517257
09/15/17 05:32 PM
09/15/17 05:32 PM
WY
sloinker Offline OP
sloinker  Offline OP
WY
I now have two new Volkswagen's that have DSG transmissions. With the 40k service interval and fluid prices and types all over the map I'm wondering? I want maximum transmission life. Any thoughts?
Re: Direct shift/Dual Clutch fluids [Re: sloinker] #4517280
09/15/17 06:05 PM
09/15/17 06:05 PM
WY
sloinker Offline OP
sloinker  Offline OP
WY
The drivetrain/tranny warranty is 60k, so VW probably is content that their mineral based spec oil is good enough for the warranty life. I on the other hand would just as soon get 100-200k out of the tranny without having to fork over the big money for a new one too soon.
Re: Direct shift/Dual Clutch fluids [Re: sloinker] #4517286
09/15/17 06:17 PM
09/15/17 06:17 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
I'm not knowledgeable on VW's DSG transmissions but if in doubt OEM is a good safe choice.
I know hyundai for example tests the ATF for markers(to determine if its oem fluid) before doing any transmission repairs.
Re: Direct shift/Dual Clutch fluids [Re: sloinker] #4517301
09/15/17 06:36 PM
09/15/17 06:36 PM
USA
slacktide_bitog Offline
USA
Amalie has the best price on DCT fluid. $76.29 for a case of 12 smile
Re: Direct shift/Dual Clutch fluids [Re: sloinker] #4517318
09/15/17 07:00 PM
09/15/17 07:00 PM
Outside U.S
Floydian Offline
Floydian  Offline
Outside U.S
DSG fluid should be changed every 60000km or 4 years according to VW.
Re: Direct shift/Dual Clutch fluids [Re: Floydian] #4517325
09/15/17 07:10 PM
09/15/17 07:10 PM
WY
sloinker Offline OP
sloinker  Offline OP
WY
40,000 mile interval according to the maintenance manual with the cars. That's close to 60,000 kilometers I suppose. I will endeavor to be clearer on mileage in future posts.
Any advantage for longevity using a synthetic over a mineral based fluid?
Re: Direct shift/Dual Clutch fluids [Re: sloinker] #4517328
09/15/17 07:15 PM
09/15/17 07:15 PM
USA
USA
Synthetic will probably last longer than a mineral/dino fluid, but I'd still change it at least the recommended 40k, if not more often. DCT tech is still not mature yet, and especially the way they act in regular daily driving in the city, even with brand new fluid.
My suggestion would be to change it at the recommended 40k while under warranty, then annually once the warranty is up. Especially since Amalie DCT fluid is a good price smile
Re: Direct shift/Dual Clutch fluids [Re: sloinker] #4517333
09/15/17 07:18 PM
09/15/17 07:18 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Why do you assume it's mineral based?
http://www.pentosin.net/specsheets/Pentosin_FFL-2.pdf
OP, go to ECS tuning for a wide variety of VW parts and an array of different DSG fluids: https://www.ecstuning.com/Volkswagen-Jetta_VI-Sedan-2.0T_Gen3_GLI/Drivetrain/DSG_Transmission/Fluid/
Me: 13' VW GTI 3 door 6 speed manual
Re: Direct shift/Dual Clutch fluids [Re: slacktide_bitog] #4517337
09/15/17 07:21 PM
09/15/17 07:21 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
People shouldn't expect such a transmission to act like a conventional automatic with a torque converter.
Re: Direct shift/Dual Clutch fluids [Re: sloinker] #4517355
09/15/17 07:47 PM
09/15/17 07:47 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Factory fluid and filters and at factory 40k intervals will see your DSG last a long time.
The only times I ever really saw issues with them was when fluid changes were neglected.
"Zed's dead baby, Zed's dead."
Re: Direct shift/Dual Clutch fluids [Re: sloinker] #4517418
09/15/17 09:11 PM
09/15/17 09:11 PM
Huntington WV
dbias Offline
dbias  Offline
Huntington WV
Ive always done my own DSG service its not hard. I use the drain/measure/replace method instead of the torturous fill from the bottom factory method.
2011 VW JETTA Castrol Edge 0W-40
2012 FORD TRANSIT CONNECT Castrol Edge 5W-20
2016 HONDA CIVIC COUPE Frankenbrew 0W-20 to 5w-40
2017 AUDI A4 Mobil1 0W-40
Re: Direct shift/Dual Clutch fluids [Re: sloinker] #4517528
09/16/17 12:25 AM
09/16/17 12:25 AM
MN
14Accent Offline
14Accent  Offline
MN
Stick with Pentosin and use the above method^^^. Happy DSG for years.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: Direct shift/Dual Clutch fluids [Re: sloinker] #4517535
09/16/17 12:54 AM
09/16/17 12:54 AM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
Get OE fluid (VW) or Pentosin.
Do not experiment with DSG fluid, bad fluid or not changing fluid is No. 1 cause of failure.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: Direct shift/Dual Clutch fluids [Re: sloinker] #4517633
09/16/17 08:07 AM
09/16/17 08:07 AM
pa
benjy Offline
benjy  Offline
pa
while researching tranny fluids i found out most OE are "synthetic" but the cheaper group III type, actually its just a thinner petroleum product with different additives. most drain + refill changes prolly get 1/3 to 1/2 the fluid so change early + often as trannys especially DSG's are very $$$$!!! i am a 3 pedal guy, no manual trans = no sale to me!!!
Re: Direct shift/Dual Clutch fluids [Re: skyactiv] #4517922
09/16/17 03:07 PM
09/16/17 03:07 PM
WY
sloinker Offline OP
sloinker  Offline OP
WY
Seems to me I found somewhere that the OE fluid is a blend.
Pentosin among others seems like a good choice except where it says not to mix with non-synthetics.
If the OE oil is a blend will it be ok to change to Pentosin knowing there is a percentage of the original oil left after draining?
