Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
Flow How: PourPoint warmer than CCV "0w" Temperature 0w20
by oil_film_movies. 03/25/19 05:31 PM
Oil filter material list?
by shibby6600. 03/25/19 04:49 PM
Insights on commission paying jobs?
by Pat in Speedway. 03/25/19 04:29 PM
Decode a vehicle VIN for production Month & Year?
by Ed_Flecko. 03/25/19 04:29 PM
Wix 51522 vs Fram XG9837
by RDY4WAR. 03/25/19 04:13 PM
Rural King: 20K Lumen LED Tripod Worklight $34.93
by skyactiv. 03/25/19 03:55 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
122 registered members (AndyB, 2015_PSD, 2010Civic, ARB1977, agpatel, ABerns, 15 invisible), 2,027 guests, and 67 spiders.
Topics286,429
Posts4,908,099
Members67,622
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
What oil should I use? #4517222
09/15/17 04:35 PM
09/15/17 04:35 PM
Illinois
NicaNica Offline OP
NicaNica  Offline OP
Illinois
Hi guys,
I am wondering if I should use High Mileage Synthetic Blend oil in my car. The car has been used on regular oil until now. Details below.
1. What kind of vehicle you have - Subaru Forester LL Bean 2006 / 181.000 miles
2. What your owner's manual says -- 5w-30 regular, or synthetic.
3. Where you live - Illinois, United States
4. How you drive (easy? hard? fast? slow?) - easy, not too fast
5. What your daily drive is like (short trips? long trips? city? highway?) - mostly long trips (around 3hrs), very little in city.
6. Whether your car has any known problems - it has a little bit of an oil leak, most probably due to a worn seal. Other than that is fine. I was thinking to put a synthetic blend, but I've been warmed it may cause the leak to expand. I was thinking also of a High Mileage version, due to the age of the car.
Thanks!
Re: What oil should I use? [Re: NicaNica] #4517224
09/15/17 04:39 PM
09/15/17 04:39 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
NAPA has the Synthetic on sale right now for 3.49 a quart if you buy a case. Its the same as Valvoline full Synthetic and that's a pretty cheap OIC.
2004 Corolla 130035
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: What oil should I use? [Re: NicaNica] #4517227
09/15/17 04:43 PM
09/15/17 04:43 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
I put Valvoline Maxlife in most engines - don't even bother with VWB most of the time. With an interval of roughly what the mfgr. recommends it should keep the engine together long past the failure of components due to factors other than lubrication. Worry not about making the leaks worse - I've changed dozens and dozens and have not seen that happen yet.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: What oil should I use? [Re: NicaNica] #4517250
09/15/17 05:20 PM
09/15/17 05:20 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Magnatec Synthetic Blend is the Best. thumbsup
Re: What oil should I use? [Re: NicaNica] #4517254
09/15/17 05:27 PM
09/15/17 05:27 PM
Outside U.S
Floydian Offline
Floydian  Offline
Outside U.S
Where is the oil leak located? I would definitively use fully synthetic.
Re: What oil should I use? [Re: Floydian] #4517270
09/15/17 05:51 PM
09/15/17 05:51 PM
Illinois
NicaNica Offline OP
NicaNica  Offline OP
Illinois
I don't know exactly, it's in the front under the driver's seat it seems. My mechanic says that he needs to degrease the engine, and under the car, and then see where it comes from. It's not a big leak, and sometimes it leaks, sometimes it doesn't. In a month, I need only once to top it (I keep a 1 quart bottle in the trunk).
The thing is, some mechanics (including mine), suggested not to use synthetic because they say, it may clean up the sludge that built up inside, uncovering the leak spot even more. And some mechanics also said that in that high mileage engine, using synthetic may cause it to burn the oil.
I was just thinking to use a High Mileage synthetic blend (not full synthetic). What is your experience with synthetic oil in an old car that has been used all its life on regular oil?
Re: What oil should I use? [Re: NicaNica] #4517284
09/15/17 06:12 PM
09/15/17 06:12 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
That it has to be pretty darn sludgy for those mechanics' theories to be true. I doubt your engine is that bad, and if it is, shame on you. Not even considering the HM additives that counteract any removing of deposits that would open up leaks.
Re: What oil should I use? [Re: Alex_V] #4517292
09/15/17 06:24 PM
09/15/17 06:24 PM
Illinois
NicaNica Offline OP
NicaNica  Offline OP
Illinois
I just bought the car 2 months ago, and I drove it about 2000 miles. The next oil change is coming soon, probably in a week-two, since I am driving about 500-600 miles per week. I don't believe the engine is that dirty inside, because it performs and sounds very snappy. Actually it is really really silent and smooth, about the same as my gf's 2016 Kia Rio with only 16k miles.
But then again, I want to keep the car for as long as possible and most mechanics seem to agree to just keep it on regular oil if it doesn't do any harm and if performs well with it. I just wanted to see what other people recommend and what has been working for their cars. I'll probably try synthetic blend on the next oil change, and see how it goes.
Re: What oil should I use? [Re: NicaNica] #4517304
09/15/17 06:45 PM
09/15/17 06:45 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Valvoline MaxLife 5W30 synblend in the red bottle. A great HM oil that offers everything you want.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: What oil should I use? [Re: NicaNica] #4517311
09/15/17 06:56 PM
09/15/17 06:56 PM
Outside U.S
Floydian Offline
Floydian  Offline
Outside U.S
Clearing up sludge is good for your although oil consumption may increase. Unless you don't top it up oil consumption won't kill your engine, but sludge will definitively will.
Re: What oil should I use? [Re: NicaNica] #4517322
09/15/17 07:06 PM
09/15/17 07:06 PM
Pennsylvania
K23Turbo Offline
K23Turbo  Offline
Pennsylvania
Another vote for the Valvoline Maxlife Synblend 5W30.
Re: What oil should I use? [Re: NicaNica] #4517339
09/15/17 07:21 PM
09/15/17 07:21 PM
PENNSYLVANIA
JeepWJ19 Offline
JeepWJ19  Offline
PENNSYLVANIA
Mobil 1 HM 5w30
Was recently (may still be) on Rollback at walmart
2002 Jeep WJ 4.0 | Mobil 1 HM 5w30 |
TG8A | 2.5" lift | 148k miles
Software Engineer :]
Re: What oil should I use? [Re: NicaNica] #4517341
09/15/17 07:24 PM
09/15/17 07:24 PM
West Michigan
HM12460 Offline
HM12460  Offline
West Michigan
Another vote for Valvoline Maxlife. Your car is an ideal candidate for this quality oil.
2018 Chevy Colorado
1995 Ford Thunderbird
Re: What oil should I use? [Re: HM12460] #4517348
09/15/17 07:33 PM
09/15/17 07:33 PM
Illinois
NicaNica Offline OP
NicaNica  Offline OP
Illinois
For all of you who voted for Valvoline's Max life syn blend - what do you think about Castrol's HM syn blend (green bottle), compared to Valvoline's? I found it near me at a discount, but both normally have the exact price (at least at the Autozone near me).
Thank you all for suggestions!
Re: What oil should I use? [Re: NicaNica] #4517375
09/15/17 08:29 PM
09/15/17 08:29 PM
Vancouver, Canada
dubber09 Offline
dubber09  Offline
Vancouver, Canada
Go with HM oil of same 5w-30 for winter, change to HM 10w-30 in the spring.
Kia Sportage 2014 GDI 2.4L
Kia Forte 2014 MPI 1.8L
Page 1 of 3 1 2 3
