FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
111 registered members (ArrestMeRedZ, AndyB, addyguy, avi1777, anndel, 12 invisible), 2,066 guests, and 54 spiders.
Topics286,151
Posts4,903,046
Members67,565
Most Online2,967
Mar 10th, 2019
'09 Impala with steering shuddder /noise, lo speed #4517087
09/15/17 01:40 PM
09/15/17 01:40 PM
Canada
i_hate_autofraud Offline OP
Canada
Hi all!
Just got some weird noise, shudder, clunking & shimmy in low speed 90 degree turns only, like into a parking space!
Car is '09 Impala 3.5L V6 140,000 miles (227,000 Kms)
Just checked:
- PS fluid OK level, no foaming, no leaks (not flushed)
- Serpentine Belt looks good, tight, no cracks
- Tire pressures OK
- Lug nuts OK
- no loose Tie rods (jacked up to check)
- no other loose suspension parts " "
- no wheel bearing noise
any ideas guys? searched for similar posts, found nothing.....
Thanks!
Re: '09 Impala with steering shuddder /noise, lo speed [Re: i_hate_autofraud] #4517103
09/15/17 02:04 PM
09/15/17 02:04 PM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
what are the condition of the tires?
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: '09 Impala with steering shuddder /noise, lo speed [Re: i_hate_autofraud] #4517138
09/15/17 02:37 PM
09/15/17 02:37 PM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
When you had it jacked up, did you rock the tires hard to check the bearings? Another possibility is the 1/2 shaft. I had an Audi that presented that way. It's one side only, correct? Because if it's both, then that's different (steering).
Re: '09 Impala with steering shuddder /noise, lo speed [Re: i_hate_autofraud] #4517142
09/15/17 02:41 PM
09/15/17 02:41 PM
Virginia
bigt61 Offline
bigt61  Offline
Virginia
Tires, struts - at full lock, you have a lot of caster jacked in which puts more pressure on various parts and likely the tire sidewall as well. Does this happen equally going right and left? I would say the "turn in" side would be more stressed. You can try varying tire pressure to see if it gets better or worse - try it at 20lbs and then at 40lbs. Maybe that will give a clue. I know belts going bad in tires can cause all kinds of problems and have you chasing the wrong thing.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
Re: '09 Impala with steering shuddder /noise, lo speed [Re: Bgallagher] #4518349
09/17/17 06:58 AM
09/17/17 06:58 AM
Canada
Canada
Thanks, Tires are good at 60% thread, rebalanced 18 months ago. no lumps or bumps, pressure at 32PSI
Re: '09 Impala with steering shuddder /noise, lo speed [Re: Oro_O] #4518350
09/17/17 07:03 AM
09/17/17 07:03 AM
Canada
Canada
Thanks, I lifted each side one at a time and rocked the tire top to bottom, then left to right.
Top to bottom had a little clicking, I'd don't recall having before, left to right was solid, new tie rod ends 2 yrs ago.
Turing the wheel had some play, didn't seem more then before.
I'll try lifting both sides and see overall CV play and everything all over again.
