Trooper recommends dash cameras
by FordBroncoVWJeta. 01/22/19 07:14 AM
New Harley synthetic 80w-140 gear released
by shanneba. 01/22/19 06:43 AM
Registering a Vacation Car
by ssamaroo01. 01/22/19 06:23 AM
Starter cross reference?
by dlundblad. 01/22/19 05:11 AM
Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
How cold is it? (Humor)
by StevieC. 01/21/19 07:13 PM
Slight performance decrease
by A_User55555. 01/21/19 06:54 PM
Binco, Coolbreez1973, jmcast1127, DF8005, FT86dude11
67009 Registered Users
112 registered members (53' Stude, 4WD, alteredtuning990, 2strokeNorthstar, AandPDan, 9 invisible), 1,718 guests, and 30 spiders.
Topics296,966
Posts4,962,521
Members67,009
Most Online2,821
Yesterday at 01:32 PM
Bleeding ABS unit - Mazda #4517016
09/15/17 11:09 AM
09/15/17 11:09 AM
PA
Chester11 Offline OP
PA
I think I pushed some air into my ABS unit. At least I am hoping that is the problem.
I've changed pads, and replaced the fluid, but the pedal is still soft. I'm going to relube the caliper pins and bleed again this weekend.
The manual says ABS bleed is a dealer only process - apparently it requires a scan tool to activate the system and push the air out of the unit and into the brake lines. (My interpretation).
Will some hard stops bleed the unit by activating the system? Anyone tried it?
Re: Bleeding ABS unit - Mazda [Re: Chester11] #4517025
09/15/17 11:24 AM
09/15/17 11:24 AM
Central Virginia
Silverado12 Online content
Silverado12  Online Content
Central Virginia
Not sure if this is even related, but I had a hard time with a Hyundai Santa Fe brake job and I bled them diagonally and that ended up fixing it. Also, another thing that drove me nuts was the pads took a long time to 'feel right".
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Bleeding ABS unit - Mazda [Re: Chester11] #4517045
09/15/17 11:55 AM
09/15/17 11:55 AM
Florida, Cape Coral
Eddie Online sleepy
Eddie  Online Sleepy
Florida, Cape Coral
Once you've messed up and gotten air into a ABS system it is difficult to get the air out with out the recycling tool. A brake shop should be able to do this. Trying to clear the system of air by abusing the brake system with multiple panic stops would prove frutal I think. Ed
CX5 Touring 2.5L :-)
Re: Bleeding ABS unit - Mazda [Re: Chester11] #4517162
09/15/17 02:12 PM
09/15/17 02:12 PM
SW Ontario Canada
KGMtech Offline
KGMtech  Offline
SW Ontario Canada
Had the same problem with my wife's 2009 Ford Flex. One of the rear calipers developed a leak and I was not aware until my oldest son told me after he drove for 2.5 hours round trip to a concert...the BF reservoir got low enough to get air in ABS system.
2 attempts by me with my Motive Bleeder, no luck. Tried the redneck way of activating the ABS system on gravel roads, still no luck.
Took it to Ford dealer, spent the money and they activate ABS circuits by OBDII portal and all was good. Lighter wallet, but hard brake pedal.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Bleeding ABS unit - Mazda [Re: Chester11] #4517244
09/15/17 04:13 PM
09/15/17 04:13 PM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
FORScan might be able to do it
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: Bleeding ABS unit - Mazda [Re: Chester11] #4517274
09/15/17 04:56 PM
09/15/17 04:56 PM
California
nthach Offline
nthach  Offline
California
Depends on the system - you just described how I had to bleed a friend's Tahoe with the Kelsey-Hayes ABS system.
You can try a few hard stops to trigger the ABS and then bleed. A pressure bleeder does help with ABS. Have you tried topping off the MC and cracking the line fittings at the modulator to get fluid moving in that direction and then bleeding at the wheels?
Re: Bleeding ABS unit - Mazda [Re: nthach] #4517536
09/16/17 12:02 AM
09/16/17 12:02 AM
PA
PA
Not tried this - the lines looked pretty small and was afraid to break them, or introduce more air into the system.
Re: Bleeding ABS unit - Mazda [Re: Chester11] #4517538
09/16/17 12:06 AM
09/16/17 12:06 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Find some wet grass, and let it grind to a halt a few times between bleeds.
Re: Bleeding ABS unit - Mazda [Re: Shannow] #4517563
09/16/17 02:50 AM
09/16/17 02:50 AM
Tennessee
ChevyMan93 Offline
ChevyMan93  Offline
Tennessee
Fully agree with this statement.
2016 Chevrolet Silverado Z71 5.3
2017 Honda CR-V 2.4
