Is there a new (2018) list of GM Dexron VI licensees?
by garageman402. 09/26/18 01:20 AM
Thoughts on new AMAZON branded oil...?
by PantherFan88. 09/25/18 10:47 PM
Clutch kit?
by andrewp1998. 09/25/18 10:34 PM
Galaxy S8+ weird app when clearing storage
by KrisZ. 09/25/18 10:18 PM
Brake bleeder - cfm ?
by hallstevenson. 09/25/18 09:43 PM
18' Corolla vs 18' Elantra
by wolf_06. 09/25/18 09:41 PM
Using Tc-w3 bad for my car?
by Floydian. 09/25/18 09:25 PM
I'm going to start using type F in my gm autos
by turtlevette. 09/25/18 09:17 PM
Cleaning deceased MIL condo and found $15K cash
by Mr Nice. 09/25/18 09:12 PM
Gluten
by StevieC. 09/25/18 07:55 PM
Amazon Prime delivering inside your house
by StevieC. 09/25/18 07:49 PM
2018 MB C300 M1 0W-40 3,475 Miles
by 2015_PSD. 09/25/18 06:44 PM
02-05 Silverado frame rot
by Oildudeny. 09/25/18 06:38 PM
Aftermarket Back Up Camera
by lancerplayer. 09/25/18 06:20 PM
Service champ filter CUT OPEN
by 53' Stude. 09/25/18 05:05 PM
Pressure washer pump life just 23 hours?
by HawkeyeScott. 09/25/18 05:01 PM
STP S 10590 CUT OPEN
by 53' Stude. 09/25/18 05:00 PM
2003 BMW M5-Unknown oil 2500 mi
by Audios. 09/25/18 04:54 PM
Pat_Roberts, Peppz, Jfa02, ibsfusion, Fearcat707
66070 Registered Users
34 registered members (Blue_Goose, 2015_PSD, 2013ecof150, CB900F2, 53' Stude, BlakeB, 5 invisible), 459 guests, and 45 spiders.
Topics291,026
Posts4,854,700
Members66,070
Most Online3,590
Jan 24th, 2017
2014 V Strom 1000 Rotella T6 5W-40 #4516630
09/14/17 10:48 PM
09/14/17 10:48 PM
California
jdoucet Offline OP
jdoucet  Offline OP
California
Well, this might not be good. To answer the question in the comments, the oil pressure is normal in that the oil light goes out immediately after starting, and I have not noticed any knocking. Any ideas?
Re: 2014 V Strom 1000 Rotella T6 5W-40 [Re: jdoucet] #4516643
09/14/17 11:11 PM
09/14/17 11:11 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Can't read it? To small.
2004 Corolla 124900
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74277
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 74705 4-22-18
Re: 2014 V Strom 1000 Rotella T6 5W-40 [Re: jdoucet] #4516650
09/14/17 11:27 PM
09/14/17 11:27 PM
California
jdoucet Offline OP
jdoucet  Offline OP
California
Second try.
Re: 2014 V Strom 1000 Rotella T6 5W-40 [Re: jdoucet] #4516656
09/14/17 11:36 PM
09/14/17 11:36 PM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
That's a LOT of copper.
I'm not crazy about 5w40 in the Strom.
I rode an SV for a couple seasons, and found it liked and had better UOA on 20w50's than xw40's.
What is total mileage on the bike?
Try a 20w50, run another UOA and see if you trend down.
Nothing special in the Suzy,you do not need synthetic. Havoline 20w50, Pennzoil 20 or even 25w50 is just fine (unless you have heated gear and ride all winter) and clutch friendly. Don't lug the engine, keep that twin moving.
Get a Bales filter stub, switch to more common 6607 or 7317 filter also. You'll save some cash and have a range of better filters.
http://balestech.com/filter.htm
beanoil: Tough under heat, real dirty afterwards.
Re: 2014 V Strom 1000 Rotella T6 5W-40 [Re: jdoucet] #4516677
09/15/17 12:38 AM
09/15/17 12:38 AM
USA
Reddy45 Offline
Reddy45  Offline
USA
How did you pull the sample? After a long hot ride and directly from the drain?
Those numbers are not good.
Have you been doing a lot of extended wheelies?
Re: 2014 V Strom 1000 Rotella T6 5W-40 [Re: beanoil] #4518737
09/17/17 04:20 PM
09/17/17 04:20 PM
California
jdoucet Offline OP
jdoucet  Offline OP
California
Switched out to Rotella 15w-40 yesterday, has some on hand. I'll see if that makes any difference.
Re: 2014 V Strom 1000 Rotella T6 5W-40 [Re: Reddy45] #4518739
09/17/17 04:22 PM
09/17/17 04:22 PM
California
jdoucet Offline OP
jdoucet  Offline OP
California
Yep, hot oil after a ride, directly into sample bottle from drain hole. Don't wheelie, traction control keeps the front wheel down.
Re: 2014 V Strom 1000 Rotella T6 5W-40 [Re: jdoucet] #4519068
09/17/17 11:00 PM
09/17/17 11:00 PM
USA
Reddy45 Offline
Reddy45  Offline
USA
Best of luck. These motors are normally bulletproof and very reliable.
Re: 2014 V Strom 1000 Rotella T6 5W-40 [Re: jdoucet] #4519221
09/18/17 08:29 AM
09/18/17 08:29 AM
Cedar Park, TX
sunruh Offline
sunruh  Offline
Cedar Park, TX
that may be the highest copper reading i have ever seen
congrats in a UH OH kinda way
you need to look at thrust bearings or bushings
tin and lead ... while typical of saddle bearings...how many does your motor really have?
i would bet close to zero
so....where is tin and lead coming from?
also is the titanium a ghost of the famous [censored] silver 1 or actually in it?
if so where is the Ti coming from as well? might be related.
any idea on valve guide material?
while i dont like 5w40 in shared sump bikes in the summer they do NOT cause this kind of wear.
your flash and susvis show it wasnt that thin (upper 30wt)
so...we need to figure out where these number a coming from
motorcycle oil myth buster
Re: 2014 V Strom 1000 Rotella T6 5W-40 [Re: jdoucet] #4519990
09/19/17 05:50 AM
09/19/17 05:50 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
Yes, I dont know how much of a difference it will make but until I saw your post I was going to suggest that you use the recommended weight oil as a starting point which you are now doing, Rotella T6 5w40 weight oil is not a recommended oil for your engine to the best of my knowledge.
Agree with sunrah, I doubt this issue is just the oil, just make sense to use the proper oil to begin with and T6 5/40 is not..
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: 2014 V Strom 1000 Rotella T6 5W-40 [Re: jdoucet] #4520450
09/19/17 04:21 PM
09/19/17 04:21 PM
Oregon
jgturbo Offline
jgturbo  Offline
Oregon
Wet clutch friction plates often contain a fair amount of copper. I wonder if that's part of it?
Re: 2014 V Strom 1000 Rotella T6 5W-40 [Re: jgturbo] #4520933
09/20/17 06:07 AM
09/20/17 06:07 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
Not for anything as I do not know much about your engine, but here are UOAs from older ones of the same bike.
This guy ran 4 UOAs short OCIs, looking at them, it seems like maybe the iron is normal in your UOA but your copper is whacked out for sure. Again, based on this ... and as you can see, oil type doesnt matter as much, in most aces we split hairs, not to say it doesnt matter but who knows what does matter... for a limited test on limited elements.
Click here, 4 UOAs on your bike engine (I think)
07 Suzuki C50
Re: 2014 V Strom 1000 Rotella T6 5W-40 [Re: alarmguy] #4520935
09/20/17 06:13 AM
09/20/17 06:13 AM
Texas
4WD Offline
4WD  Offline
Texas
Never understood the T6 (put it in everything) obsessions here ... did they ever get NOACK down?
Re: 2014 V Strom 1000 Rotella T6 5W-40 [Re: 4WD] #4521517
09/20/17 06:08 PM
09/20/17 06:08 PM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
Originally Posted By: 4WD
Nvever understood the T6 (put it in everything) obsessions here ...
Me too
07 Suzuki C50
Re: 2014 V Strom 1000 Rotella T6 5W-40 [Re: jdoucet] #4522021
09/21/17 09:05 AM
09/21/17 09:05 AM
Cedar Park, TX
sunruh Offline
sunruh  Offline
Cedar Park, TX
blue jug 5w40 is a great oil
its just not great for a shared sump motor/tranny
it can be a great winter oil with a short oci
it just doesnt have much shear resistance for the tranny gears from what i have tested
and once again, the oil is NOT the source of his copper issue...something else is clearly in play here
