Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
A cool litttle Fall foliage site
by Papa Bear. 09/23/18 06:02 PM
Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
40 registered members (Ag76, Bailes1992, BKlab, Blkstanger, AndyB, 4 invisible), 1,022 guests, and 35 spiders.
Topics290,918
Posts4,852,504
Members66,055
Most Online3,590
Jan 24th, 2017
What will Amsoil's Gen 2 formula look like? #4516571
09/14/17 09:22 PM
09/14/17 09:22 PM
IL
lukejo Offline OP
lukejo  Offline OP
IL
Signature Series has always used BIG calcium numbers....which they at least partly attribute to the extended drain intervals. They now say they've conquered LSPI and surpass Gen 2 with the formula rolling out next week. (Let's assume this is true and not go off on their lack of true certifications.)
So, did they accomplish this by greatly reducing calcium levels...and increasing something else to still be claiming a 25k OCI?
OR...have they been able to control LSPI without reducing their pet Calcium?
Re: What will Amsoil's Gen 2 formula look like? [Re: lukejo] #4516575
09/14/17 09:24 PM
09/14/17 09:24 PM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
Should be interesting. I'd like like to know that, also.
Re: What will Amsoil's Gen 2 formula look like? [Re: lukejo] #4516762
09/15/17 06:26 AM
09/15/17 06:26 AM
New England
Virtus_Probi Offline
New England
Additive manufacturers have been good about sharing LSPI/oil info and have indicated that sodium is a big LSPI accelerant in the presence of calcium and that ZDDP helps quench it. It might be possible that a good dose of calcium would still be OK for LSPI if there is no sodium present and a bigger dose of ZDDP than SN allows is used, and Amsoil is definitely a company that is OK with putting out non-API oils.
I am definitely very curious about what their new SS 0W30 and 5W30 oils will look like!
2014 Forester XT, 86000 miles
Last Change;
M1 5W30 d1G2
Tokyo Roki 15208AA170 filter
Re: What will Amsoil's Gen 2 formula look like? [Re: Virtus_Probi] #4516796
09/15/17 07:29 AM
09/15/17 07:29 AM
IL
lukejo Offline OP
lukejo  Offline OP
IL
Interesting. Thanks for the sodium explanation!
I don't know about the ZDDP/SN possibility though. Being their "mainstream" oil, I think they would still want to meet certification specs on paper.
Re: What will Amsoil's Gen 2 formula look like? [Re: lukejo] #4516812
09/15/17 08:02 AM
09/15/17 08:02 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
Everyone's "All In" wink
'18 KIA Sportage LX AWD 2.4L: MSS 10w30
'13 Hyundai Santa Fe Sport 2.0T: EDGE 5w30
Re: What will Amsoil's Gen 2 formula look like? [Re: wemay] #4516856
09/15/17 08:48 AM
09/15/17 08:48 AM
bigj_16 Offline
bigj_16  Offline
This is kind of interesting. I wonder if ExxonMobil and Toyota will make this "technology" available to everyone.
Re: What will Amsoil's Gen 2 formula look like? [Re: Virtus_Probi] #4516863
09/15/17 08:53 AM
09/15/17 08:53 AM
bigj_16 Offline
bigj_16  Offline
Not discounting the sodium, but some of the studies I read mentioned calcium, of any formulation, as the culprit, with no mention of sodium. Can you post a link to the sodium study? I think something that would be prudent, right now, would be to go with a lower calcium pack, i.e. most M1, until this is locked down.
Re: What will Amsoil's Gen 2 formula look like? [Re: bigj_16] #4516906
09/15/17 09:49 AM
09/15/17 09:49 AM
New England
New England
Here's a link for an LSPI study mentioning the impact of sodium...
http://www.infineuminsight.com/insight/nov-2016/quenching-low-speed-pre-ignition
Great post by wemay that brings up the impact of moly, which I had forgotten about! So a high moly oil might be able to handle more calcium and still be LSPI resistant. I really have no idea how stringent the dexos1 Gen 2 LSPI test is, anyway...
EDIT - interesting that the XOM patent gives magnesium half the weight of calcium as an LSPI accelerant while Infineum says it is LSPI-neutral...
Last Change;
M1 5W30 d1G2
Re: What will Amsoil's Gen 2 formula look like? [Re: Virtus_Probi] #4516910
09/15/17 09:54 AM
09/15/17 09:54 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
The Sodium is interesting because it seems the Valvoline Dexos gen 2 still has sodium unless the spec sheets haven't been updated. I could be wrong though.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: What will Amsoil's Gen 2 formula look like? [Re: CT8] #4516912
09/15/17 09:59 AM
09/15/17 09:59 AM
New England
New England
Looks like the 9/7 sheets with the Gen 2 licenses don't give sodium info anymore.
https://sharena21.springcm.com/Public/Do...10-ac162d889bd3
Last Change;
M1 5W30 d1G2
Re: What will Amsoil's Gen 2 formula look like? [Re: Virtus_Probi] #4517035
09/15/17 12:40 PM
09/15/17 12:40 PM
bigj_16 Offline
bigj_16  Offline
Thanx! What I really need to do is shell out the $$ for the SAE paper.
This is what Oronite says about calcium, magnesium, and moly:
"Many factors have been demonstrated to impact LSPI, including: engine designs, fuel composition, and lubricant composition. On the lubricant side, the most noticeable impact has been from the detergent chemistry. Oils with higher concentrations of calcium, which is found in many detergent systems, have been shown to increase the frequency of LSPI. The exact chemistry of the detergent is less important to LSPI than the calcium content. Conversely, magnesium-based detergents do not seem to promote LSPI. Although reducing calcium may seem like a solution to control LSPI, there may be other performance tradeoffs to consider. In addition there are other additives that can also help reduce LSPI events. This provides an opportunity to formulate for robust LSPI performance, while maintaining the level of detergency needed to help keep engines clean and neutralize acids generated during combustion.
Aside from the detergent system, there are many other additive and lubricant compositions that can influence LSPI. Molybdenum compounds, for example, not only provide frictional benefits, but also have been shown to decrease LSPI when used at high levels. Base oils also affect LSPI events. Both the quality of the base stock (i.e. Group II versus Group III) and the viscosity can have secondary effects on LSPI. The effect on LSPI from these other lubricant aspects are not as significant as the detergent system, but can shift the LSPI frequency in oils that are more prone to LSPI."
I know why, in the Infineum cited SAE study, that they used the "clean" gasoline that they did, but I wonder if there is any issue with "street" gasoline adding to, or possibly, increasing the LSPI in combination with the lubricant.
Re: What will Amsoil's Gen 2 formula look like? [Re: lukejo] #4517042
09/15/17 12:53 PM
09/15/17 12:53 PM
bigj_16 Offline
bigj_16  Offline
Another interesting excerpt from the Infineum/SAE piece, and something I have seen alluded to before:
"Three different viscosity grades - SAE 0W-16, 0W-30 and 10W-30 - were tested and although directionally a trend of decreasing LSPI event count with increasing SAE viscosity grade was seen, the differences were not statistically significant. While simplistically it could be assumed that more viscous lubricants may reduce LSPI counts, for the viscosity grade range covered and number of tests performed, viscosity grade here is considered LSPI neutral."
Re: What will Amsoil's Gen 2 formula look like? [Re: lukejo] #4517611
09/16/17 07:20 AM
09/16/17 07:20 AM
IL
lukejo Offline OP
lukejo  Offline OP
IL
Maybe Pablo has heard something he can share about the Gen 2 formula?
'05 Corolla 285k
'09 Silverado 2500HD 6.0, 95k
'12 Camry LE 4cyl, 155k
